Question about Garden
Little fingers have been turning the throttle & carb screws on my lawnmowers Tecumseh AQ148 engine & now it 'hunts' & struggles to run at full throttle. What are the settings?
    Problem Solver:
  • 14 Answers
With many engines, you can start by screwing them all the way in. Turn each about a half turn out at the same time. try to start it. Turn a little more each. Again start it. Eventually, it will run but listen to how the engine runs. It should not be super revved up nor should it sound like it is barely staying running. Adjust one screw at a time to fine tune it once you get it to stay running. Either it will need more air or more gas. Take it for a spin..how does it cut? Does it bog down in normal grass? You may need to give the gas another half turn. Half turns on the screws to 1/4 turns once you fine tune it. Once it purrs nicely, see how well it cuts without bogging down. I hope this helps. This is the way I adjust all of my smaller engines. Make sure you check your plug and ensure it is still good before you do this and that your gas is not spoiled too. Please let me know if I have helped or if you need more help.
Posted on Apr 21, 2010
I used common sense & adjusted until I reached a setting that was suitable for me
Posted on Sep 13, 2009
I have a Suffolk punch 14 s with a Tecumseh engine model number AQ148 when I turn off the throttle petrol leaks out of the air filter please could you tell me how to fix the problem. Many thanks Neil
If engine runs fine and thats only problem the quick is a fuel shut off valve install and turn gas off before shut engine off or I think it is fuel float in carburetor that will need to be set or replaced.
Jun 16, 2015 | Tecumseh Garden
13 hp tecumseh riding mower engine surges when mower is not engaged. It runs well when mower is engaged
"Govenor hunting" caused by a lean condition ,carb is starving for fuel ! Dirt in carb or water,or out of adjustment ,or leaking throttle shaft ....usually it is a plugged low idle passage,that causes this condition,and is almost impossible to remedy,but a good cleaning might help .....does it only governor hunt at low idle ? If so thats the issue !
Jun 05, 2014 | Tecumseh Garden
MTD snowblower with Tecumseh engine 8 hp stalls out when chock is adjusted to run position
hello ,your engine is a tecumseh HMSK90-156525D, Sounds like carb. may need adjusting. Take the heat box off to expose carb. the heat box is the metal box surrounding the caeb., there should be 2 adjustment screws- 1 on the bottom of the bowl and 1 on the side of the carb just above the edge of the bowl ( depending how the carb sets off the engine - if the carb comes straight out it will be on the side facing towards the front of the snow blower or if it goes towards the handles then standing other side of the snow blower the screw will be facing you), turn both screws in til they just bottom out the turn them out 1 1/4 turns out then start the machine. While the machine is running at low idle turn the screw on the side of the carb. in (clockwise) a little at a time listening for the engine to start to rev up and then start to rev down, bog or studder then turn back slightly to bring idle back up. Once the idle is up then the screw on the very top of the carb. turn that out to lower idle to a normal idle. Repeat those adjustments till you cant get the idle to go up anymore. Now for the screw on the bottom of the bowl- move the throttle up to max and turn the screw in till you hear it rev up higher and starts to bog or sputter then turn it back slightly to bring the high rev to a smooth rev. That should take care of it. If it does not solve it then the carb may need cleaning then the adjustments done again. If you need more help on this please feel free to ask. Sometimes you have to do process of elimination and you start with the easiest first. Also the adjustments should help with the carbon build up on the plug.692509.pdf (application/pdf Object)
i have included the manual to give you a good understanding of the carb, page 7 to 25, hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you.~~
Feb 23, 2012 | Tecumseh Snowblower Snow Blower Starter...
Stalls when chock is in run position
i have included the manual to give you a good understanding of the carb, page 7 to 25, hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you.00
Oh318sa
Jan 27, 2012 | Tecumseh Snowblower Snow Blower Starter...
Toro lawnmower model 20027. The engine starts fine, but goes to full rpms. I have closed the throttle with my finger but it goes back to full rpm operation. Everything seems fine on the mower. i just got...
"Most likely you'll have to remove the bowl nut, under the carb's bowl. You'll most likely find varnish in the jet, or maybe water. These are some typical jets, Tecumseh. Briggs, similar" (baymee LehighValleyPA, 2009).
I'm going to try this tomorrow myself!
Aug 27, 2011 | Toro Personal Pace CARB Walk Power Mower
With engine started and full throttle, engine speed surges up and down. If I stop linkage from moving speed is constant and stays that way for a few seconds after releasing it. This is its third winter...
Engine hunting is due running lean ( fuel starvation ) there is a blokage in the fuel feed, or in the carb main jet, to clean this properly you need to remove the carb, remove the float bowl, the main jet will be screwed into the centre of the carb, normally a brass jet, once removed blow out the carb bwith an air line to remove dirt trapped in other places.
Feb 24, 2011 | Garden
How do I change a worn Carburettor Gasket and Diaphram on a SP470 B&S Engine on my Mountfield Lawnmower? I'm good at DIY. The engine is hunting and running erratically.
Hunting and erratic operation are signs of air leaks or diminished fuel flow at WOT settings.
If this mower is running a vacu jet style carb with a diaphragm you simply take off the air cleaner, the vent tube, and then the four screws holding the carb on the gas tank and after the carb body can be lifted remove the throttle linkage so you can flip over the carb and pull the main jet and clean the inlet screens.
http://www.psep.biz/store/briggs_stratton_carburetor_kits.htm
Aug 11, 2010 | Briggs & Stratton Garden
8hp Tecumseh engine how to adjust carb. when I put throttle on high it sputters drop the throttle back down its okay?
These symptoms indicate a rich mixture. Assuming the carb is the original (and therefore correct) one, and that it has an adjustable main jet, turn in the main jet adjustment screw on the bottom of the float bowl until the engine runs smooth.
If there is no adjustment on the float bowl, the carb will have to be removed and properly cleaned (ultrasonic cleaner recommended).
Oct 01, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
306 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
