Question about Kenmore Microwave Ovens
Oven wont come on it has an electric igniter the ignitor will glow bur the oven wont come on
  • 999 Answers
The ignitor is weak and not allowing the valve to open or the valve is faulty. Easy test: while the ignitor is glowing, tap on the valve body with the handle of a large screwdriver. If it lights replace the ignitor. If not replace both the ignitor and the valve.
Eric
Posted on Sep 15, 2009
Hi, whirlpool rf302 bake wont work but broil does. Thanks
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 29, 2011 | Microwave Ovens
I have a CGR3740ADW EVERYTHING WORKS BUT TGE OVEN WONT HEAT I PUT IT TO A TEMPETURE AND ITS SAYS ITS PREHAETING BUT DOESNT HEAT OR SMELLS GAS THE BROIL WORKS FINE
heatman101
Aug 08, 2011 | Microwave Ovens
Oven does not heat up. The ignitor glows, but the oven does not light. There is a strong gas smell after about 5 minutes.
Change the ignitor. Although it glows it is too weak to light the gas.
You can test it with an amp meter. The ignitor should read 3.3 amps or higher.
If not,it is bad.
Jul 12, 2011 | Microwave Ovens
Amana arg7102w gas range broiler works fine but regular oven doesn't heat up, viewed igniter from the back while turned on and see igniter glow but no gas flowing, can't find service manual online...
heatman101
Jul 12, 2011 | Amana Microwave Ovens
Oven does not light properly. igniter glows, but does not ignite until gas builds up, then it blows the oven door open slightly!
heatman101
Apr 21, 2011 | Microwave Ovens
When I turn it on, the heating element glows, but there doesn't seem to be any gas flowing through. I checked the valve, and it's open. Does this oven have a pilot light that needs to be lit?
The glow you see is actually the ignitor, it has taken the place of the out-dated pilot light. It is likely that your ignitor is partially burnt out and the safety valve is not opening. A good bake ignitor draws just over 3 amps and the safety valve will not open until it reads this 3 amp draw.
If the glow you see is a dull orange, it is likely that the ignitor is bad.
Apr 15, 2011 | Microwave Ovens
Gas oven
Just because it glows that does not mean it is not bad...
heatman101
Aug 29, 2010 | Microwave Ovens
Stove top works and the oven does not.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 18, 2010 | Microwave Ovens
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
Integra fan convection - rsa regency
you might be able to just clean the ignitor to get it working again. Take it out and give it a good cleaning. If that doesn't work then it could be your spark module. If it is your spark module it will have to be replaced. I have replaced spark modules and ignitors of ovens or ranges that you can no longer get parts for with whirlpool modules and ignitors. There are basically two types, just make sure you get the same type. One type , typically used by GE uses a continous ignitor that glows when it works, and Whirlpool (on most models) uses the spark module and ignitor that makes the clicking sound like your oven did for ignition.
Jul 24, 2006 | Bosch HLK4525GB Convection/Microwave Oven
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
