Question about Microsoft Windows XP Professional for PC
The search utility on Windows XP Start Menu does not respond properly to the "Case sensitive" option. That is, it still finds ALL occurrences, even those which are not printed in the desired case.
  • 77 Answers
Left click too sensitive
open the start menu and type mouse and it will be the first option
Jul 15, 2013 | Logitech Computers & Internet
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
Installing a web cam creactive
  • 1)Insert the software and drivers disk into your CD/DVD drive. If an auto play window pops open, select the "Install" option. This will begin the installation wizard automatically. If the auto play option doesn't start, go on to Step 2.
    2) Double-click on the computer icon on your desktop or navigate to "My Computer" by opening up the Start menu and selecting "My Computer." A window will pop open. Right-click on the drive were the disc is located, for example DVD Drive (F:). Select the "Install" option to start the installation wizard.
  • 3)Plug your webcam into the desired USB port. If you have not installed the drivers, the device driver wizard will begin searching for the drivers on its own. Windows XP, Vista and Windows 7 utilize the plug-and-play option and will automatically find the drivers for you. However, it is recommended to install the drivers from the disc or from the Creative Labs website.
  • THankyou.
Jun 13, 2011 | Computers & Internet
My Belkin USB 10/100 Ethernet adapter is detecting as a buetooth device when I connect to my laptop... I am using Windows XP as an operating system. I guess WIDCOMM in windows is causing that...
Wireless Zero configuration is a utility that connects your computer to a wireless network.
If Wireless Zero configuration is not enabled, the following message will appear: "Windows cannot configure this wireless connection."
Note: If you have the Belkin utility installed, you'll need to change the Program Choice in the Options tab so the Windows XP Utility is selected.
Setup steps:
  1. Go to the XP Start menu and select Control Panel.
  2. Change the view to Classic View.
  3. Double-click Administrative Tools.
  4. Double-click Services.
  5. Find Wireless Zero Configuration within the Services list.
  6. Right-click Windows Zero Configuration and select Properties.
  7. Select Automatic from the drop-down menu next to Startup type.
  8. Click Apply and restart your computer.
Jun 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
All of the programs in the start menu are showing empty. I can find them with a search and run them, but some shortcuts are gone.
Check this link to check the settings of your start menu. http://www.coolnerds.com/XP/StartMenu/xpStartMenu.htm. It might be that it is not properly set that is why you dont see those options on your start menu. Hope this would help. Thanks.
May 30, 2011 | Microsoft Windows XP Professional Full...
Can not get it to turn on
Download Hiren Boot cd from http://www.torrentzap.com/torrent/622163/! (9Down.COM) Hiren's BootCD v10.0
Instruction on how to use it...
  • The disk is downloaded as an ISO file. The ISO files can be burned using software programs such as Nero. Burn the disk to a DVD instead of a CD by using a program such as IMGBurn.
  • Booting
  • Once the disk is burned, place it on a DVD or CD drive on the computer and restart the computer. After the computer displays its default first screen, the disk will scan and load the Hiren's Boot menu. The menu gives users three options. The options are to start the computer normally, load Mini Windows XP or load the disk. Choose the disk-loading option to work within the disk parameters and run in DOS. DOS is a simplified process that uses only text. The CD provides shortcuts to each utility.
  • Mini Windows XP
  • To clear a virus and use a large collection of Hiren's Boot tools, choose the Mini Windows XP option. A simple version of Windows XP will load on the computer. It might take a few minutes to load everything because it processes files directly from the CD. Once it has loaded, wait for the Hiren's Boot disk menu to pop up. Select the "Menu" option and scroll through the programs. The disk features Windows password hackers, registry cleaners and a large collection of antivirus software.
  • Antivirus
  • A main portion of the disk feature antivirus software. Spybot-Search and Destroy scans a computer for the most likely spyware and removes it. Malwarebytes Anti-Malware finds root kit viruses and Trojans that could affect computers and spread through networks. Super Antispyware is an all-in-one scanner that detects and eliminates all types of viruses. Run one scan at a time. Do multiple scans because one program might find a virus that another program misses.
  • **Please give a 4 thumb rating..If you find my solution useful**
    Have a Nice Day
    Sep 28, 2010 | Computers & Internet
    When I start my computer and it comes to users account I try to put in my password but it says not the right password I wrote it down but it seems not to be working is there a way around this so I can make...
    Hello.
    When you created that password, you should have had a security question answered that would help you remember what the password is exactly. Even though you wrote it, remember that it is case sensitive. So if your password was
    SystemShock2 it won't respond to systemshock2 or SYSTEMSHOCK2, or anything that isn't exactly as it was written.
    If you cannot get in, reboot and keep pressing F8 until you get the safe mode options. Log on as Administrator and change the user account password, or remove it entirely.
    Nov 07, 2009 | Microsoft Windows XP Home Edition
    Recently unable to download photos from my eos 350d to pc. When I hook up through USB the camera flashes busy for up to 5 min. Then the usual EOS utility box appears. The only option available is ''...
    Do you have a memory card reader or a memory card slot on your laptop or Desktop PC? If so, remove the memory card on your camera and then hook it to the slot on your computer.
    It should be detected and then you can copy your files from the card to the computer.
    If you still have problems, please post back.
    Aug 21, 2009 | Canon Rebel XT / EOS 350D Digital Camera
    HP computer with both Vista and Windows XP
    If you truely have Xp and Vista installed properly, you will see a dual-boot menu when the PC starts up... From there you would have the option to choose which operating system you wanted to start... Otherwise, if you dont see that menu, you still might have both OS installed but you would have to edit the master boot record...
    Apr 04, 2009 | Dell Inspiron 1525 Notebook
    Folder Options
    Click Start, Run and type this command:
    regsvr32 /i shell32.dll
    Jan 03, 2008 | Microsoft Windows Xp Home Edition Sp2...
    Microsoft Windows XP Professional for PC Logo
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
