Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven JVM1650SH01
I would like to know how many amps does the microwave oven JVM1650SHO1 need to make it work.
  • GE Master
  • 9,047 Answers
I'm not finding it in the owner's manual, but there is a tag inside the cavity which should tell you either how many amps it requires or how many input watts it consumes.
If it gives you power in watts, just divide: #watts / 120V = current in amps.
If that tag doesn't tell you, maybe one on the back of the unit will.
It will probably be 13-18 amps, depending on whether its power output is 950 watts or 1200 watts.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
microwave oven JVM1650SH01 - d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
On that mini-manual, there should be a troubleshooting flowchart, and it will have a few different current measurement values on it. You should be able to decipher the normal draw from that.
If you're just trying to figure out how many amps the breaker should be on the microwave's power line, figure 15A for an oven rated at less than about 1000 watts output power, and 20A for an oven rated at over 1000W.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly with your brand, model and symptoms for more FREE help & do-it-yourself advice.
Please include this URL, too:
http://www.fixya.com/support/t2931401-microwave_oven_jvm1650sh01
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 12, 2009
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
GE JVM1650SH01 Microwave starts cycle but as soon as heating starts it shuts down and requires clock and date reset. Sometimes resets and works but now will not stay reset.
You have a bad or loose magnetron.
See
this FixYa solution. even if your model number is different.
Aug 20, 2010 | GE Microwave Ovens
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge jvm1650sh01 surface light doesnt work/ vent
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
May 06, 2010 | GE JVM1650 1000 Watts Microwave Oven
Jvm1650sh01 .microwave
Hi
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Vent motor turns on, but does not draw air in as it should...
the vent tube in back may not have been changed over they can be vented or ventless but you must switch the flap in back you had the answer in your question ... good job,,..lol
Jan 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1650SH01
your problem most likely is in your door aligment there are 2 arms that need to close some door interlock switches inside the unit next time press in on the door hold it and try to start or push down on the door after it is closed and try to start it
Jan 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
141 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
