Question about Kenmore 63942 Dryer
The Kenmore dryer worked for one load, pushed start button for next load and it makes a hum noise at the start button and won't start
  • Kenmore Master
  • 8,220 Answers
This is probably the motor going bad. The sensors wont cause this to happen. The start switch either, replacing all the sensors in the world wont make the motor be good again. But their is something you can do to try and make the motor last a while longer,their isn't any holes to oil the dryer motor so you must make some,using a 1/8th inch drill bit make a hole in either end of the motor where the bearings are (taking care not to hit the shaft), then add some hi temp oil such as zoom-oil, (dont use WD-40) and work the motor free as you can by hand. If this frees up the motor it may go a while longer. Also oil the rollers and check the slides to make sure they are not pinching and stalling the motor. If the motor can't reach top speed it will get hot,overload and stop.
Posted on Sep 12, 2009
2 Suggested Answers
Jahn27
  • 1554 Answers
SOURCE: 110.64872400 kenmore dryer 80 series.
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Posted on Aug 15, 2011
Kenmore 70 series electic dryer wont start make humming noise
your motor likely has a start-up capacitor to start the motor, it will be a cylindrical unit with 2 wires going to it, bring this with you to your local appliance repair depot and ask for a replacement with the same numbers on it, re-install as the old unit was uninstalled, this will likely the problem
Apr 15, 2012 | Kenmore Dryers
Our Kenmore clothes dryer is not starting.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Mar 15, 2009 | Kenmore 84052 Dryer
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
DRYER WON'T START WHEN START BUTTON IS PUSHED
if its a humming than a click,,wont start for a few mintues,,than the hum again ,,your motor is shot,,,replace,,onthejob
Jan 05, 2009 | Kenmore 62872 Electric Dryer
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Oct 07, 2008 | Kenmore 63942 Dryer
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Kenmore dryer hums but will not start
If it just hums the motor is probably on it's way out. If it makes a growling noise, it's the motor.
Nov 04, 2007 | Dryers
Dryer will not start
If if "hums" like the motors is working you drive belt may have broken. If it makes no noise other than the click it could be a blown thermal fuse (there can be several) or a seized motor.
Jun 15, 2007 | Kenmore 64722 Electric Dryer
Kenmore 63942 Dryer Logo
59 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
