Question about De Dietrich DOC310 Electric Single Oven
De Dietrich Oven - Clock tripping back to 00:00 means I cant turn
Which part I have to replace?
    New Friend:
I tried this and it worked well. Surprisingly easy fix. Thanks for the info in the above post.
Posted on Jul 26, 2015
The part that needs replacing is the clock timer.
FIRST: ISOLATE THE CIRCUIT.
The front fascia is held on by three clips. Take off the two knobs and gently pry away the fascia fron the left, right and top centre.
The clock timer is held in by four plastic push clips at the top and bottom about 1cm in from the end. Push them in and pull the timer out.
There are now three wires on push clips attached at the back.
Do not take the colours for granted. On my oven just repaired the Live was Black and the Neutral was Red! The black marked 'C' is the input. The side by the trip switch is the output. The Red goes on the other side.
When the timer trips it causes the circuit between the input and output to break.
You have two options now:
Read the serial number of the timer and try and order it (expensive), swap the cables over.
Carefully run an electrical cable between the push clips on both black cables making sure you leave no exposed wire. Your timer and clock however will never work, the oven just does not care about it anymore.
Note: I am not an oven engineer, I am an electrical engineer in another field and have tested voltages and current and believe this to be safe. I have done this on my own oven.
Posted on Sep 16, 2011
De dietrich oven clock tripping out
I already explained, you need to replace the big 1.5uF Capacitor that
is reponsible for the voltage drop from 220V to about 10V. You need to
remove the timer controler module from the oven, in the meanwhile you
can shunt the 2 wires that usually are shunt by the relay, and then
buy a new capacitor and replace it with a soldering iron.
Good luck.
Apr 11, 2013 | De Dietrich DOC310 Electric Single Oven
How to get the heating element out of the large oven in a De Dietrich DOD348*
If you mean the element at the back (not the bottom one), inside the oven undo a screw at the back to reveal the element, then undo one more screw attaching the element. THEN, totally disassemble the oven, removing all the cladding, taking off the top oven and controls, detaching lots of wires to be able to do this, in order to finally gain access to the 2 little nuts securing the element behind the oven. Then if you're not sufficiently dismayed by De Dietrich's design skills, email their customer service to be given the wrong part recommendation at twice the price of an independent supplier. Finally, buy part from independent supplier, spend several hours dismantling and rebuilding oven. Then it will work. But maybe don't ever buy De Dietrich (Brandt) again!
Dec 22, 2009 | De Dietrich Ovens
Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
The oven won't come on, the digital timer just flashes continuous
Hi
have you tried setting the clock as the oven wont work if the clock is not set. hope this helps
regards dan
Mar 19, 2009 | De Dietrich UMP404 Powerclean Stainless...
De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
May 13, 2008 | De Dietrich DOC310 Electric Single Oven
De Dietrich oven not working!
I suspect that it is the oven lock that needs replacing. I bought a De Deitrich oven (pyroclean) in Sept 2007. The oven failed to heat in Aug 2009. The oven lock needed replacing which meant the unit had to be removed from the wall. It was replaced under guarantee but failed again in June 2010 and was replaced at a cost of €140 by enginneer. I am very dissappoined in the oven and expected to have no problems with it considering the DeDeitrich name. I would not recommend it to a friend. By the way the clock is easy to use if you follow the instructions exactly. Oven used by two careful owners only.
Mar 31, 2008 | Ovens
Clock problem
had same problem but didn't fix it because i don't use the clock. after a few months it got worse, can't set the time (clock always flashing) so the oven doesn't work.
Jan 21, 2008 | De Dietrich DOC310 Electric Single Oven
My oven keeps turning itself off
the oven may be trying to protect itself because of a faulty device that says "I'm too hot". As electric clothes dryers have a thermal high temp limit switch to protect them, look for this device (may be 1 inch round with 2 wires connected) and replace it
May 24, 2007 | De Dietrich UMP404 Powerclean Stainless...
De Dietrich DOC310 Electric Single Oven Logo
517 people viewed this question
Top De Dietrich Ovens Experts
ashburton
richie46
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
