Question about GE Monogram® ZSC1001KSS Stainless Steel Oven
GE monogram advantium 120 ZSC1001KSS
I have GE monogram advantium 120 ZSC1001KSS, after a power outage, the display is not working anymore. I can still press other buttons and hear beeps, but without display, it is hard to do much. What should I do?
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: F0 error - My GE Over displays an F0 error & constantly beeps
Appu, the F0 error for this built in means there is a shorted or stuck off key. Sometimes this can be resolved by removing the keypad ribbon cable from the board and cleaning the ends with an eraser. If that doesn't work, you want to find out whether its the board or keypad by ohming the ribbon cable, 3 to 4, probes on the conductor side...should read 125 to 1750 ohms while pressing the off key. Catriver..post back.
Posted on Apr 30, 2007
SOURCE: The GE Profile Advantium SCB2001KSS
Well right now I'm looking for how to just turn off the beeping. Our GE Profile isn't the same model, but it does the same thing. Found a fix that works, but we have to use it every few months when the keypad locks again. Here's the solution to getting it running again:
unscrew and take off the faceplate exposing the motherboard and chips/wires. unplug/unsnap the wide, flat power cord attached to the digital face. Take a pencil eraser and use it to clean the metal contact points where the power cord meets the display (the ones that are visible once u unplug the cord). Put it back together and tadaa... it works again.
My guess is that it gets some sort of buildup over time that u just have to clean off. Anyway, good luck. Hope this helps
Posted on Jan 13, 2008
localwonder
  • 6784 Answers
SOURCE: F1 error/touch panel not working on GE Monogram Dual Oven
Usually, the F1 means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
I recommend a service call for this repair.
Posted on Jun 03, 2009
SOURCE: ge profile advantium 120, scb1001 oven, display panel out
Turned off breaker for 30 seconds. Display returned.
Posted on Jan 20, 2010
Scb2000 GE Advantium 240 microwave not heating
It s the magnetron tube, thats what makes the microwaves. Not a hard fix, you can order one from sundberg.com or marcone .com with your model number
Jul 19, 2012 | GE Monogram 30" 240 Volt Black Built In...
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
GE Advantium Microwave portion not working
There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
Sep 02, 2017 | GE ZSC2001FSS Advantium Electric Single...
TOp Oven Light ..
if its a brand new unit (still in waranty) make the service call
Aug 30, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Jun 29, 2008 | GE ZSC2001FSS Advantium Electric Single...
Advantium zsc2001fss no power no lights
I have same unit...power outage made unit come back on and it then requested user to set the clock, but the display shows the hours but won't accept the pushputton to lock it in. I had to look at the control panel today to see how hard it would be to replace.
To take off the front vent panel: first take microwave out of the built-in space, disconnecting the power cord. Then the top outer metal skin can be unscrewed and removed, which exposes the screws that hold in the front top vent and the control panel in place.
Feb 21, 2008 | GE ZSC2001FSS Advantium Electric Single...
Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
GE Monogram® ZSC1001KSS Stainless Steel Oven Logo
276 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
