Question about Philips 42PF7320A 42 in. Plasma HDTV
I HAVE PHILIPS 42PF7320A/37 IT WANT COME ON, AND IT HAS ERRA CODE 3 THAT MEANS VSCAN PROBLEM. CAN ANYONE HELP, OR GIVE SUGGESTIONS. THANKS BAMAREPAIRMAN
  • 854 Answers
Option 1
Check the connector from the logic board that will be the board under the small signal board. The small signal board have the AV input on it. Check the connector from the logic board to the power supply there should be one connector between those 2 boards. On the power supply side second pin from the left it will say Vs_On if the set has 0 volts the problem is the SSB or the logic board. how to determine that is to Use 2 Jumpers to short J8003 & J8004 on the left edge of the PSU (see figure below).
Use 1 Jumper to short CN2012 on the lower left part of the Logic PCB (this will supply a 100% White signal to the Display).
Plug in the AC to the PSU thru CN8001.
If PDP panel operates with White field screen then problem may be the SSB.
Option 2
Remove back cover.
Plug in power when tv goes into error protection, check power supply and see how many times the led flashes. Right below the flashing green led there is a list 1-13 of error codes and what they mean. Your problem will probably be an error 7or 8 VSET or VSCAN . Which ever error code it gives you VA VSET or VSCAN or whatever it indicates look at the cable connectors to the power supply unplug that connector and the TV will stay on. And there will be your problem.
Posted on Sep 12, 2009
This TV has been in use for 2 years. None of the cables have been changed or removed. Apparently hit a button on the remote that blanked the picture & sound. I have a gray screen with menu options,...
Hi Jim:
You can find an owners manual on the Philips site.
There's also a quick start guide and a firmware update.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7320A/37&scy=us&slg=en
Try the above link, should take you to the site..or you can
do a google search....
owners manual Philips 42PF7320A/42
you should see this link in the list of links...maybe the top one.
42PF7320A/37 Philips flat HDTV 42PF7320A 42" plasma digital cable ...
May 25, 2007 ... Philips flat HDTV 42PF7320A 42" plasma digital cable ready with Pixel Plus ... Manuals & documentation · Leaflet · User manual · Quick start guide. + More Manuals and Documentation ...
Hope this helped.
Dec 27, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320A/37 blinking red light
hello, amigo if the all the caps are godd then you have to replace the power supply board. don't try to fix it this is not an easy task. you are looking at almost $200.00 with tax an shipping. just go to google and type your tv model # and ask for the power supply board or just look for the part# on the board itself. good luck
Jul 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Mar 08, 2009 | Philips Televison & Video
This set is a HD plasma tv and convergence is done differently than the rear projection tv's,rear projection tv's have convergence Ic's and you can adjust the color but not on this unit.
Nov 23, 2008 | Televison & Video
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42 inch plasma 42pf7320a/37
My TV this with this . What can be ?
philips-42-inch-plasma-42pf7320a-37-nhe5gy2xupfnvv1disgbrgaq-1-2.jpg Help me please
Nov 13, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Part # referring to
the ssb is located on bottom middle when looking at back of tv with back cover off. has inputs and tuner on it. part number is 313926727671 and is buyable through vancebaldwin.com. when replacing a small signal board and you don't have picture you need to enter 062598 menu (diversity code which is 3 digit numeric code located on option code sticker on panle itself). hope this helps dan
Aug 22, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7220A/37 Chassis Number BP2.3U
I think its something on the picture frame board or on the line output board. I would sway to the line output simply because I think but not sure that error code is linked to the line output stage plus when you unplugged the cable the voltage seems within parameters. Good luck.
Aug 04, 2008 | Philips 42PF7220A 42 in. Plasma Television
REPAIR NEEDED
sounds like the Y boards.best to replace all 3 at same time main and buffer upper and lower
http://www.shopjimmy.com/searchparts.cfm?make=Philips
Jul 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42pf7320a/37 dead
Error 7 is a power related problem. This is what u need to do.
Remove back cover.
May 06, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Philips 42PF7320A 42 in. Plasma HDTV Logo
254 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
