Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Start button not working on whirlpool cabrio washing machine
  • 15,935 Answers
It sounds like your thermal fuse is out. You can check it for continuity with an ohm meter, make sure your dryer is unplugged first! Or you can take the wires off the thermal fuse and use electrical tape to tape them together to see if it will come on.
CLICK HERE for the TECH SHEET on your washer... and HERE to see the thermal fuse.
Sometimes the plastic start button can break a little tab off the back as well, so check it as well.
Thanks for using Fixya - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2009
  • 82 Answers
SOURCE: Cabrio washer want start.
leave the door open and try it again if it does the same thing as before the door lock has gone
Posted on Jun 27, 2009
  • 726 Answers
SOURCE: Whirlpool Cabrio High Efficiency Top-Loading
hey there i had a search F then 1 flashes there is a primary control failure. Replace the machine control assembly my best bet would be to call a service center or repair guy to advise you further what to do or even fix it as this will be a ongoing stuff around for you and you dont need that
Posted on Sep 15, 2008
57 varieties
  • 1653 Answers
SOURCE: F54 error code
The F54 code is a motor control overcurrent error. If you keep seeing this error then you ned to callin a service man to have the system looked at.
Posted on Oct 02, 2009
lancaster5
  • 245 Answers
SOURCE: My Whirlpool Cabrio smells like mildew and that
Try using a bottle of vinegar.
Posted on Aug 20, 2010
kel1guy2002
  • 3740 Answers
SOURCE: How to fix error f
Hi and weclome to FixYa, I am Kelly
An F54 code is a motor over current fault. This is caused by a severe load on the motor or a bad motor bearing.
To remove the error press Pause/Cancel twice. Before removing the error.. try and find out why the motor is hard to turn. There may be an article of clothing stuck at the top of the inner tub or between the inner and outer tub. (
If the unit has previously had an ld code (long Drain) this can also cause high motor currents if the water level switch allows the washer to spin when not completely empty. Usually an ld code is associated with something stuck in the pump / pump inlet or possibly a bad pump.
Thanks for choosing FixYa,
Kelly
Posted on Jun 09, 2011
Why won't it start?
Pull the wall plug on it and count to 10 and then plug it back in.
How to reset whirlpool cabrio eHow UK
Jan 02, 2016 | Washing Machines
Whirlpool Cabrio washing machine button does not work.
Possible that the main controller unit is faulty. You need to confirm the voltage on the controller unit and the connectors to the panel.
If there is no support from the controller then it can be faulty.
This requires testing the board for the processor and the set voltages for the board to function which must be measured..
Jun 05, 2012 | Whirlpool Washing Machines
My front loading washing machine started and then displayed f1, now it will not start at all and when I pushed the start button it beeps three times and does nothing.
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My start button no longer works on Whirlpool Cabrio WTW6600SW0
the plastic board where the button attaches is broken and the button fell down inside..
Feb 09, 2010 | Whirlpool Washing Machines
My washing machine beeps and flashesF1
my machine starts to fill with water then stops and flashes F
Oct 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Jun 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,739 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
