Question about Logitech 967461-0120 Keyboard/Mouse
Keyboard Key assginment
I added an Emotion from my MSN..and placed it on the "A" letter Key...
Now, when i type the letter "A" in any shows the emotion...rather then the actual letter..
How can i reverse that..?
3 Suggested Answers
Fix it Out
  • 90 Answers
SOURCE: no letters on screen
You need to reboot the PC and it will be fine.
Otherwise, if your mouse is working then go to the device manager and uninstall the keyboard and then restart the PC with Keyboard Driver Installation CD/Setup.
Let me know if you face and difficulty and need further assistance, I will assist you further to fix the problem.
Best of Luck & Have a Nice Day Puneet
Posted on Oct 07, 2008
  • 118 Answers
SOURCE: the keyboard types 2 letters for each single press
try encrypting the keyboard contact logitech on how to encrypt your keyboard.
Posted on Jul 17, 2009
  • 78 Answers
SOURCE: problem keyboard
either remove the batteries from the keyboard and the mouse, and unplug the receiver from your computer, and leave them all unplugged for about an hour.
otherwise, you might wind up literally taking the keyboard apart and cleaning it, which isnt recommended unless you really know what youre doing.
otherwise, you simply will wind up buying a new setup there.
Posted on Sep 24, 2009
0 characters
1 Points
Sony Vaio keyboard repeating letters
Keyboards to wear out, but are not expensive to replace. Multiple key strikes and sticking can be caused by spilling "stuff" into the keyboard, even crumbs will do it.
Oct 29, 2015 | Sony VAIO PC Laptops
Keyboard typing wrong letters
Your keyboard is not "typing wrong letters", you have a stuck key. The key is shorting out and is stuck on the letter W. Usually caused by dirt/dust/spills on the keyboard jamming the key so it can't release. Things to try in order of difficulty:
>Vacuum cleaner with brush attachment, vac the keys.
>Paper towel moistened lightly rubbed on the 4 sides of the W key; use a knife blade to gently work down into the edges.
>Soft toothbrush, lightly dampened with water, work the bristles all
all around the edges of the W key. After that do step 2 with a dry
dry paper towel.
>Take the keyboard apart; usually several tiny screws on the rear/sides. CAREFULLY remove the top. You may have to turn the board over, lie on its face to do this. Do not knock the letters out of order or you will have a headache placing them back in proper order! Clear whatever it blocking the W and replace the cover.
If none of the above works the keyboard has failed, needs to be replaced.
Jun 08, 2013 | Samsung Keyboards & Mice
My laptop is entering more than one character at a time when typing in my password for example its adding additional letters how can i turn this off
seems like something is ring with the keyboard, try an external keyboard, if the issue is still the same this will be a windows issue, once in windows tap on the shift key 5 times this will either deactivate sticky keys or ask you to activate sticky keys.
If it is not a sticky key setting issue then the problem most likely will be Hardware, did any liquid spill on your keyboard previously causing the key to malfunction causing the key to type extra characters?
If none then possible this is a faulty keyboard on the machine.
Sep 10, 2011 | Keyboards & Mice
When typing skips some letters & spacs
Start>Control Panel>Keyboard
Adjust keyboard...
Sep 10, 2009 | Keyboards & Mice
A key (which one?) changes the letters all keys type
You're hitting SHIFT and CTRL -- which changes the keyboard input method, i.e., for French keyboard, or for DVORAK keyboard, or for Scandinavian keyboard.
Access CONTROL PANEL, and use REGIONAL settings to "uninstall" all keyboard-layouts that you _never_ use.
Jul 01, 2009 | Microsoft Natural Ergonomic 4000
Locked keyboard buttons
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
  1. Click Start c01311982.gif , and type region into the Start Search field.
  2. Select the Keyboards and Languages tab.
  3. Click Change Keyboards .
    A Text Services and Input Languages window opens.
    Figure 3: Change Keyboard button
  4. Click Add .
    Figure 4: Add button
  5. Select the keyboard(s) you want to use and click OK .
    Figure 5: Add input language: US Dvorak keyboard selected.
    The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
    Figure 6: Keyboard tray icon
  6. From the Text Services and Input Languages window, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    Figure 7: Move up button
  7. Click OK . You can now use the new keyboard. If you find that the new keyboard works well and you do not want to use the other keyboard, repeat these steps and Remove the keyboard that you do not want from the General tab of the Text Services and Input Languages window.
Jun 02, 2009 | HP DC170B Keyboard
Keyboard typing extra letters >.<
Sounds like the windows key is stuck down, pressing start+r opens run, start+e opens explorer etc. The start key being the one between control and alt.
May 25, 2009 | Keyboards & Mice
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Keyboard is messed up
Try looking here to see if any of the keys are set wrong.
Normal 0 If you are then go to Control Panel.
1. Click on PRINTERS.
2. When the Printer Properties come up, CLICK on KEY SETTINGS.
3. Then set up the keys by selecting the key to be setup.
Hope this helps. Bud
Dec 14, 2008 | Saitek Eclipse (PZ30AUR) Keyboard
Logitech 967461-0120 Keyboard/Mouse Logo
29 people viewed this question
Top Logitech Keyboards & Mice Experts
micky dee
Are you a Logitech Keyboard and Mice Expert? Answer questions, earn points and help others
