Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I need to remove front ice maker cover on whirlpool ed22tqxew00
I think it is held on with adhesive only but I'm not sure. I really do not want to crack it. How do I get it off (I need to replace a broken light switch).
Thanks,
Dan Rasmussen
I'm no expert, and I am myself trying to figure out my ice-maker issue (no ice) but I think it might also depend on your model and how old it is. Mine is 4-5 years old so here's how it is in mine:
If the icemaker cover lifts bottom-up, (and hits the light switch on the top) ... then there are 2 slots into which the cover's center area mini-protrusions (for lack of a better word) are fitted. It's a shift to release mechanism (the release is to push the holders away from the protrusions).
Posted on Sep 12, 2009
How to remove Kenmore ice maker 363.59572994?
I sure hope you got an awesome deal on that refrigerator. I would hate to think they charged extra for the mouse :-) Unfortunately, the ice bucket in this model does not just slide out like your other one did. You should be able to remove the front cover & flap of the ice bucket to reveal the ice maker and yes, it is bolted in. below is an exploded parts diagram of the ice maker. As you can see, the whole thing can be taken apart - of course you then have to put it back together. If it were me, I would toss it & replace the ice maker rather than try to disinfect/ sterilize the one in there. Good Luck!!
Jun 05, 2014 | Whirlpool GS6NBEXR Side by Side...
Remove ice maker?
Yes you can just remove the ice maker and no cover is necessary for the female connector, it will not harm the operation of the unit at all. You just need to use trays if you want ice.
Apr 19, 2014 | Whirlpool Refrigerators
Ice maker lever broken not making ice.
Not the lever that is broken. Common problem with w'pool. Pull the front cover off the i/m and you will see a module held in place with 3 screws. Replace this module and you will be fine.
Feb 09, 2010 | Whirlpool ET5WSEXKQ / ET5WSEXKT Top...
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
How to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Feb 18, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Icemaker is not working on my whirlpool GS6SHEXNS00side by side refridgerator
Check to make sure the ice maker is not jammed. My refrigerator was only two months old when opposing plastic fingers on the ice maker jammed together. I'm not sure how it happened but I carefully straightened the bent finger and the ice machine started to work again.
PokeMeister
Jul 26, 2008 | Whirlpool ED2FHEXN Side by Side...
Icemaker stopped making ice
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
May 24, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker not making ice
How old is the unit? These things are actually very delicate, a power surge will take them out. The devil to service them is that they are difficult to diagnose out of the freezer. If you see a burnt or melted spot on the timer wheel, it's done. The timer wheel is behind the square plastic cover, which pulls off the front. That front part, which I think is called the module, is replaceable. On the two units I have worked on, that was where the problem was.
May 05, 2008 | Whirlpool ED0GTQXMQ Side by Side...
I have a Whirlpool Gold side by side frige Model # GDYHA Ice maker stopped working tried to troubleshoot it but still does not work...Have any idea how to fix it. Thanks
THE ICE MAKER CYCLES WHEN THE INTERNAL THERMOSTAT REACHES 10 DEGREES. IF THE FREEZER IS WARMER THAN 10 DEGREES, FIND THE REASON FOR THE WARMING TREND.
CHECK THE ICE MAKER TO SEE IF IT HAS ICE OR WATER IN IT. IF NOT, CHECK THE FILL TUBE TO SEE IF IT IS FROZEN. REMOVE THE ICE FROM THE FILL TUBE IF IT IS FROZEN OFF. IF THE FILL TUBE IS O.K., CHECK THE WATER VALVE ON THE BACK OF THE REFRIGERATOR TO SEE IF IT HAS GOOD WATER PRESSURE COMING TO IT.
ALSO, CHECK THE FRONT OF THE ICE MAKER BEHIND THE PLASTIC COVER. THE WHITE GEAR IS SUPPOSE TO BE HELD IN PLACE WITH TWO TABS IN THE CENTER OF THE GEAR. IF ONE IS BROKEN OR BENT INWARD, THE GEAR ISN'T MAKING CONTACT WITH THE CIRCUIT BEHIND IT. THE CONTROL MODULE WOULD NEED TO BE REPLACED. OR IT MAY BE JUST AS WELL TO REPLACE THE ENTIRE ICE MAKER.
Mar 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Thanks but, I knew this part was working
Iceman, here's a little deal I wrote, check it out, Catriver
Diagnosing Whirlpool and Kenmore s/s with ice bucket in door.
Upon opening of the door the emitter light should flash 2 times with a pause repeatedly. Then when holding the left side emitter flap down the light should stay on steady. If you have this scenerio, your emitter boards are working properly. If you do not, check the following:
First thing to check is the position of the ejector blades on the ice maker. They should be at rest in the 2:00 postion. If you find them in any other position than that, it’s more than likely a module failure. The module is located on the front of the ice maker. To remove the ice maker from it’s mount, remove the quarter inch screw holding the harness cover on the lower right side. Remove the harness cover. Now the ice maker will pull straight out. Unplug the harness. The module is held in by 3 screws in the corners and will pull off.
Often, the black fill tube located on the ceiling will freeze causing a no water fill. This can be fixed by thawing with a hair dryer or some sort of baster using hot water.
To jump start the ice maker do the following: Unplug the refrigerator. With the ice maker out of it’s mount but connected to the harness use a insulated jumper wire stripped a quarter inch on each end and place the jumper in the holes marked T & H on the module. Place the ice maker with the jumper in, on the shelf with enough clearance to close the freezer door. Close the freezer door. Plug the refrigerator back in and wait 50 seconds. Now open the door and see if the module is rotating. If so remove the jumper, put the cover back on the module and place the ice maker back in its mount. The water fill should take place when the ejector blades are at the 12:00 position. Note that on some models, after you have done the aforementioned proceedure you have to press and release the light switch 3 times for the module to start.
Dec 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
353 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
