Question about Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Sharp LC-37HV4U not turning on
Good evening, i have this unit and it doesnt wanna turn on. All i see is the red light blinking and nothing happens. Sometimes when i press the power bottom stays steady then flashes.
  • 2 more comments
  • Anonymous Dec 16, 2007
    same exact thing
  • thomasts May 27, 2008
    help ~~~ anybody has solution, pls help
  • diefromxxfor Jan 21, 2009
    is there any way to fix this at all.. the 1st and 2nd solutions sound lame and didnt work either
  • Anonymous Mar 21, 2014
    does sharp have software updates for the lc-37hv4u and how to install
Hold down the input button and volume - while the MAIN POWER BUTTON IS OFF. Then turn on the main power button while those are held down, the light on the tv & avc box will turn green, then immediately let off the 2 buttons and press volume +. Next step is to repeat the process about 20-40 times & the TV WILL WORK!. I have read that this may have something to do with the energy star compliant commads that can changed through the serial port.
Posted on Aug 03, 2008
    Problem Solver:
  • 6 Answers
Thank you, psxpirate25!!!! It worked. I had to repeat it about 35 times. It came up in a factory setup firmware mode. I could see the video behind it. Pressing buttons on the remote only switched between the settings menus. I power cycled it a couple of times and had to do another 35 times. Finally it worked! Totally awesome!
Posted on Aug 13, 2008
  • 1 more comment
  • AirmanB29 Aug 14, 2008
    Well, that was last night. Tonight, tried to turn it on with the remote and it is doing the same thing again. Tried the power button thing again, but it does not work this time. It worked for a few minutes, but as soon as I turned it off, it was lost. Seems like the control box is doing some kind of flaky firmware thing.
    There sure are a lot of people having the same problem with their Sharp TV. I don't think I will ever buy another one again!!
  • AirmanB29 Aug 15, 2008
    OK. Here seems to be a solution that is working now. Unplug both the
    AVC and the panel (I used a power strip to make this easier by just
    turning off the strip and back on again). With the AC removed, press
    the "MAIN POWER" on. Next, press and hold the "VOL (--)" and "INPUT" at
    the same time. Finally, plug the AC power back in and the set should come on.
    After it came on, mine was in a factory test mode. I had to enable the
    write mode (I think it writes to the PROM) and then selected the second
    line down on the first menu (1 of 15 ) to have it do the restore or
    something.
    Finally, my set came up with OPC enabled to auto and it seems to have a
    sensor issue. At night, the monitor is unwatchable with such low light.
    So, I turned on a bright light near the monitor and set that to
    "Manual". so far, for two days and nights now it has been working
    again. I hope this helps. Good luck! -Brad
I had the same problem with my lc-37hv4u and i changed the following board: Sharp Main Board KB453DE XB453WJ. If your a little handy you can do it yourselfand save $150.00 bucks. The only proble is trying to find a new board, which will cost about $300.00 or if you can search the net and find a used one for much less, but make sure they are willing to take it back if it doesn't work. good luck.
Posted on Dec 25, 2008
Samsung TV not turning ON. My email address is prk Please help... Much appreciated.
Its power supply I will tell you how to fix you need to get few things first
Jan 29, 2016 | Samsung Televison & Video
Sharp aquos LC-37HV4U won't turn on just have a red light. I have unplugged the display and the AVC system. Turned back on then get a blinking red light. Turn on at the display and to goes to solid red...
when this occurs this is got only meaning: the Ignintion panel is faulty its the board/chip that gives the signal to the TV to start
to replace that part u must a serious soldering skill and and take to much risk cuz u might make more damage on that TV
plz do rate this post as good as u can
Oct 10, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Display powers of with power up of AVC
how many blinks does the red light give in a row? This would be an error code?
The problem for 7 blinks would be an Interface board. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. You can replace the board with a new one and update the software on the new interface board.
If is isn't 7, let me know and I will help you out with this
thanks
Apr 26, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
My Sharp lc-37hv4u wont turn on. I just jave red light. No image, no sounf
If you are a DIY then once you pull back off you will see power supply board and there are caps that goes bad in these sets. They bulge out and sometimes explode. You tube has video on how to fix some sets, this is the same procedure
Jan 03, 2011 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
My sharp aquos not working tv went off and wont
these flashing lights are error codes set by the manufacturer..
Call sharp...they will tell you the problem
Apr 26, 2010 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
My Sharp XR-11XC Projector died not long ago with very few hours of use. The unit will not power up nor does it show any signs of trying to. No LED lights, no fans - nada. I tested the fuse and it's...
I opened mine up hit the red reset in the front and now all good. If ur red light is blinking make sure ur lamp compartment is shut properly, if not the red light will blink and unit won't turn on.
Mar 26, 2010 | Sharp XR-11XC Multimedia Projector
Sharp Aquos LC-37HV4U 37 in.  LCD HDTV Logo
2,909 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
