Question about Garden
Install springs on briggs&stratten carb. on Mclane edger
5 Suggested Answers
moretons
  • 155 Answers
SOURCE: I just went to start up my older model McLane gas
i would check the thread where your plug screws in it can be fixed with what they call a helicoil thread repair kit hope this helps.
Posted on Jul 25, 2009
RonPark
  • 855 Answers
SOURCE: can not start garden edger made by mclane
O-kay engine and motor are the same. I'll have to do some checking on this one and I'll get back to you.
Posted on Oct 02, 2009
vincob
  • 718 Answers
SOURCE: I'm changing the cutterhead bearings
Was it packed with grease when you took it apart??? If there are gears there lubricate yes! Good Luck..
Posted on Mar 12, 2011
SOURCE: Purchased a Troy Bilt Edger model# 258-554E011
I purchased a 5 HP Briggs & Stratton outboard motor which did not have a operators manual. Is there a free site that I can download this manual from?
Posted on Sep 16, 2011
Looking for a briggs and stratten manual for model 445677 rebuild carb
here is a lilnk to B&S with your engine listed. ;hope it helps
https://www.briggsandstratton.com/na/en_us/support/results.html?searchrequested=445677
Oct 09, 2016 | Craftsman Garden
How to hook up governor springs on a 3.5 engine
Google the Briggs and Stratten web site, it has all your answers.
Aug 21, 2014 | Briggs & Stratton Garden
3hp. Briggs and stratten motor
Yes . Do not mix oil and gas like a 2 stroke engine. You may need to use a higher grade fuel than regular. It will run better and start easier.
Jan 18, 2014 | Homelite Garden
What kind of oil to use for mclane 801-3.5RP edger
Gene you can use a standard lawn mower oil in any small machine like yours
Oct 20, 2013 | McLane Walk Behind Edger 801-3.5RP
I have a mcklean 3hp edger that won't start it tries were can I find how to fix this problem repair manual for the carb
If this is an older edger with a 3 hp Briggs and Stratton engine, there is a diaphram in the side of the carb. Look for a plate approx 1"x1.5" with about 6 screws in it.
Remove those screws, and you'll find a paper thin rubber diaphram and a spring. Replace that diaphram, you can use the old spring. There is one spring loaded carb adjustment screw, close it all the way, and then open it 1 and1/2 turns.
Sep 19, 2011 | Garden
Briggs & Stratton 60200 series engine intake valve tar
I'm having the exact same problem with a Briggs & Stratton 80202 engine on my Mclane reel mower. I cleaned out the valves and cylinder head, put it back together and it runs nicely. I ran it for about a half hour then turned it off to adjust the blade. A couple hours later I went to start it and no compression. The Intake valve is stuck open with gum from running it for a half hour! The can of gas I have is less than a month old. I'm going to try a different brand of gas.
Jan 09, 2010 | Garden
Can not start garden edger made by mclane
Oct 02, 2009 | Garden
Have to choke to keep running
this is not hard to do here is what you need , 1 can of carb cleaner anykind will do , a 10 mm rench to remove the bowl 7/16 socket . now remove the carb take a good look where the spring is before you take the carb off it muct go back in the same hole , now that you have it off take the bowl off remove the float place to the side here is the fun part look in the carb you will see some small hole spray them this will clean all of the old gas out if you can let it set for about 10 min then do it again blow out with air if you have one nothing else to do but reinstall this works most of the time ...Good Luck..
Aug 16, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
