Question about Panasonic TC-32LX50 32 in. HD-Ready LCD Television
The cable guy programmed the cable remote to turn on/off the TV. We used it to turn the TV to stand-by. Then pushed the power button on the TV to turn the power off. Haven't been able to turn the TV on since with any combination of TV button and remote on/off button. Did we fry the power supply?
  • suebrown06 Sep 15, 2009
    Yes, it is a universal remote, and I understand how they work. I have programmed universal remotes with macros. The problem is the TV power button will not even put the TV in stand-by mode (the indicator on the TV will not light up red or green). I have a hard time believing the remote has anything to do with this. But I wanted to describe exactly what happened.
    Problem Solver:
  • 9 Answers
Does your cable remote have a little button that says "tv" ? Usually you have to tell the remote which machine it is controlling, and you do that by first pressing the button "tv" "cable" or "cbl" "dvd" etc. Once you do that, it will use the frequency for the item you selected. After you turn on the tv, you'll then have to press "cbl" or "cable" to operate your cable box.
Your power should be fine unless you also had a surge or lightning strike.
Posted on Sep 12, 2009
    Problem Solver:
  • 12 Answers
First use the original remote control that came with your tv, or just manually turn it on at the tv itself to bes sure it is working. If it works you should call the tech support for the cable company to program their remote control to a different code - or put it back to to factory state and just use two remotes.
I need remote control code for Dawin TV
If you do not know the code, you can use the code search function to program the remote control.
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Apr 04, 2016 | Televison & Video
I can't program my remote to the tv
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Feb 18, 2014 | GE 210864 Vcr Remote Control Original...
How do I program a tv code into my remote
Jan 05, 2014 | GE Tv Vcr Sat/cbl Remote Vsqs1495...
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
I need to program my Sanyo remote to all available channels. What is the code for a Sanyo GXBD remote?
I think this may be what you need I will tell you and we can see. Its true most remotes have codes but their are so many of them it would be hard to say. But as a fail safe the remote is programmed with a self coder. turn your T V off stand away from it a couple of feet and aim your remote at it, then start pushing the power button slowly at about 2 second intervals just keep pushing sometimes you may have to depress the power button as many as 50 times but the T V should turn on when it does use your remote and go to menu channel select and scan it should log the channels in automatically in about 3 minutes
Nov 10, 2009 | Sanyo DS20425 20" TV
TV Will Not Turn Off With Digital Cable Control
The remotes you get from the cable company are universal and kinda cheap. ive ran across this multiple times but since i dont know what model remote you have the only advice i can give is that the code you used is not the right code if it doesnt do all basic functions (on,off for the tv,volume)its just the wrong code if the codes you stated are the only ones available the book you got with the remote should explain how to run an auto scan.hope i was some help
Feb 01, 2009 | Symphonic ST419E TV
Codes to program the RCA Universal remote control for a Magivox T.V.
My dear friend if your remote control got the code search button try with this.
Push and hold code search button until the led stand lit,now release him push and release the tv button the you need to push and release the power button until the tv set turns off push and release the button set and the code get in the memory of the remote.
You need to turn the tv manually.
Good luck
Sep 13, 2008 | Televison & Video
Television
Try this: turn on your tv.
Push and hold code search button until the led light stand.
Release him push and release the device button( Tv,Dvd,Vcr),now you got to push and release the power button until the tv turn off now you push and release the enter button and the code are now on the remote memory.Good luck
Aug 20, 2008 | Emerson EWF2704 TV
Need code
i too went 3months with no remote or codes finally a young tech at walmart in another town told me to use 0171 code but cable guy set me up on cable remote to turn tv on and off tech told me to get a one for all remote 9.99 at walmart and code it but to also push setup code for tvdvd and enter code i use cable remote for tv viewing and the one for all to reach video 2 (press tv/vid button twice) for games and dvd player now i can access menu and use my tv as it should hope this helps
Jan 03, 2008 | iLO 3200 32 in. LCD Television
Olevia 242T television
The code you want is 11610. Buy a remote that can accept this code.
Dec 01, 2007 | Televison & Video
Panasonic TC-32LX50 32 in. HD-Ready LCD Television Logo
103 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
