Question about Whirlpool Washing Machines
My Whirlpool LSR8233EQ1 washer is not agitating.
SOURCE: Agitator does not agitate unless I add presser downward on the to
There are 3 plastic dogs that have teeth. They become worn smooth and will not engage the agitator. Change these for about $12 and you will be back in business.
Posted on Jun 07, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
aasc
  • 1606 Answers
SOURCE: I hae a Whirlpool LSR8233EQ1 Top loading washer.
If you can catch it running while in the spin cycle but not spinning ( put a butter knife or screwdriver in the lid switch hole ) and wiggle the timer knob . If it starts spinning during this process , the timer needs replaced . Sometimes though , when a washer does everything BUT spin and you hear the motor running , the transmission is the problem .
Posted on Aug 16, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Agitator is not rotating properly
thttp://www.repairclinic.com/ this site has a kit and, instructions to repair the agitator over running clutch dogs on your machine
Posted on Sep 01, 2009
washdryman
  • 154 Answers
SOURCE: Whirlpool /Roper washer won't drain or agitate.
LID CONTROL SWITCH BAD
Posted on Feb 07, 2010
How do I change the dog agits in the ultimate care whirlpool topload washer model lsr8233eq1
Remove number one then 23 then number 2
Then remove the agitator. Set it on the floor and yank it apart. Install the new part being careful not to break the retention tabs on the base of the agitator. Here is a nice video which shows how it is done:
More videos and a service manual are HERE
Nov 19, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't spin, LSR8233EQ1
with out help from you!!!!!!!!!!
Nov 21, 2009 | Whirlpool Washing Machines
use flat screwdriver in slot in cap to see dawgs(4)replace them
Aug 31, 2009 | Washing Machines
Aug 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Jul 23, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WHIRLPOOL TOP LOAD WASHER MAKING GRINDING NOISE FOR AGITATION
When you put the motor in did you replace the coupler between the motor and transmission? When fixing the agitator you need to get the agitator repair kit, It has seals, dogs,thrust plate, cam bearing and seals. The upper agitator is supposed to move only in one direction to get the clothes to move down towards the agitator. Do not overload machine. I have one of these and after 12 years I finally had to install this upper repair kit because the upper agitator quit moving. You may have an agitate cam that is going bad inside the transmission
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Jun 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How do you get the top console of whirlpool washingmachine model # LSR8233EQ1
behind the console ,on the right and left ends thres a recess with 1 phillips head screw ,,losen dont take out then flip console back
Dec 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer
hi thanks for the question. the cabinet has to come off.to do this. 2 screws 1 each corner of the console. remove. lift the console. 2 brass clips on top. remove. disconnect the wiring for lid switch. pull cabinet off. put washer on a block to raise it . its easier. . remove the clips that hold the pump on the motor. remove the motor. 2 screws 2 clips. replace coupling thanks the appliance doc
Oct 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
273 people viewed this question
Dan Webster
Dan Webster
Sal De
