Question about Gateway FPD2485W Television
Monitor will not power on
Had it plugged into a UPS and worked great for about 2 years. It now is "dead" Tried plugging into a new outlet, but this did not bring it back to life. This is sad because the picture was great.
    Novelist:
  • 159 Answers
If you get power to the controlsand you don’t have the startup sound or see the gateway logo when you plug itin, the main board may be bad.
If your picture was pinkish ordark at the top or bottom when it was working then you may have 1 or more ofthe bulbs failing.
If you have the startup sound andsee the gateway logo and the screen just flashes and the power buttons staylit, then it sounds like probably the inverter may have went.
Takethe screws out of the bottom rear edge (these hold the front trim), and the 4big black ones at the middle of the back that hold the stand bracket.
Thetrim then unsnaps. {Be aware of the small ribbon to the power button board onthe right edge}Start at the bottom and release the trim (pulling up the trim onthe screen side usually starts it off), then work your way up each side bottomto top ((a pocket knife or thin putty knife even a credit card, will helprelease the catches as you work your way up)
Thenunsnap the top edge (rocking it while lifting helps)
Disconnectthe ribbon at the power button board, (Tiny latch lifts up on a hinge andribbon slides out)
Oncetrim is off, remove the 4 corner screws that hold the screen in. Then thescreen will lift out with all the guts. You may have to pry up on a corner witha screw driver to get it started.
Theinverter is under the medium size metal case.
Thepower board and main board are under the large cover.
You’llthen have to remove a bunch of screws including the usb board ones and unplugthe bulbs and wire to the screen
thenthe power board and control board is under the center area under the metalcover
Shoutif you need more info.
Ifyou email me a good picture of the boards to bammbamm@ptd.net , I may be able to get a better ideaif it is the inverter from a visual.
Thanks Fran
Posted on Mar 07, 2010
The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    APC Back-UPS ES500. Battery is new replacement UB1280, and battery has charge and runs fine if unit not plugged in. However, if unit is plugged in to power back-up side outlets in unit don't work.
    there are 2 parts of a UPS .
    the charge side
    and (battery is obvious)
    the inverter side.
    if the charger fails, all is lost. (are the batteries in backwards?)
    if the charger works (volt meter tells you that)
    then the inverter is bad. (this unit is not full time UPS , but part time, this means it switches over to inverter at power fail.
    (on full time sys. inverter runs full time, like the name states)
    the unit, you mean the load right.?
    the UPS side plugged into a load. and the load is now dead.
    the Backup plugs should work if the mains are hot.
    if you kill mains, the inverter will fire off, (hear the squeal?)
    and give you 500 watts for some minutes, sucking the batteries dry. (see load run time curves)
    I used to do service on HUGE UPS systems, some with 100s of batteries. 3 to 5kw too.
    on ours there is a port on the rear , we connect and can
    check everything "BEST brand" even charge voltage.
    did you look on APC site for special software and connections?
    the manual does cover trouble shooting, ever read that?
    RTM? start there, its online, for sure.
    Oct 03, 2013 | APC Back-UPS® CS 500 UPS System
    My moniter is no light(m.no 715b)
    Check out the monitor power sources first like loosed A/C cords plugs in,dead plugs in outlets.Tried reset the monitor back to factory setting by unplug replug back in like an hour later.Non of these solutions works,than your monitor power supply board is dead that the board where the A/c plug into.Try website like EBay.com to buy a new refurbish power supply board for the replacement.
    Jan 14, 2013 | Computers & Internet
    I have a omni 1000 lcd. power went off when it came on the thing won't work. When I bypass the unit and plug my TV into the power out let the TV works . Have any idea what could be going on ,is the...
    The UPS is either off, has a dead battery or is dead. Does the UPS power anything at the surge only outlets? If it doesn't, it's off or dead. Turn it on and check again.
    The Omni 100 VS does not have a user-replaceable battery or other parts. If the battery or UPS is dead, replace it.
    I hope this helps.
    (when the UPS is off but connected to power, the battery should charge.)
    Jun 28, 2011 | Tripp Lite (OMNI1000LCD) UPS System
    I need to conect to my UPS via my computer . Not sure who to do this?
    Is easy, here is how to do it:
    1. Plug your computer in your UPS
    2. Plug the UPS to an outlet/plug
    3. Start the UPS
    4. And done
    If you want your monitor conected to the UPS make sure it has 2 spacest to plug them in or use an extension cord with 2 outlets or more.
    Hope it was usefull
    May 06, 2011 | MGE UPS Pulsar Ellipse Premium 500 UPS...
    Continues beeping
    did you leave it plugged in to let it charge? ups's will beep continuosly till they are charged, if it has dead battery packs inside, it will continue to beep because there is no battery charge to support its job. leave it plugged in for 2 hours. if it doesnot stop beeping, toss it and get a new ups
    Jun 04, 2010 | CyberPower 575SL (CPS575SL) UPS System
    I work for the STATE Dept I have a unit Without the External battery pack. I get NO AC Volts out of the plugs in the rear ??????
    It is a little obvious but I have to say it. Make sure the wall outlet it is plugged into is live and the UPS' power button is on. Now for the (slightly) less obvious:
    The battery is dead. Even high-end UPS batteries are only good for 3-5 years depending on your evironment and the UPS' sensitivity level. I budged for battery replacement every 5-years whether they die or not. Better safe than sorry.
    Finally, the UPS hardware is dead. It does happen. I have seen them die after only a couple of years. Overheating is usually the culprit.
    If this doesn't narrow it down pick up the phone and get the manufacturer on the line. Make sure you have your model and serial number ready because they will ask.
    If this helps please vote for my solution.
    Aug 17, 2009 | MGE UPS Pulsar EX15 Rack (89015R) UPS...
    Sceptre 17" lcd monitor is plugged in but no power please help!!
    Let's rule out the obvious first. It may be that a power surge has blown out the power supply on the monitor but let's check the outlet as well. Plug a lamp into the same outlet that the monitor is plugged into. If the lamp works, the monitor may have gotten zapped. If it doesn't work, plug the monitor into a known working outlet. If it turns on, the outlet is the problem. If it doesn't, your power supply may have gotten zapped in a power surge. This is assuming you don't have it all plugged into a power strip. Perchance would you be using a UPS (uninterruptable power supply)? If not, it's a good idea to purchase one for the next such occurence. You really don't need a heavy duty one. Just one that will give you about 5 minutes or so to power down after you have saved your work so nothing is lost. They also protect against such spikes and surges. Let me know what you find out.
    Feb 15, 2009 | Sceptre 17" LCD Monitor
    'Battery' outlet dead.
    Hi There, Its definately the battery. The batteries can be replaced.
    Nov 05, 2008 | CyberPower OfficePower 650SL UPS System
    Battery/Surge outlets not working...
    Sounds like the UPS battery is bad, or the circuit break on it has gone. Is there a reset button on the UPS? Do you have the program that came with the UPS to check the battery status, those programs typically let you run a test on it also.
    Jan 29, 2008 | CyberPower OfficePower 825AVR UPS System
    Gateway FPD2485W Television Logo
    379 people viewed this question
    Top Gateway Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
