Question about Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
Heater turns on and off
Pilot light was on but the heater would not turn on. had service tech. visit, but was not home at the time. the heater now turns on, but it only stays on for a little while and then turns off. cannot call service tech until monday, but would turning the temp. down cause this problem?
Thanks,
Kim
    Champion:
  • 246 Answers
Not rectifid the flame let me guss jandy LJ need new parts the ignator kit and the rectification kit if LJ
Posted on Sep 13, 2009
Need to purge air from gas line for water heater
It could be that the gap for the igniter is too big Try lighting it manually There should not be that much air in the line .
Jun 14, 2017 | Rheem Water Heaters
I have a h150 pool heater. when you light the pilot it would go on but it would turn off once the valve was in the on position. service tech came to the house and changed the thermocouple. it finally...
Having multiple issues with a milli-volt heater very common and can be expensive to fix at times. Start by cleaning EVERY connection in the safety circuit and the pilot circuit. If you have a milli-volt meter that would help a lot.
Jul 13, 2017 | Hayward H Series Millivolt 250,000 Btu...
I just turned the heater on for the first time, so excuse me for my ignorance, but when I turn the heater off, should the flame turn off as well? I'm a little worried because I never noticed the flame or...
you are talking about the pilot light that on this heater is all ways on to light the burner when you turn the thermosat up , its safe to leave on there is safety device on the heater if the pilot goes out to shut off the gas , also when you come home you just turn up the stat if you are cold , if you turn this off you will have to relight it every time , there will be air in the line and be a pain to light up,
plus your house will be very cold when you came home after a days work or a night out
Nov 30, 2010 | Williams (5009622) Ceramic Gas Wall...
How do i relight my standing wall heater light, where is it?
There should be a removable panel on the bottom front. Remove this panel and you should see gas valve with two lines going into combustion chamber. The larger of the two will be for burner and the smaller to the pilot light. There may be lighting instructions on the inside of panel,or on front of burner compartment. If not look at gas valve and see if you can see where it is marked off pilot and on. Turn thermostat to lowest setting and gas valve to pilot ,locate pilot light and hold match to it while you depress pilot button . Pilot should light. If it does hold button depressed for 1 to 2 mins. Release pilot button and if pilot stays lit turn valve to on. Turn thermostat up to desired setting and see if burner comes on. If it does you should be done. Put cover back on. If pilot light does not stay lit or burner won't light I Would recommend you call a service tech as there are several things that could be wrong. Hope this helps you.Thanks
Nov 12, 2010 | Montgomery Ward (223600UP) Heater
Pool heater sparks but does not light up
coud be several things, Do you have Gas and is gas toruned on. Is valve on. The Pilot could be dirty and need cleaned. $350+ sounds reallly pricy for a pilot assembly. Call your Gas Company and get an Estimate and a Qualifed Service tech. You may try turning Off the Power to the Heater Unit and turning it back on , and then trying to turn on heater again, So times after several atemps the valve will lock out and the power needs reset on Propane units.
Jun 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Can't light pilot on rudd model urcf 07e24jkr
If your furnace indeed has a pilot, a thermocouple or gas valve is your culpret. Thermocouple is about ten bucks from The Home Cheapo so it is a good inexpensive start. That is the copper stick that the pilot flame hits. Turn off the gas and electric when changing it. If it still won't light then you will need a qualified HVAC tech to replace your gas valve.
Dec 12, 2009 | Heating & Cooling
Ihave a force gas heater that has a problem
Hi, after the heater starts again and warms the home up and shuts down, do you have to turn off the switch to get online every time? I hope they haven't charged you for all of these service calls.I may not have the answer, but It should have a flame sensor on it that may be dirty. It would be next to the pilot with the rod of it in the pilot flame. If it does, clean it with steel wool, no sand paper.See if this takes care of the problem. Let me know so we can find the solution for you, this is crazy coming out and doing nothing to find the problem. Let me know Please!
Sincerely,
Shastalaker7
Nov 25, 2009 | Heating & Cooling
Poilot light is on but furnace will not turn on.
check diverter at pilot chech for lint could be gas valve re-light pilot
Oct 11, 2009 | RTO Home Heating Products 5.5HH240...
Pilot light will not stop on plenty gas will not fire up.
If the pilot lights, but goes out when you try to turn on the main burner, then you most likely need a new regulator. If the pilot will not light at all, even manually, then there is most likely a blockage in the pilot jet. You will need to take apart the head to clear the blockage. If you are not comfortable with this, here a service tech.
Sep 05, 2009 | Sunglo Black Portable Liquid Propane Gas...
Pilot light goes out every time heater reaches & missing knob
the thermo couple thing that pilot heats up is not staying in flame if knob is broke you may be able to heatup manualy to get gas valve to open some will wome wont
Jun 10, 2009 | Heating & Cooling
Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
225 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
