Question about HP Deskjet 2330 InkJet Photo Printer
IT SAYS FREE SUPPORT FOR YOUR PRINTER---WHY WOULD I HAVE TO PAY FOR A SIMPLE QUESTION .HOW DO I GET VRID OF 54 THINGS IN MY QUE--WHATEVER THAT IS
  • 20 Answers
Go to start >> click on run>>type "cmd" without quotes in box
command prompt opens type>
net stop spooler
and hit enter
net start spooler
and hit enter
go to the printer icon >> Right click>> Cancel ALL documnts
select yes
disconnect the usb
reconnect it back
and print
Posted on Sep 14, 2009
Error 54.16 laserjat 3600
Hi
54.XX ERROR An error has occurred with one of the tonerlevel
sensors.
XX Description:
1. Que Make sure connector J1020 on the
DC controller is seated Correctly.
2. Replace the DC controller.
Dec 05, 2013 | HEWLETT-PACKARD Hewlett Packard Genuine HP...
Won't print it always says document in queue
This sometimes happens if a print job freezes before, or during the print. I would suggest two things. Open up your print que, which you should be able to access from the bottom right hand side of your screen in your task bar. Right click, and open print que. If there is a print job in the que that says printing, try to right click on the job and cancel it. If this does not work and you have not done so already, restart your computer and your printer! Go back into the que if you have to and if the job is still there, right click and cancel job again. Then, retry printing a something different from your printer. This should solve your problem.
Sep 20, 2011 | Canon Pixma MX420 All-In-One Printer
How can i unlock my blackberry free of charge
ESTE TUTORIAL ES PARA DESBLOQUEAR SU BLACBERRY VIA IMEI
Si quieren que les salga gratis, sigan el tutorial.
La pagina que da el codigo de desbloqueo gratuito es trustedunlock com (http://www.trustedunlock.com)
Ellos lo unico que te piden es que les promociones el sitio web indicando un simple comentario con el enlace a trustedunlock.com. La promocion tiene que ser con un simple comentario (obviamente despues de tu posteo) en algun sitio web, foro, blog o youtube (eso si en facebook o twitter no sirve). (como firma en algun lado).
Luego entras a aqui (http://www.trustedunlock.com/2010/08/free-blackberry-unlock-codes.html) y pones un comentario con la siguiente informacion:
Hi, y need the unlock code for my Blackberry.
My POST: (el enlace directo donde pusiste el anuncio con la firma de trustedunlock com.)
IMEI : 355541.53.443442.2
MEP : MEP-09917-001
Pais : Chile
Company : Entel
Modelo : Blackberry 8520
Thanks you, very much.
(tu nombre)
Dec 10, 2010 | RIM Research In Motion Blackberry Storm...
HP 1005 laser printer won't cancel jobs
try turnning it off and then back on.
Oct 15, 2009 | HP LaserJet 1005w Printer
Out of paper clears print que
we need to restart the print spoolers to fix this,
click on start> Run> Type in services.msc. A window will appear with the list of services, there u will find Printer Spooler> Do a Right click on that and Restart it. Do the same thing 2-3 times and then give the command to print multiple documents, to check if the problem is fixed or not. Please let me know the same.
Aug 05, 2009 | HP Photosmart C7280 Laser Printer
Que proplem
There are two things you might be missing.
Both involve getting into the printer que.
It sounds like you already know where that is. If not, open your start menu and go into control panel then click into the printer section and double click the printer that is giving you trouble
once open look at the top of the que window and see if it says Use offline after the printer name. If it does, click on the printer drop down menu. and it will also have a Use offline option which will have a check mark beside it, click it and the printer will go back online.
If this is not the case you may have a document jammed or the print spooler is locked up.
To release/cancel a jammed que, look at the first document in the que and if it has an error of any kind in the status column you can right click on the name of the document and then select cancel from the popup menu. If there's no error message or if that doesn't work your print spooler may be jammed up. This can happen for a host of reasons but is simple enough to check.
close the que and go to your My Computer Icon, Right click it and then select manage, If you're using Vista then a continue window will pop up, select continue. When the management console opens, hit the plus sign/arrow near the bottom for Services and Applications then select the sub category services. A full list of Services will come up on the right hand side. Double click Print Spooler. Now Click stop, this will take a few seconds. Once it's done close the windows, and shut down the computer, once it's off, turn the printer off for 10 seconds and turn it and the computer back on. You will need to go back into the services list, double click print spooler again and make sure it is started.
Now go back into your printer que and make sure it's empty, right clicking and deleting anything that survived the restart. If this works the printer should start working again. If not at worst you may need to uninstall the printer and reinstall it.
Hope this helps FixYa
Chris
Apr 27, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Can´t pay whit my Credit Card Visa Citibank
Por favor llama a la tienda con el nombre y numero de articulo que quieres ordenar para la compra.  Tambien asegurate que los popup blockers esten desactivados, y la seguridad de el initernet este en medium low.
May 25, 2008 | Computers & Internet
LYRA RD2762 & VISTA
SURE,I GET PRETTY FED-UP WITH ALL YOU ON-LINE 'FREE' OFFERS FOR HELP AND AFTER YOU TYPE IN ALL YOUR INFO, YOU SAY, "$9.95" OR $39.95 OR WHATEVER, IT'S A SIMPLE QUESTION REQUIRING A SIMPLE ANSWER. IF I GET DESPERATE ENOUGH TO PAY $ 10 FOR A $ .25 ANSWER, I'LL GET BACK TO YOU, MAYBE.
May 19, 2008 | RCA Audio Players & Recorders
Fan Failure Error 54
1 of 2 things.
You need to clean or replace the fan.
You have to remove the back, right side and top cover to access that fan.It is near the back just behind the fuser module.
It could also be the low voltage power supply fan. Most likely the fuser fan.
Once you remove the fan, there is a label on it, remove the label, There is a rubber plug behind the label, remove the plug and drip some lubricant into the fan. Reassembly and it should be ok.
I would recommend replacing the defective fan though.
Here is a very reliable part source.
https://www.partsdrop.com/store/
If you call ask for Britt and specify the model number and that you need a fuser fan and probably order a Power supply fan, Neither are very expensive.
Have both on hand to be 100 percent sure the problem is resolved, But its a 90 percent fuser fan failure code. It operated in a heated area and can dry out faster.
Mar 27, 2008 | Xerox Phaser 7700 Laser Printer
HP Deskjet 2330 InkJet Photo Printer Logo
Ben Johnson
