Question about GE JE1540 Microwave Oven
GE Profile Microwave Keypad
I have had my GE Profile Microwave for only 13 months and the keypad does not work at all. I called customer service and the tech came and said the part is $900! Are they kidding me! I just bought this. What a piece of ****! I knew I should have purchased the Thermadore equipment. I am going to complain to customer service. I refuse to pay this. Has anyone has had problems like this with fairly new microwave from GE?
  • William Miller
    William Miller May 11, 2010
    Customer service is not typically staffed by technicians, so they probably don't understand what is really needed to fix it. NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly with your full model number form the tag in / on the unit and symptoms for more FREE help & do-it-yourself advice. Please include this URL, too:http://www.fixya.com/support/t2931612-ge...
    William E. Miller
    prototech@usa.net http://www.microwavedisplay.com
I have the exact same problem at exactly 12 moths and 22 days. Just out of warranty, wouldn't you know. Sears says it will be $150 just to show up. What a piece of junk.
Posted on Oct 16, 2009
My ge is Microwave beeping and says keypad short may need service
PCM/Smart board (comes with the keypad), If it is less that 30 days beyound the 12 month warranty call GE and ask for a "good will concession" ... 1800-GECARES
Apr 28, 2014 | GE XL1800 1100 Watts Microwave Oven
GE microwave says "shorted keypad", what causes this? How can I fix it?
a shorted keypad is when the tiny capacitors across the keypad,become shorted,the only fix is to replace the membrane keypad........no fix
Dec 14, 2012 | GE Profile PVM1970SRSS 1.9 Cu. Ft....
Touchpad does not work any longer. Is there something to check, or is this a service call.
You have a failing membrane keypad.
On some models you can order just the membrane keypad. It's more work, but it's cheaper.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, you have to order the control panel frame which comes with a new keypad already on it. This costs more, but it's an easy DIY job.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Some connectors have a lock.
You can order GE parts from the Pros here.
Nov 30, 2012 | GE Profile : JVM3670BFBB 36" Over the...
My GE Profile Spacemaker XL 1800 (JVM1870WF06) microwave is not working. The fan starts, the keypad works but the turntable is not turning and the food is not getting heated. Please help. Can I buy a part...
The problem is more than likely one or two bad door switches, but you will need to call for service if you decide to fix this, to buy new may be a better option since prices have come down and you get a one year warranty.
May 08, 2012 | GE Microwave Ovens
My microwave GE Profile Spacemaker 2.0 keypad does not work, I unplugged it and reconnected it and it works at times for a while then it stops again.
To help you further, I would need your brand and the full model number from the tag on the unit.
It's best to repost a new message to FixYa or contact me directly.
Dec 31, 2010 | GE Profile Spacemaker Over-the-Range...
GE Profile Microwave Model JEM31SA, intermittent problem with keypad going dead after cooking. Have to go out and flip breaker to reset. It prompts for clock set info and functions normally again after...
You're going to have to replace the keypad module and possible the control module (do the keypad first). You can try contacting these folks: http://www.appliancepartspros.com/search.aspx?model=jem31sa%20001%20ge%20spacemaker%20microwave
And see if they have a keypad for your unit. Depending on the age of your microwave, you may be best off replacing the whole microwave.
Aug 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Numbers 4,7,8,9,0 and Beverage on pad do not work. Others do work, do I have to replace the oven? (Spacesaver JVM1440WH04) Over stove oven installed in Feb 2007, in use 4 months each year. This problem...
No you can have the keypad replaced. It may be something as simple as a dis-lodged keypad ribbon connection where it mates to the control panel recepticle. If you look here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1440 there are several model numbers it seems you did not provide all of the numbers but the keypad is the same. The key panel here is $75.00 http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1440 Then you add a service call or shop charge your looking at well over a $100.00 repair. Your call on how to proceed. Good luck.
Jan 12, 2010 | GE JVM1440 Microwave Oven
I own a GE over the range microwave, model #HVM1540DN1BB The touch panel doesn't work at all. I can't even set the clock. I even umplugged it for a couple of DAYS, and still nothing. I called GE, and they...
This model from GE is a ****..they replaced the keypad once wihtin first 2 months..now just after warranty..same issue again. Never buy GE products. The replacement key bad is $44+shipping in many onlne parts store..I am giving it one more try..next time this happens..GE will be out my door!!
Dec 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My keypad is also dead.
No, but as with all electronic items faulty ones typically show themselves up during the first few months of use.
You've probably just been one of the unlucky ones.
Sep 08, 2009 | GE Spacemaker JVM1540 Microwave Oven
Microwave dead even though power works
It sounds like the magnetron overheated and opened the thermal fuse on the magnetron.
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
The magnetron will have a 5 to 9 year warranty. Your manual will tell you that.
You can download GE owner's manuals and installation instructions here.
If needed, GE may send you a replacement magnetron. GE Customer Service is here.
Dec 04, 2008 | Microwave Ovens
Microwave Ovens Logo
590 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
