Question about Garden
The cord on my saw wont pull. not even a little bit. the cord mechanism itself is working fine but when on the unit wont pull. i was using the saw and the chainbrake triggered. the saw shutdown. i reset the brake and the cord would not pull. the saw is new. the fuel mix is correct. any ideas
  • dontbother10
    dontbother10 May 11, 2010
    Make, model, and serial numbers always help! Remove the plug and try it (leave ignition off). If it won't turn with plug out take it back. Lou
  • 31 Answers
If your sure it the chain brake then try to reset. But you could have locked up the motor
Posted on Sep 13, 2009
My son's ipod will charge just fine on computer, but will not charge on a car charger. What's wrong?
I'm not quite certain what you mean by "car charger",
If you mean a battery charger which is used to charge a 6 or 12 volt automotive battery, your device's protection circuits will read an incorrect amperage, and refuse the connection.
If you mean the device will not charge by connecting the cord to the cigarette lighter outlet (or other 12Volt outlets), you should check that the cords' side contacts are coming out as they should, these often fail to engage because the mechanism is a bit wimpy.
You can use the tip of a pen to slide under the contacts and gently pry then out.
then try re-connecting the device, and see if it will charge.
If it is still not charging, be certain the front contact is fully extended, if not, grasp it gently with a pair of needle nosed pliers, and pull it (again gently is the operative term), if it comes out 1/8th to 1/4 inch.
Plug it in and it should work.
Be certain and that the tip is clean (a light touch with fine sandpaper, (or a little scrape with your knife) should do just fine.
If you still are not getting the charge, try using the cord which does work on the other device, the problem could be in the cord itself.
If you have a multimeter check the end of the cord which plugs into the device for proper voltage, the control circuits in the cord itself may be malfunctioning, in which case a new cord it needed.
I hope I've been of help, if not please feel free to try for another answer.
Good Luck!
John (Sparky)
Oct 06, 2014 | Apple 160 GB iPod Classic (Silver) +...
How do i pull out the short cord?
I just now took a flat blade screwdriver, turned the coffee mill (Mr. Coffee) upside down, pushed the little bit of cord back in until I saw the cord wrapped around the base. Gently lifted it over the base and kept hand unwrapping it. Worked fine, will not retract, but this is not a problem for me. Hope this helps.
Jun 14, 2014 | Mr. Coffee Coffee Makers & Espresso...
My Maxtra 30cc pole pruner starts ok and runs fine for about 5 mins. The revs then begin to race and the engine cuts out
I have seen this issue before, having trouble remembering the fix though. Is there any more info you can give me about the problem?
Apr 14, 2013 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
I am having trouble installing the blade on my 1587vs jigsaw.
Please consult the online manual for your saw here, and review this article about changing the blade.
All I can say is, You're not the only one, Thank God they finally changed the design of the blade change mechanism, How could it have taken that long for a bunch of German engineers to figure that one out, and you have my sympathy for owning one of those that use neither a screwdriver nor the new quick release mechanism.
Realise to begin with that the blade goes in and slips out in a position about 45 - 90 degrees away from the position it's in when cutting. In other words, the teeth must be turned somewhat to the side of the saw to allow the blade to slip free. Before that can happen, however, you must use that ridiculous handle mechanism to loosen the lock screw that holds the blade in place. First set the orbital selection switch to III or max orbit position. This will give you a little more flex when pulling the blade free. You might also pull the blade out to a more downward position if it's up inside the saw quite a bit. Pull up on the handle as shown in the instructions and rotate counterclockwise (looking down at the top of the saw) to loosen the blade, being careful not to pull up on the handle too much when it is exactly 180 degrees from the home position, or it will come off in your hand. That is the position to reinsert it in when it comes off, then turn it a little to the side to pull up again. I don't have much use for the push upward and pull downwards advice they give, regarding the tabs on the blade itself. It seems to me they could have figured out a way to keep the handle on the saw while you pull up on it to loosen and tighten the blade in place, but I guess with patience you can get it back in and tightened up again.turning what should be a thirty second blade change into a frustrating ordeal. The older model used a special long shank flat head screwdrive, which worked fine, but everyone would lose the screwdriver or forget to bring it to the jobsite, and without it you couldn't change the blade in that one either. Once you get the blade in they work great!
Anyway, know you're not alone when you curse Bosch, and someday you can replace that little pain for an upgraded model that has a 3 point support mechanism and much better blade change mechanism, or you could go all out and buy a Festo jigsaw, that you would love for the rest of your days...
Sorry for the rant. I hope that helps. I see that you wrote about a month ago, so hopefully you managed to cut your wood by now.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 22, 2011 | Bosch Saws
The saw was working fine. I shut it off. When I attempted to pull the cord to start it again, the cord would not retract. I removed the cover, disassembled everything related to the cord. Made sure the...
Many of these small saws have what is reffered to as an e start, the section that engages to the flywhell is seperate to the rope pulley, and is joined via a round coil spring, the idea is to soften out the compression and help to spin the engine over when cranking, one end of the spring fits into the outer flyheel engagment pinion, the other ends fits into a hole in the starter cord pulley, it does not fit into the main recoil spring, the securing screw for the assembly is a shoulder screw the idea is not to pinch the rewind mechanism when tightened, as this only screws into plastic it is very easy to over tighted and make the pulley post swell and stop the pulley rotating on the shaft, you may now need to leave the screw just a little slacker, the black plate under the starter is a conductor plate, this helps blow the cold air from the flywheel over the cylinder, this plate should always be there. When assembling the starter on the saw, keep pulling the rope as the cover goes on, this will ensure the pinion engages properly with the flywheel pawls.
Feb 19, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hoover UH70120 WindTunnel TSeries problems with the cord. im a tech savy guy and have been trying to fix a cord after it was pulled to far out and now wont auto retract, but just cant find a way to pull...
You will probably have to replace the cord winding mechanism. I have never had any luck trying to repair one. Cord retracters are great when they work but it seems like they always go bad before too long. On many units you can't even replace the cord if you get a bad spot in it, you have to buy a new cord reel which can get expensive.
Jul 21, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
Pull cord difficult to pull..removed from saw it works fine..with spark plug installed hard to pull ..with plug removed (of course there is no compression) ,the pull cord pulls easily..saw worked greatall...
Make sure someone hasn't run this saw without the oil in the fuel mixture. It is possible it is dry and some galling is happening. Or - if this saw is equipped with a compression bleeder (for easier starting), this could be not functioning and you're pulling through the normal compression (which can be a bit feisty!). Check for misalignment of some type having to do with the pull starter - check that the cord spool isn't rubbing on the housing when you pull. Good luck.
Nov 30, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
It won't start.
Prime away... on a chainsaw it does NOT squirt fuel into carb. It draws fuel from tank, through carb, and returns it to tank.
Using the choke however will flood it in a second once it has fired. with a good fuel supply, 99.5 % of chainsaw won't start problems are flooded. Lou
Nov 15, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Will not start - brand new
i bought a new dirtbike as a kid n same thing.it turned out ,it needed to be a synthedic oil in the mix.try seeing for spark to begin with by putting sparkplug in the wire n touching diode to the engine block while pulling the cord.thats a good starting point to diagnosing your problem.maybe try warming it up in the house then try starting it with no choke needed.the saws i ve used needed you to give it throttle after you pull,n no throttle with choke.
Mar 12, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
134 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
