Question about NEC VT800 LCD Projector
With the NEC VT800 mounted on ceiling, the picture is upside down. How do you flip the picture? Also, the S-Video cable is hooked up properly to the dvd player as well as the NEC VT800, but still we get the blue screen. How do we get the movie to show up?
chris5563
  • 37 Answers
SOURCE: picture upside down b/c of ceiling mount
I assume you mean a VT491?
Manual link below:
http://www.necvisualsystems.com/cms/documents/UserManuals/RS232BaseMasterProjectors_rev3.0.30f.pdf
Posted on Nov 09, 2007
SOURCE: Need to invert the picture--ceiling mounted
The SYSTEM menu provides options for ceiling mount and rear projection. From the main menu, select SYSTEM, move the cursor down to CEILING and then click the SELECT button. That should put a check mark on that option. Then go to PREVIOUS and finally EXIT the menu,
Posted on Sep 28, 2008
projdoc
  • 2237 Answers
SOURCE: nec projector
go into menu, under image, and chose ceiling.
Posted on Aug 04, 2009
projdoc
  • 2237 Answers
SOURCE: upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Posted on Jan 11, 2010
projdoc
  • 2237 Answers
SOURCE: I need to flip the image on the Infocus In2104
go into the menu, go to settings, image, and select ceiling (it's probably on "front" right now).
Posted on Mar 09, 2010
Testimonial: "Great information. Just what I needed."
Optima Optima hd81 projector mounted on ceiling now picture is upside down
There is an option in the setup menus to re-orientate the picture, to flip it either vertically, horizontally or both to correct for the various installation options. You should be able to correct it quite easily :o)
Mar 29, 2014 | Hitachi PJTX100 Multimedia Projector
Runco picture upside down
Yes possibly because you have done a complete system reset and not a lamp hour reset so you will need to go into image or screen settings and select front view ceiling mount configuration
Apr 14, 2013 | Office Equipment & Supplies
Infocus projector is showing upsidedown picture, what could be the problem? hooked up to dell desktop
Sounds like you have to scroll thru the video settings upside down is the setting for projectors mounted on the ceiling simple fix though you may have to stand on your head to read the setting options :0)
Jul 15, 2011 | NEC VT465 Multimedia Projector
Will turning your television upside down damage your television?
No it will nNo it is not. In fact some televisions are designed with this in mind. Usually this is done with smaller televisions that will be mounted. On those televisions there will be a picture flip or reverse image/invert image setting. I have spoken with bewildered seniors with upside down pictures and advised them to simply press picture flip until their image is right side up again. There are some customers that mount their televisions in bathroom mirrors or on the ceiling, under kitchen counters, and etc. who have found this to be most helpful.
Jun 13, 2011 | Televison & Video
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
Projector is mounted on the ceiling and display is upside down. how do I fix this?
Go to the setup menu and change the orientation. You will have a number of choices. ex. Ceiling front, ceiling rear. Select the position that the projector is mounted and the picture will reorient and display correctly.
Aug 25, 2010 | NEC MultiSync LT280 LCD Projector
I mounted my In Focus Projector upside down because of the ceiling mount I bought for it. Now the picture is upside down. How do I fix this?
Go to the Setup menu and select Orientation. In here, you will want Ceiling Front or Ceiling Rear depending on how you are using the projector.
Some projectors won't let you into the menus unless there is a computer connected. I'm not sure if this is one, but keep it in mind if you have trouble.
Sep 28, 2009 | NEC VT465 Multimedia Projector
Upside down picture
YOU most likely have the thing mounted upside down that all
just flip and check the instructions
>if it is hooked up through a pc you will have to change the settings in on the pc( graphfic/diplay) ROTATE 90degress
PLEASE be kind if i helped and post more if you need help RATE this userKindofcheap
Aug 31, 2008 | NEC VT465 Multimedia Projector
Nec projector
Apr 08, 2008 | NEC VT37 Multimedia Projector
NEC VT800 LCD Projector Logo
59 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
