Question about Kenmore Washing Machines
Model 72981600 from 1978\r\nsuddenly won't pump
Model 72981600 from 1978 suddenly won't pump out water.
washes and spins ok. Any ideas?
    President:
  • Kenmore Master
  • 1,922 Answers
Is this make/model a belt drive unit? the pump could have a blockage from something washed previously with a lot of knapp fibres in it like an area rug, pump shaft or impeller could be bad, remove top and front cover to access belt if this is a belt driven unit,then you can inspect the pump unit also
Posted on Sep 12, 2009
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
Wont final spin
sorry have not come across that model its not within my expertise
Nov 14, 2011 | Washing Machines
LG dishwasher model LDF6920WW 1 1/2 years old approximately. Suddenly stops a minute or so into cycle (it drains remaining water and fills with new water then get LE error). When I open the door at the...
The manufacturer has assigned this error or fault code to indicate a problem with the water circulation pump motor. Turn the appliance off for 30 minutes to allow it to cool. Then, restart the cycle. If the error code returns check the wiring to the pump motor. Also, if the wash impeller is broken this error can appear. If the impeller and wire harness check out, and the code keeps returning, you will probably need to replace the pump and motor assembly.
Aug 06, 2017 | Dishwashers
Hi, we have a Beko 6kg AA WMA652S and its not spinning. It won't spin during wash or at the end. Any idea what's wrong?
the problem might be the panel or it might be the washer pump that brings water out after wash
Jul 07, 2011 | Washing Machines
The washer quit spinning, I can get it to work in wash mode but when it comes time to spin out it won't do anything,
themobilian_2472.jpgIf it won't puthemobilian_2473.jpgmp out the water or spin that is the lid switch. If it pumps out the water but does not spin then that is the motor coupling. How to get into the machine.
How it works: 4 videos and a service manual
Jun 21, 2011 | Whirlpool LSR6334LQ Top Load Washer
The spinning thing won't spin all of a sudden. The washer is making a lot of noise and will drain but won't spin. How do you take the back off?
The motor has a double pole on it. The pump is driven on one side of the motor. The basket is driven on the other end of the motor. So if the water is pumped out then the lid switch is fine. What you have is a broken drive coupler. Usually breaks on a heavy load like rugs or quilts. Low water on a heavy load can break it too. Or simply old age.
Video:
Repair manual and more photos HERE
May 07, 2011 | Whirlpool LSN2000LW Washer
What does f-5 mean when flashing at me and won,t let me have my washing out the machine also washing really hot after a fast spin programme
if water is in drum then door wont open,drop drain hose to floor level into bucket to drain manually, then check filter or pump is it running ok if not is it stuck some thing in it , hot wash is cold water inlet ok or is this due to again faulty pump ...
Jun 25, 2010 | Hotpoint Aquarius WD640 Front Load...
Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Washing Machines
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
13 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
