Question about Nintendo DS Lite Console
Nintendo ds lite 'A' button not working , how to repair?
  • 83 Answers
Needs new conductive pads see www.dsdoctor.co.uk
Posted on Sep 17, 2010
  • 30 Answers
Buy spares on ebay(you will need a tri wing screwdriver) If you are unsure I can repair.
Posted on Sep 19, 2009
  • 51 Answers
If it is just the pllastic "A" button you can buy a set of replacement buttons on eBay for a couple of euros with a trihead screwdriver and simply search youtube for a tutourial video on how to remove the screws etc.
If the "A" button is still in one piece and in the Ds unit you have danaged the underlying button pad which is embeded in the motherboard and can be exspensive to sort out. If this is the case you would be better trading it in against a new system.
Posted on Sep 18, 2009
SOURCE: Nintendo Ds lite not working needs to be repaired
sounds like you both have a lose connection on the circuit board, so easily done, even if one cable is slightly misaligned the ds will not turn on, do they charge o.k?? if so it is a faulty connection
Posted on Apr 03, 2008
  • 13 Answers
SOURCE: nintendo ds lite repair
i had the same problem, the light would come on and for a split second you'd see a blue screen on the bottom and then it poweres down again. its because the thin ribbion cable is not plugged in all the way. On the white connector where the ribbon plugs in , there is a little black door that clamps down on the cable keeping it inplace. make sure youve clamped it down or it will fall out. I thought i had it plugged in well there too ,but when i powered it up i had your problem so i opened it up and found that the ribbon wasnt in all the way, and then it would power up, but my touch screen was unreponsive. i think i chiped something on the mother board. hope that helps
Posted on Aug 18, 2007
  • 19 Answers
SOURCE: my nintendo ds lite top screen isn't working properly
Top LCD's flex cable that passes through right-hand hinge into bottom part of case will be damaged or not properly seated in its connector socket.
Posted on Jan 01, 2008
open it up and clean out the ds
Posted on Apr 12, 2008
SOURCE: how do i fix the R button on my Nintendo DS Lite
Take a q tip and wet the end. then you rub the crack between the button and the actual ds the dry it off and blow on it really hard three times
Posted on Apr 28, 2009
Nintendo ds lite l button doesnt work
Does it click when you press it or does it seem to be out of position? If so, that's an easy fit.To fix this you'd have to open up the DS and re position the button and the pin holding it in place.
If not that, its probably got something to do with the trigger inside the DS. When you press the shoulder buttons, they push into a button just below them on the motherboard, which sends a message to the DS. If that has fallen off or started malfunctioning in any way, it could definitely be causing this. You'd have to order one online (link provided to an example) NINTENDO DS LITE BUTTON SWITCH REPAIR PARTS 4 NEW and then solder it in after desoldering the other one, if you know how to do that.
If not, there are probably some repair guys with an ad on your local Craigslist who'd be happy to do it for you for a quick buck.
Jun 17, 2014 | Nintendo DS Lite
Nintendo DS lite "L" "R" button dont work
OK the buttons are probably dirty. I had this same problem with my DS. Pry open the outside edges of the buttons until there is a gap. Blow into the gap while making sure you dont spit in the console. This should clear out the dirt and make your buttons work.
Dec 26, 2009 | Nintendo DS Lite
Nintendo L and R button do not function.
You will have to open the ds and clean the two small press pads under the buttons as the sand has got stuck in them.
Sep 04, 2009 | Nintendo DS Lite
Nintendo DS Lite Top Screen works at certain angle
my mates ds lite happened the same too. the only thing you can do is...
1. send it back to nintendo if its insuared
2. buy a new one
3. try and fix it yourself (mate used sellotape)
Jul 07, 2009 | Nintendo DS Lite Console
My nitendow ds lite right trigger button isnt
yes the internal switches are the same so repairs are the same.
Jul 06, 2009 | Nintendo DS Lite White Console
DS Lite - broken on/off button
Why don't you go to the nintendo website they can help you, you can explain your problem, ship of the DS and get it back fixed.
Mar 09, 2009 | Nintendo DS Lite Console
Game slot has been damaged on nintendo ds
I can give you some answers but might not work. See if the slot where the Ds game suppose to go needs to be cleaned.Take a pice of cotton from the cutip and put it on your stlyer(DS stick).Clean inside of it.Stiil dose not work and have a warranty go get the ds repaired.DO NOT PUT LIQUID IN THE DS SLOT(WILL NEVER WORK AGAIN TILL REPAIRED).
Dec 30, 2008 | Nintendo DS Lite Console
The A button doesnt work on nintendo ds lite, is that repairable.
If this is the case then you should dismantle your ds entirely. You have to use a triwing screwdriver which arevery cheap buttttt...
Dec 18, 2008 | Nintendo DS Lite Console
Left button on Nintendo Ds Lite
From looking around, you can get replacenet parts for the DS. Its a little tricky though. Do you have any friends that mess around with building and moding computers? They may be able tohelp you
Jul 14, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
1,068 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
