Question about Kenmore Dryers
Dryer doesn't work, but light goes on when open door
  • Kenmore Master
  • 8,220 Answers
T may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 12, 2009
Intermittent heat problems with GE dryer. Drum light associated with problem. Light goes out with door open when centrifugal switch disengages. No heat when this occurs.
this problem is related to the thermal hi-limit cutout and its sister thermal fuse. The two can be bought as a repair kit from repairclinic.com or any appliance repair dealer. Enter your model number and the kit will come up high on the hit list of commonly ordered parts.
25361439-xipalmoknr3fbjmp51kycajc-3-0.jpg These two are in series with each other, and can be jumped out temporarily to verify operation. The silver one will look very much like the picture, the black and white one may be round instead of rectangular (depending on model). They should be swapped as a set. You can ohm them out just like regular fuses to check them.
Jan 09, 2015 | GE DWSR405EBWW Electric Dryer
Dryer continues to run when I open the dryer door.
The door lock is more than just a latch; it is an electrical interlock. From your description it is likely that the interlock has failed
Jun 02, 2013 | Maytag Neptune MCE8000AY Electric Dryer
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Will only work with light amount of clothes in dryer, if medium amount just hums and will not start
With the door open hold in the door switch in and turn the drum while someone hits the start switch, if the dryer starts when you do this you may have a bad motor, what this is doing is "jump starting" your motor winding's. If it doesn't start by doing that then you may have a problem in your belt/idler pulley system.
Apr 21, 2012 | Dryers
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
Sears craftsman 1/2 hp. Door goes up with remote, but when button pushed to go down the light flashes and door doesn't move. If you push the wall mounted switch, the door goes down like normal. Works...
Check the sensors in the doorway. They should both have a small light that is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
The timer on my dryer does not work.
Sounds like the timer needs to be replaced.
May 29, 2009 | Dryers
Dryer wont start
Push on the door switch and make sure the light goes out. When the light goes out, a contact should be made to allow the motor to run. If you can get to the timer, spray a good electronic contact cleaner inside while rotating the dial. While you have the unit open, vacuum out all the lint, and check for loose wires, especially to the door switch.
Apr 14, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
