Question about JVC RX-D202 Receiver
JVC RX-D202B Blown capacitor
I have a JVC RX-D202B which stopped working. I replaced the fuse and it would blow again. I saw that an audio capacitor, C1117, had exploded. I was wondering what would more than likely be the reason the capacitor had blown. Could one of the amplifier chips gone bad, if so which one? I also saw that R109 and R110 have turned the PCB a dark brown. They test to be at the 2Kohm value.
2 Suggested Answers
  • 120 Answers
SOURCE: JVC RX-318 keeps blowing fuses
could be several things, speaker wires touching,shorted output transistors, a shorted rectifier diode,bad filter caps in the power supply,those are the most common
Posted on Jan 06, 2009
My JVC RX-801V has a short? The 5 amp fuze burns out every time I replace it. what could be the problem?
Probably the output transistors have blown or the amplifier capacitors are dried out.
Fuses are there to protect you and the device from further damage. Repeatedly replacing a fuse without fixing the cause of why it keeps blowing in the first place isn't a wise decision.
Sep 10, 2014 | Audio Players & Recorders
Can anyone please help me with my superstar red 3900 has i have changed the audio chip and protection diode and i have still got no recieve what could the problem be thanks
No RX or No Audio?
Could be blown protection diodes or if no audio a faulty capacitor close to the audio chip!
The protection diodes can blow if you were close by someone with a high power transmitter, then the diodes would blow kinda like a fuse to protect the rig, result no RX symptom!
Replacing the diodes will cure that problem, located close to the rear of the rig.
Sep 06, 2011 | Superstar SS-3900EGHPA CB Radio
Microwave blows fuse in microwave mode grill function ok
It is most likely the capacitor has shorted or the rectifier has shorted. Check with ohmeter, but make sure it is discharged first by shorting the capacitor with a wire.
May 21, 2010 | GE Advantium 120 Convection/Microwave Oven
Jan 06, 2009 | JVC RX-318 Receiver
My jvc receiver has blown fuse if i replace the fuse and it blows again what else could be blowing the fuse
blowing fuse only indicates that there is power surges in your area. in order to avoid blowing your fuse again. you may need to a have a surge supressor and auto voltage regulator used for your receiver and any appliance that may need it.
Mar 24, 2008 | Audio Players & Recorders
Stopped working
I had a similar problem with a jvc 8040. when I replaced the fuse it became very obvious that the b1560 output on the center channel was blown (smoke and sparks, always a dead giveaway). I haven't fixed the center channel yet but simply unplugged the center channel board and removed it from the unit. Now everything works fine except of course the center channel. Pre outs still operate just fine so a slave amp could be used for center channel power, or you could just go and buy a marantz amp; I did and then I realized that I was lucky that the old jvc quit.
Jan 27, 2008 | JVC RX-1028V Receiver
RCA RS2656 Shelf System
Had a problem with a customer's stereo system, i replaced the transformer and put in two new fuses and all worked good again. Another time it was a damaged capacitor allowing full charge to go through causing the fuse to blow immediately so i just replaced the capacitor and the fuse and all was good.
Dec 31, 2007 | RCA RS2656 Shelf System
Blows fuse
i've got a problem on my denon receiver/amplifier. what devices are 1) KIA 7915PI 321,
2) SK B1560 44 P
3) SK D2390 43 Y
can you please send me some details about these devices (semiconductor, diode, integrated circuit, terminal voltage regulator, capacitor, etc.)
thanks in advance!
Dec 30, 2007 | JVC RX-5020VBK Receiver
JVC RX-D202 Receiver Logo
130 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
