Question about Sylvania TV Receivers & DVRs
Sylvania model c 6420 fe
I am looking for a part for this sylvania tv.,it isthe part where the tv cable screws in behind the tv set .someone trip onthe cable and pulled it out from this box ..The following is on this box.utunntuspo25 and below is b9015a lot trgfa.Help me out if you can thanks Reno
0 characters
1 Points
How do i connect xfinity to my plasma display
If you're referring to your xfinity tv receiver (the cable box) there's a few different ways. Please keep in mind without much information, it's difficult to give a 100% direct answer.
There are four ways to connect it. We'll start with what will give you the best video quality, going to the worst.
HDMI cable: A single cable with a flat end. Your TV and receiver will have port labeled "HDMI". You plug it in, and then use your tv remote to set it to the HDMI channel. You may have source or input button on the remote. Press that, and a list of options will appear on your tv. Select HDMI. If there is more than one HDMI (as in HDMI1, HDMI2) try each one until you get a picture.
Component cable: A cable with 5 ends. They're color coded, so match up the colors. Then try that input our source button to select the COMPONENT option on your tv.
RCA cable: A cable with three ends. Color coded. Follow the same directions as above in regards to the correct "channel" to put it on.
Coax: A single cable, an end that screws in. Its connector will look like something can be screwed on it, with a hole in the middle for the pin to go into. Connect it, then tune your tv to channel 3 or 4.
Mar 30, 2013 | Comcast XFINITY
Call the company or the manufactor they can do something for you.
Jan 04, 2013 | Alba TV Receivers & DVRs
Hullo ... I have erroneously used the TV remote to change channels, where I should have used the TelstraClear remote to do this. I now get a "No Signal" box on the television and am unable to...
The TV is not on the correct input setting or channel. Depending on your TV model and the receiver, you have a cable coming from the receiver to the TV. That cable could be a coax (screws in), RCA (yellow, white, red tips), component (green, blue, red, white, red tips), or HDMI cable. For all cables except the coax, the TV should be on an input setting. With your TV remote, you should have a source, input, or TV/Video button. Press that button and it should bring up a list of input settings. Each time you press that button it will scroll you down the list. Try each setting until you find the picture. I hope this helps.
Ray Calo
DISH Network
Jan 21, 2011 | TV Receivers & DVRs
I am trying to find a remote that will work my Sylvania 32" digital tv. I have tried 3 different remotes and none work. The remotes I have will work everything else.
Try with the model of your TV. They often have exact duplicates of the original remote or a substitute remote that will handle most of the features of the original.
Alternatively, look at the high end remotes that are programmed by a computer.
I hope this helps.
(the age of the TV and the build date of the universal remote affect the codes. My universal remotes from early 2000s or late 1990s did not work on newer TVs with digital tuners.)
Apr 18, 2010 | Sylvania TV Receivers & DVRs
Need an operations manual for a TV sylvania
You need to give the model number but to guide you in the right direction look hence forth..
If this helped Vote for me or do a testimonial
Sep 02, 2009 | TV Receivers & DVRs
Nothing works
Mamarene, you should have a cable that comes from the flooor or wall that will got to the Satellite in port on the Dish receiver. You then should have a cable leaving the 3-4 port of the Dish receiver going to the IN PORT -usually the top- of the VCR. Directly below this port on the VCR you may have another cable which ould connect to the antenna port of the TV or you may have a set of red/white/yellow cables that need to be on the output port of the VCR of the corresponding color and connected to the INPUT PORT of the TV in the same manner. The DVD will be connected the same way with red/white/yellow but mat go directly to the TV on another set of IN PORTS or they may go to the IN PORTS of the VCR if so equipped. If your systems is different let me know what kind of connections and type theey have or give me the make and model number of the TV/VCR/ and DVD and I will look them up and tell specifically what to connect where. Thanks for using Fix Ya
Mar 19, 2009 | DISH Network 311 DTV Receiver
Sylvania tv model sst4272 no vertical
The LA78041 IC has failed. I replaced it twice before I cleaned the high voltage connection to the CRT. It was very cruddy from cigarette smoke. A high voltage discharge to the yoke takes out this IC. They are available for under $4.00 Good luck.
from Lincoln Hubbard at
Feb 09, 2009 | Sylvania TV Receivers & DVRs
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Nov 26, 2008 | TV Receivers & DVRs
Sylvania TV codes
For what type of remote? Brand model number?
Nov 13, 2008 | TV Receivers & DVRs
TV Receivers & DVRs Logo
35 people viewed this question
Top Sylvania TV Receivers & DVRs Experts
Jaime Hernandez
Are you a Sylvania TV Receiver and DVR Expert? Answer questions, earn points and help others
