Question about Canon PIXMA iP1700 InkJet Photo Printer
The printer grabs a bunch of paper at a time when printing
It works if I put in one paper at a time which is annoying
    Brigadier General:
  • 4,090 Answers
There is some static electricity in some papers that bu=ind them together and will be grabbed several at a time in some instances. Before using paper "Fan" it brrrrp! like a pack of cards to separate the pages. Do this TOP and BOTTOM to release the static, do not use photocopy types of paper
You might also want to consider a better grade of paper, that is static free.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 12, 2009
Initially grabs paper but then rejects it gives an
This seems to be a common problem with a lot of HP printers. Your options are to nurse it along or call HP, have them walk you throught some fixes and then ask for a replacement printer if the fixes don't work. I've found that you can "help" the printer by manually pushing the page and this will often help the printer grab the page and print it. However, if you are printing a lot of pages, it's a huge annoyance. I would call HP and complain. If you are under warranty and they cannot remedy the problem, they will ship you a replacement printer. I did this once, and although the problem is not gone, I only have to "help" the printer every 1 out of 20 pages intead of 15 out of 20. I think HP has some problems with their feeding mechanism on the inkjet printers. Too bad as they used to make the best lasers. Good luck!
Mar 12, 2010 | HP DeskJet 970cse InkJet Printer
Printer paper feed
Hi there
This hapens a lot with different printers, best way is to gave your papers a good shake and keep in a worm place then it may work for you.
All The Best Pineworks
Mar 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Lexmark 5400 series printer won't grab paper for printing
Whenever the printer doesn't pulls the paper please pull the pack of papers, browse through the papers with your finger and put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
Good luck,
GetAFix99
Nov 17, 2009 | Office Equipment & Supplies
Paper pulls to right side and bunches up
Have you tried pulling off the back cover and wipe the rubber wheels off. some times they get dust on them and can cause them to not be able to grab the paper correctly.
Oct 22, 2009 | Canon PIXMA MP190 All-In-One InkJet...
My printer has trouble grabbing the paper from the tray to print. I have to feed it one page at a time with my hand. very annoying.
The pickup rollers need cleaning or there is too much paper in the tray (paper lift spring not strong enough).
Clean the pickup rollers on the tray with Q-Tip / 70% alcohol ... or lens wipes (for glasses and monitor screens).
Use less paper in the tray for now.
Sep 29, 2009 | HP PSC 1510 All-In-One InkJet Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer will not feed paper / message E2 ...cannon pixma mp 160
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
someone replied to my problem, i tried it and its fixed 1st time, for others its taken a few attempts and then worked..
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now. hope this helps, let me know how you get on. Garty
May 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark 5250 printer
Before you put papers in tray it must reshaple make separate each other , to delete the message "off the power " on again to continue printing.
Dec 10, 2007 | Lexmark X5150 All-In-One InkJet Printer
Paper jam in tray 2
the most common problem for a paper jam in tray 2 is that either the pick up rollers and separation pads are worn or that there is something stuck to the rollers that transfer the paper up through to trat 1.(most commonly from if people have been printing on stickers/labels) just eyeball it to see if anything looks to be stook and try wiping it off. DO NOT SCRATCH IT OFF as this will only make things worse!!!
Sep 05, 2007 | Office Equipment & Supplies
Paper does not feed
http://www.fixya.com/support/t148464-paper_not_feed_grabs_right_side The person before you found a cracker or cheesie or something. I just found a marker lid in mine.
Apr 30, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Open Questions:
See all Canon PIXMA iP1700 InkJet Photo Printer Questions
Canon PIXMA iP1700 InkJet Photo Printer Logo
100 people viewed this question
old marine
old marine
