Question about Insignia 2.0 Speaker System (2-Piece)
Static/putput noises coming from insignia speakers
They're only a year old and whenever they are on they make this dreadful like repetitive popping noise with a background static-type noise. I'm listening to my music at twice the volume to drown it out. Horribly frustrating. My guess is that it's probably bad wiring and they're just crappy speakers, but I've only had them a year and half of that they weren't even being used, they just sat in their box.
  • The Vanguardian
    The Vanguardian May 11, 2010
    First, check them against another set, to make sure it's not your computer that's doing it. If it isn't in the computer, it could be the power adapter that's powering them, see if you can find another adapter with the same voltage and connector.
Steady popping noise.
reinstall the sound driver
thank you
Oct 23, 2008 | Logitech Z-5500 Computer Speakers
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
Insignia white noise coming out of speakers not when muted
try adding .01mfd disc capacitors across bridge rectifiers diodes(all the 4 diodes),If the devise is old try replacing filter capacitors.and isolate transformer secondary leads if they are very near recifier board.
Jun 30, 2014 | Insignia 2.0 Speaker System (2-Piece)
Left Speaker Jack only produces static
That is probably happened to an aging speaker.
Consider buying a new one or try to rewire the coil inside the speaker magnet.
Jun 01, 2010 | Bose Companion III Computer Speakers
Insignia PC speakers - give a weird static feedback noise
I'm going to vote for the haunted option.
Sound like you have some noise on your power lines. This can be caused from many different things. Normaly it is a motor going bad or a compressor starting up. From the AC unit or refrigerator.
See if you can correspond the noise to anything else happening in the house. Fridge starting up, AC or heat cycling on...etc.
It may be that you just have speakers and a cordless phone going bad at the same time.
It might just be Casper the friendly ghost playing tricks... ha!
Jan 23, 2009 | Insignia 2.0 Speaker System (2-Piece)
Popping & cracking noises
Is the popping noise coming from the speakers? If it is, lowering the volume to zero does not stop the popping from the speakers, then you have an audio output failure. If the sound is not from the speakers, you probably have a high voltage leak. If this is the case, are you in a moist environment or using the set near a window??
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Popping noise
If the popping sound is NOT coming through the speakers, you probably have high voltage arcing. Probably close to the high voltage (flyback) transformer. If this is the case then other parts could be damaged if allowed to continue. If the popping is coming through the speakers then you could have a problem any where in the signal circuits. Like a loose connection. You'd need to have it checked out to find the problem.
Feb 27, 2007 | Sanyo AVM-3680G 36" TV
Insignia 2.0 Speaker System (2-Piece) Logo
142 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
