Question about Dell Inspiron E1505 Notebook
Receiving message wellconhiddenwindow at computer shutdown
    President:
  • 2,976 Answers
It sounds like spyware running in the background. You don't dee it until you shut down. While in msconfig, you can also unselect the things you don't want running in the background. If you can't identify what something is, don't uncheck the box.
Posted on Sep 12, 2009
  • Dell Master
  • 1,183 Answers
"Receiving message wellconhiddenwindow at computer shutdown"
Could you give us more info on the error message.
You can try the following step in the mean time
1. click on start
2. click run
3. type msconfig in the box and click ok
4. click on the startup tab on the top right
5. click on the disable all on the lower bottom
6. click ok or click close
7. Click restart
8. Once you are back on the desktop click on the check box , donnot display this message again
Testimonial: "Worked perfect. Thanks"
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that
Normal behavior. Most of the lcd monitors ( not all) show this message. You can safely turn off the monitor once you shutdown your computer.
Oct 17, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
Tip
Tips & Tricks of Windows Operating System.
1) To check whether your window os is activated or not goto Run -> type slui & the window of activation status will appear.
2) To verify the drivers software is sign up by a valid signature certificate or not just type sigverif in run and follow the wizad (ie press start)
3) Various log windows options functions (Goto run and type the following) :->
i.) shutdown -s (for shutting down of computer)
ii.) shutdown -h (for hibernating computer)
iii.) shutdown -l (for logging off computer)
iv.) shutdown -r (for restarting computer)
v.) shutdown -i (gives graphical interfaces)
vi.) shutdown -p (shutdown without any interfaces of messages to administrator account)
vii.) shutdown -f (shutdown forcefully)
viii.) shutdown -s -m\\computername -t 30 f
on Apr 27, 2010 | Computers & Internet
Computer does not shutdown
You have programs running that aren't shutting down, you can choose the force shutdown option to solve your problem.
Jul 27, 2014 | Computers & Internet
Need screw ring for Deni 3500 Meat Grinder
VITAMIX T&G 2 Blending Station
error message ''shutdown refer to manual''
Magnetic Brushes are removed but , receiving same error message
Nov 22, 2013 | Deni "3500 food grinder commercial 800...
Hello. My Viper 5701 suddenly doesn't start anymore. I press the button on the 2way, I get a red light by the f instead of the usual green start light. The rest of the functions (unlock, lock, alarms) work...
You should also be receiving an error message. If the parking lights flash six times, it relates to the hood shutdown wire(-) or the brake shutdown wire(+). If the parking lights flash seven times, it relates to the neutral safety shutdown. Check the toggle switch under the dash and flip it to the opposite position.
Jan 23, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Acer 5630z power shutdown after 30 to 60 miniutes no power ON only battery LED will go to off for 6 to 8 seconds but no power ON
If the computer is not receiving any power this mean the power supply or your power cable may be faulty,you should try another power cable/ power supply, but if you can see the light indicating the computer is receiving power, this mean the power button may have a fault and need to be changed,if the problem still not solve you should replace the motherboard. Make sure you check the power cable and power supply first.
May 18, 2010 | Computers & Internet
How do I send msg to someone on my wifi network or shutdown --
To send messages from one computer to another download and run this exe on both computers.
http://www.ipmsg.org/index.html.en IP Messenger for Win ver2.06 (103KB)
You can copy to startup and fiddle around with the settings.
Small app which gets the job done.
For shutting down a remote computer
Source: http://www.tweakxp.com/article36917.aspx
Right click on desktop, create new short-cut.
Type shutdown.exe -i
Click next, type in name for your short-cut e.g. shutdown computers
Click finish.
Run the short-cut you just created. Now you can browse the network for computers to shutdown/reboot etc. or just type in the IP/Name of the computer.
You can even broadcast a message, and schedule the shutdown.
NOTE:  You will only be able to shut down computers that you have admin access on!
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 03, 2009 | Belkin N1 Vision Wireless-N Wireless...
Medion MD 7317 flashes colors after computer shutdown
That's what it's supposed to do. This is the monitor test to let you know that the monitor is working but it's not receiving a video signal.
Jun 15, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Shutdown
There could be any number of reasons for this to happen. However, the most likey reason - assuming that it runs for a bit, and then shuts down - is that the heatsink/fan on the CPU is not working, or not installed properly. Once the CPU heats up to a certain point, it will shut down to prevent damage. Perhaps the CPU fan as gone bad, or is completely clogged with dust.
Feb 03, 2008 | Computers & Internet
Dell Inspiron E1505 Notebook Logo
24 people viewed this question
Alun Cox
