Question about Kenmore 57029 Side by Side Refrigerator
Ice maker in my fridge deos not work. Water connections are good. If have to clean uo the filter,m where is it ? Any other suggestions ?
    Problem Solver:
  • 16 Answers
The main part that controls the water is a solenoid type device. That may be bad. On many fridges it is on the back near the bottom where the water from the source connects to it.
Posted on Sep 13, 2009
Testimonial: "good"
No Water going in to the fridge
Hi Norm,
Most fridges don't need a motor to run in order to dispense water. A simple on / off solenoid on the water line (same for the ice maker) that makes a click when changing from off to on and on to off is usually all anyone hears (the ice maker makes rumbling sounds and you can hear ice falling into the bin - too).
Check for ice. If it has a maker and it is making ice, the problem could be a defective water dispenser switch, solenoid or other circuit component or wire. If no ice, I'd suspect a filter or water supply issue.
Make sure the filter is fully inserted and twisted into place. Many filters have marks to align when 1) inserting and 2) to let you know when it is installed correctly. When sure it is installed correctly - try to dispense water again. Many fridges will dispense water without a filter. Check your manual before trying this though! If not working still, remove the filter and try to dispense water. If you're able to dispense water, the problem is either the installation of the filter or the filter itself. Try to re-install it correctly. Try to dispense water again.
If it still doesn't work - call the plumber back and ask why there's no water. Or - try this yourself:
Locate the point of attachment to the domestic water supply that the plumber used. There should be a valve to turn the water on and off. If off, turn ON. Try to dispense water again.
If that doesn't work - check to see if the fridge has pinched, kinked or crushed the water supply line. You may need to move the fridge forward to gain access to the water line and connection point on the fridge. Repair or replace the line as needed and route in such a way that moving the fridge in or out will not cause it to damage the line again.
Nov 06, 2015 | Refrigerators
What I check for the leak seams to be only when the ice maker is on
I appreciate your inquiry, Deo Huggins!
I understand that your icemaker is leaking water inside of your Electrolux refrigerator. It sounds like a possible crack within your water filter and that is causing water to build up into your icemaker or it could be an issue with your water valve. I would suggest removing your water filter ad making sure there is no visible damage to the outside of it. If you do not see any damage I would suggest having a professional technician come out and properly diagnosis your refrigerator. Best of luck! -Matt
Nov 21, 2014 | Electrolux Refrigerators
Ice not forming in ice tray
Hi - there are several problems that can cause this - but ultimately, if your freezer is keeping frozen foods frozen, the problem is lack of water flow.
Most automatic ice makers work on a timer. At a regular interval, if the ice maker arm is down to signal a "not full" ice bin, the heater on the bottom of the ice form turns on to break the bond between the ice and the mold. After a short time, the wiper linkage turns to allow the wipers push the individual cubes out of the mold and fall into the bin. After that, the solenoid on the water line is energized that will allow the water to flow to the ice maker to fill the mold, and then shuts off.
The water may pass through the filter inside your fridge (if equipped) and the filter may be clogged (if you can dispense water from your fridge and it works - this not likely to be the problem). Some fridges require a filter to be present - other will work without a filter - but none will work with a clogged (or frozen) filter. Make sure the fresh food compartment of the fridge is not freezing the filter.
Most of the ice maker functions are silent - except for the sounds of the ice dropping into the bin, and in some cases, the "snapping" or "clicking" of the water solenoid turning on and off (coupled with the sound of water running).
See if you can hear this happening. If you do, the problem could the either the flexible water line or the point of the water line attachment to the cold water pipe in the house. If you moved the fridge out for any reason, it is possible that the water line has been kinked or crushed when the fridge was moved back into position. If it has been undisturbed, it may be related to the valve that supplies water to the fridge. Sometimes, a clamp-on pipe piercing valve is used to connect the smaller fridge water line to the cold water pipe in the house. It is not unusual for these to give trouble after several years - particularly in areas with "hard" water. It may be worthwhile to replace this if it has been installed for some time.
Lastly, it may be the ice maker itself. It has heaters, switches and motors - any of which can fail and cause trouble. You could pour water into the the maker with a watering can or similar and let it make ice as normal. If ice is never dropped into the bin, then something on or cabling to the maker itself has failed and will likely require professional service or replacement as an assembly.
These should get you going and may pinpoint the issue - good luck!
Apr 08, 2013 | Refrigerators
No water going to ice maker
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool GC5SHEXNS Side by Side...
Ice maker not filling with water or making ice- GE pfss6pkwss
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 01, 2009 | Refrigerators
Q: Does the water for the ice maker go thru the in-fridge filter?
the water should go thru the filter first then to everything else.
Jan 02, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
the feed line of the water source is bad replace it you will also need to clean the ice makers insides to remove the rest of the contamination
and 2 more suggestions:1) change the filter - older refers have the filter in the water line serving the ice maker - newer refers have the water filter in the refer (it looks much like an auto oil filter); 2) do not store ice for extended periods when ice use is not high e.g. during cooler months. Unless you use a full basket of ice over say a few weeks you should dump all and start over periodically.
thanks.
Sep 16, 2008 | Refrigerators
Ice maker not working
what filter? drying filter? Water filter? Dust Filter?
Jun 24, 2008 | Frigidaire FRS26R4A Side by Side...
WH95TP-03, won't make ice
The machine in let water filter is block clean the filter and check the water flow
Jun 24, 2008 | U-Line Icemaker
Kenmore 57029 Side by Side Refrigerator Logo
267 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
