Question about Akai PT4298HD Rear Projection Television
Red and green projection is upside down
I have an Akai PT4299HD rear projection tv. I replaced the oil in the bulbs and the power board. Now i have a problem with my display. the blue is good but the green and red are projected upside down. Any ideas?
  • Akai Master
  • 3,459 Answers
You put the lens or tube on backawards...
Posted on Sep 13, 2009
I have an akai 55" projection tv and the top and bottom of the picture is bowed with green and red colors which makes it look like a 3-D movie. how can i fix this problem and what will it cost to fix and...
The tv have a problems known as a convergence problems,it dead.Yes,try website like Tvrepairworld.com to buy a whole rebuild convergence board for the replacement.The Akai/Samsung use the same tv convergence board.The board around $200.
Sep 09, 2010 | Akai PT5598HD 55" Rear Projection...
Red green wavy color on top of picture with distorted faces and bottom of picture seems o.k.
Ur convergence is dead.The Convergence board must repair or replaced.Samsung/Akai use the same convergence board.Try website Tv repair world.com.Buy the whole board replaced it the best.
Jan 15, 2010 | Akai PT5598HD 55" Rear Projection...
Akai pt4299hd
Try recycling the power, Unplugg the power cord wait at least 2 mins ant then plug back in. Some times by turning it off an on rapidly will cause the microprocessor to lock up or freeze. Much like a computer does when you have to reboot it..
Sep 25, 2009 | Akai PT4298HD Rear Projection Television
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
Akai/Samsung PT4299HD Convergence Problem
Ck 3 low ohm resistors 2.7 ohms they will be on same board as ICs.
Feb 13, 2009 | Akai PT4298HD Rear Projection Television
My akai pt4299hd tv stopped working. it will not come on.
On AC power supply board there is 2 thyrisitor poor solder ,I have repair several of these with that problem.
Nov 20, 2008 | Akai PT4799HD Rear Projection Television
Akai hd projection tv pt4299hd won't turn on
Sounds like a power supply issue. Does the power indicator light up? Can you hear a click when the power button is pressed?
May 31, 2008 | Akai PT4298HD Rear Projection Television
Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
Akai PT4298HD Rear Projection Television Logo
168 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
