Question about Ricoh Aficio CL3500N Laser Printer
We have a Richoh CL3500N printer and it is not making clean copies - especially the black ink is very unclear in places. How can we fix this?
  • 1 more comment
  • donna798 Sep 12, 2009
    Many of the sections and sometimes just words are coming out very faded when printing. It is not consistant when & where this is happening, but it very common and happening on every page.
  • donna798 Sep 14, 2009
    not at all helpful!!!!
  • lkoik May 11, 2010
    Here is some great PRINTER solution by Some FIXYA EXPERT.
    Get any kinds of PRINTER solution from bellow.
    » Brother Printer Solution
    » Canon Printer Solution
    » Epson Printer Solution
    » HP Printer Solution
    » Lexmark Printer Solution
    » Xerox Printer Solution
    » Other Printer Solution
    20
3 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: how to clean lens on our ricoh CL3500N Laser printer
Toner spills can be cleaned with a cotton pad and alcohol. If excess toner appears do the following:
You should replace the PCU if prints show any of the following symptoms.
  • Colors are missing, faint, or partially blurred.
  • Toner smears appear.
  • White or color rivers appear.
  • White or colored streaks appear
    1. Important: Switch off the device and disconnect it at the mains.
    2. Open the right side cover.
    3. Pull the green levers as shown to release the inner cover.
    4. Lift the inner cover upwards.
    5. Squeeze the green lever on the black PCU.
    6. Pull the unit carefully out of the device and dispose of it in accordance with your local environmental policy.
    7. Place the new PCU on a flat surface.
    8. Peel off the tape from around the new PCU.
    9. Remove the top cover from the PCU. DO NOT remove the bottom cover at this stage.
    10. Rest the new PCU in the device as shown.
    1. Push the PCU into the device while holding the bottom cover. You will hear a click when the PCU has locked into place.
    2. Lower the inner cover.
    3. Push the two green levers as shown to secure the cover.
    4. Close the side cover.
    5. Connect the device at the mains, switch it on and wait for the self-test operation to finish.
    Please remember to rate all users who assist you for free :)
Posted on Oct 04, 2008
  • 393 Answers
SOURCE: Ricoh cl3500N printing with blank streaks in
The voids and blotches can be a bad black pcu, the voids san also be toner on the glass slat obove the pcu,s there are 4 slats one for each color, on the pcu itself on the upper side is a narrow long opening, the glass slat is above this opening when the pcu is in the printer. It will take a flashlight to see any toner on the glass.
-Carl
Posted on Jun 28, 2009
What is causing my Ricoh CL3500N to allow vertical streaks of faded color on my copies?
This is usually caused by defective, or empty, toner cartridges. A good cleaning and replacing the old waste toner drum as will as the defective cartridge with a certified manufacturer's cartridge usually fixes the problem.
Apr 07, 2015 | Ricoh Aficio CL3500N Laser Printer
Making Only megenta color copies no other color
When the blue color ink is finished it may print magenta instead of blue. And it is clear that black,yellow,red colors are there.
Jun 18, 2010 | Ricoh Aficio CL3500N Laser Printer
Not printing in color and black/white copy not clear, light in some places
Dear sir
good day
to fix up such problem
Clean the printhead, then print and
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo + Copy simultaneously to print a demo sheet
and you have to Replace ink cartridges.
IMPORTANT: Make sure you are using KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to KODAK Ink Cartridges & Photo Value Packs.
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Insert new KODAK ink cartridges into the printhead, then press down firmly until you hear the cartridges click into position.
  3. Close the printer access door, then make the same print.
and you can point to the website below for further information
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=5224/6198
thanks
Dec 18, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer is smudging ink on left side of paper
Hello sir; Pull out transfer belt unit replace belt clean blade. it should take care yor problem.
Aug 28, 2009 | Ricoh Aficio CL3500N Laser Printer
The black ink in my Epson dx6000 won't work. I've wasted so much ink cleaning the print head. HELP!!! Please!!
You could try this Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Hope it works for you. Worked on my HPc6180
Apr 28, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Not using generic ink for black
@robgat:
Did you use generic carts? Those do make a lot of trouble. Use another cart.
Make sure the cart is placed well and secured (white plastic nose).
press menu then start bk copy then fourtimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink in tubes and ph and do some cleaning procedures. leave maintenance mode by pressing 9 then 9. do run a test print.
If you still cant see any bk the ph is clogged and cant be fixed anymore due to wrong ink consistence of the generic ones.
@Meloman:
If you use original carts make sure you have placed the carts well and they are secured! Give answer to display info!
If you still receive the error in question, have a look at the right hand side of the cart holder. Here you will see the led control board which might be out of position and needs replacing. Open printer and reinsert the small board.
Jan 06, 2008 | Brother MFC 210C All-In-One InkJet Printer
Black ink clogged
Did you use generic ink? The generic ink has the wrong ink filled in which destroys the ph!
brother printers must be run with dye-ink and special additives. Those additives are always missing within the generic carts!
Do use a original brother ink cart, make sure ALL carts are full with ink, placed well and are secured! Run the following procedure afterwards:
press menu then start bk copy then fourtimes arrow up (tel-index). machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink
within tubes and ph and do some special cleaning procedures. When finished press 7 then 6 then 3 then start bk copy. machine will run a powerpurge.
When finished press 9 then 9 to leave the maintenance mode.
Print a quality test print by pressing ink Management etc.
If there is no BK afterwards the ph is defenitly clogged and cant be fixed anymore!
Dec 28, 2007 | Brother MFC 210C All-In-One InkJet Printer
Will not print black
The ph will be cleaned by pressing ink thru the system (tubes and ph). Do use only dye-ink for this procedure. The best way is to use original brother ink.
place a new cart into position and make sure that they are secured.
press menu then start bk copy then fortimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink and do some cleaning. afterwards press 7 then 6 then 3 then start bk copy. machine will do a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a test quality print by pressing ink etc.. If you cant see any bk the ph is defenetly clogged and cant be fixed anymore. It needs replacing.
Dec 14, 2007 | Brother MFC 420CN All-In-One InkJet...
My printer won't print.
1:check the usb cable or replace it
2: remove the black print cartridge clean the contacts then reinstall it
Nov 28, 2007 | Brother MFC 210C All-In-One InkJet Printer
Ricoh Aficio CL3500N Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
