Activation key for quad registry - Computers & Internet
  • Raman Khowal
    Raman Khowal May 11, 2010
    please mention version/year
    Guru:
  • 402 Answers
U can download whole software with key form miniova.org
Thanks for using fixya..
Posted on Sep 14, 2009
Function keys doesn't work
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Nov 11, 2012 | Compaq Keyboard
Tip
Change the volume licensing product key on a Windows XP SP1-Based Computer
Because of changes in Windows XP Service Pack 1 (SP1), Windows XP-based computers that use a leaked product key that is known to be available to the general public may not be able to install SP1 or automatically obtain updates from the Windows Update Web site. For an easy and quick method of obtaining your own CD Key please read Quickly Retrieve Windows CD Key
If you have only a few volume licensing product keys to change, you can use the Activation Wizard.
Warning!
This document contains instructions for editing the registry. If you make any error while editing the registry, you can potentially cause Windows to fail or be unable to boot, requiring you to reinstall Windows. Edit the registry at your own risk. Always back up the registry before making any changes. If you do not feel comfortable editing the registry, do not attempt these instructions. Instead, seek the help of a trained computer specialist.
Note: Microsoft recommends that you run System Restore to create a new restore point before you complete the following steps:
  1. Click Start, and then click Run.
  2. In the Open box, type Regedit, and then click OK.
  3. In the left pane, locate and then click the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current Version\WPAEvents
  4. In the right pane, right-click OOBETimer, and then click Modify.
  5. Change at least one digit of this value to deactivate Windows.
  6. Click Start, and then click Run.
  7. In the Open box, type the following command, and then click OK. %systemroot%\system32\oobe\msoobe.exe /a
  8. Click Yes, I want to telephone a customer service representative to activate Windows, and then click Next.
  9. Click Change Product key.
  10. Type the new product key in the New key boxes, and then click Update. If you are returned to the previous window, click Remind me later, and then restart the computer.
  11. Repeat steps 6 and 7 to verify that Windows is activated. You receive the following message:Windows is already activated. Click OK to exit.
  12. Click OK.
  13. Install SP1 for Windows XP.
If you cannot restart Windows after you install SP1, press F8 when you restart the computer, select Last Known Good Configuration, and then repeat this procedure.
on Apr 25, 2010 | Microsoft Windows XP Professional for PC
Locked keyboard
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
On most laptops there is a function key that will lock the keyboard.
You would need to pres the [Fn] key and the appropriate [F#] key. In mine the combination
would be [Fn+F1] keys. If you shut down to re-activate the keyboard you will loose whatever you are working on.
hope this helps
Nov 10, 2012 | Computers & Internet
When I type on my keyboard on my computer numbers are popping up instead of letters
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times.
Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
hope this helps
Try this. Press the Start key + R. type osk in that box and hit enter On this keyboard, try toggling numlock scrolllock and capslock a few times
or
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Nov 08, 2012 | Computers & Internet
CAP LOCK STUCK
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Oct 09, 2012 | Computers & Internet
How to disconnect key left in ignition chimes
The key in chime is activated by the key sense wire at the ignition switch. You may be able to power this down by IOD fuse but, it disconnects power to some other things as well, like keyless entry, etc.
Sep 02, 2012 | Quad Dodge Ram 2009-2012 Quad/crew Cab...
My laptop keyboard is locked
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Jul 15, 2012 | Toshiba Satellite A135-S7403, A135-S7404,...
I dont have a registry key to activate my registry reviver pc clean,pls send me some key licensed,thank you
download registry reviver from the below given link and you wont need the key..
http://www.filesonic.in/file/40148809/Registry_Reviver_1.4.50.rar
Mar 24, 2011 | Computers & Internet
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
