The fax on my sharp stopped working and made everything else on the unit quit, copier, printer etc... is this fixable or should I just junk the copier?
  • 1 more comment
  • Josh Firster
    Josh Firster May 11, 2010
    What model of copier do you have and does it diplay any error codes in the display panel?
  • CruiserGB May 11, 2010
    It depends on what indications you have and what model of copier you're referring to. I'd need to know the model number and if you're seeing any error codes on the copier display.
  • Joel Haletuke May 11, 2010
    What is the Model & Serial Numbers?
  • 63 Answers
How do you know the fax is what is causing your dead machine? If the whole machine is dead then your problem could be as simple as a blown fuse or as bad as a bad board. If your copier turns on but is not responding then on of your options could be causing the machine to lock up. Depending on your make and model is what will depend on weather its worth fixing or not.
Posted on Oct 15, 2009
Stop the junk mail!!
you can collect them then turn in the companys. Look into local laws to see how to turn them in, junk mail on faxes is illegal.
Jun 19, 2009 | Brother MFC-440CN InkJet Printer
Cannot clear stored fax data?
look in the fax manual there should be a section on that
If you have no manual call the company where the fax machine was mad.
May 13, 2009 | Sharp AR-275 Copier
Printer has stopped printing copies even with a new toner and drum. Help!
Try the old one back in it? does that work if so Faulty unit take it back
Apr 23, 2009 | Sharp AL-1661CS All-In-One Laser Printer
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
Fax transmission quality and copy quality are low
Hi alicia302,
It could quite possibly be the speed and quality of your internet connection. Incoming packets come in at a different frequency than outgoing data packets. As for the copying resolution be sure to check the units setup config. Set it to it's highest available resolution i.e. normal, high etc.. Also try uninstalling and reinstalling printer and software and be meticulous in your steps. I hope this helped a little, if not, hit me back, we have other options i.e. lens and light align meant.
Thanks for using FixYa.com
Sincerly, cyyyd7
Oct 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
R-1460
Check fuse. Remove 3 screws from the plastic grill located at along the top front of the unit. Remove the phillips head screw above the control panel. Slide up and pull out to partially remove control panel. You will see a white fuse. Replacement is CD3G 125v 20amp or BUSS ABC 20 or Little Fuse 314020 at 250v 20a. Radio shack caries the ABC.
May 12, 2008 | Sharp R-1460 Microwave Oven
Laser printer black streaks
clean scanner lens with glass cleaner applied to microfiber cloth aslo clean copier glass if this doesnt fix it replace toner/drum cartridge
Jan 24, 2008 | Canon imageRUNNER 1370F All-In-One Laser...
No scanning from Sharp ARBC260
I see this is an Office all in one. Fax works you say - sending also via the scanner? or sometihng else go into more detail of the operations of this device.
Sep 10, 2007 | Office Equipment & Supplies
15 people viewed this question
k24674
jasbo
jasbo
