Question about Epson CX8400 All-In-One InkJet Printer
Ok I have a cx8400 all-in-one Epson printer. I was out of black ink so I started using composite black. Also ran out of color ink so I bought the black cartridge and installed it. Now the printer says i have to replace the color cartridges and even when I changed the settings to black and white only in the printer and the computer it doesn't want to work and when it does it only print blank pages. I already checked the black cartridge to ensure it wasn't clogged and I know the printer recognizes it cause when the "replace cartridge alert" appears it shows the black ink cartridge full. I don't want to buy the color cartridges, they are to expensive and I don't need them!
  • mendozaramos Sep 13, 2009
    THANKS FOR THE ADVICE BUT THAT SUCKS, I'LL BETTER BUY A NEW PRINTER. THE INK CARTRIDGES FOR THIS ONE ARE TOO EXPENSIVE AND CAN'T BE REFILLED. IT'S JUST NOT COST EFICIENT FOR ME. THANK YOU.
    President:
  • 1,653 Answers
If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement. You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expendedI have come across this issue many times and unforunately you have to replace the colour carts in order to continue to use the printer.
Posted on Sep 12, 2009
I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
hello
i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
Have an apple computer - epson cx8400 printer epson black 69 ink ran out my husband removed this cartridge before we had the new one to put in now printer continues to show press ok button to replace...
First try this, remove all the cartridges, turn off the printer, unplug all the cables including the power cord, leave it for few minutes, clean whatever you think you can. Tap the power button several times. Reconnect and reinstall everything. Now try switching it on again. It should work fine. There's more to do if this doesn't fix. Let me know if the problem persists.
Good luck.
Thanks for using FixYa.
Sep 16, 2010 | Epson CX8400 All-In-One InkJet Printer
My printer wont print black and white only
My Epson Stylus cx8400 uses ink so fast. I would like to turn this into a black and white printer only. The problem is, I am out of one of the color ink cartridges and it won't let me proceed until I replace it. Is there a way, in the mode it's in now, to get this to print with the black and white only? I am nearly out of ink on all color cartridges now and do not want to purchase more at the high cost they are.
Thank you!
Oct 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Printer cx8400 All in one inkjet does not print well (ink is new)
have you tried to using the head cleaning? It will clean the nozzles inside your printer. you can check your manual how to do it.
Feb 10, 2009 | Epson CX8400 All-In-One InkJet Printer
Ink cartridge replacement
I had the same problem, and after scouring around online for a few days, I learned that this is one of the biggest gripes about this printer. Basically, you're out of luck unless you replace EVERYTHING, even though you only want to print black (nuts, isn't it?). So I went out and bought all new color cartridges, and it STILL won't print. I think it's just a bad printer all around. :(
Sep 07, 2008 | Epson CX8400 All-In-One InkJet Printer
Using colour ink without black ink in Epson CX5500
this cannot be resolved, Epson software is useless it will force you to buy an INK
Jun 07, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson CX8400 All-In-One InkJet Printer Logo
283 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
