Question about Panasonic ToughBook 52 Notebook
While traveling I bent the left hinge for the lid of my panasonic CF-52. I was able to fix this but I had to remove the panel above the keyboard. There are four wires on the left side. I had to disconnect them, however I do not think I connected the correctly as my wireless does not connect in noisy environments anymore.
  • steven_i_dav Sep 12, 2009
    there are four wires. do you have a diagram or can you tell me the order they go in?
  • Chip
    Chip May 11, 2010
    You most likely have your antennae leads backwards. Reverse them and try to connect.
    President:
  • 2,600 Answers
I'll try to hunt down a schematic for you......
Posted on Sep 12, 2009
  • Chip
    Chip Sep 12, 2009
    This is what I have found so far....your laptop might have two wireless cards in it.
    There may be a second wireless adapter slot on the underside of the notebook.
    To get to it:
    Remove the L-shaped access plate adjacent to the "Battery Release"
    switch and immediately below the
    handle. (The single screw requires a
    special screwdriver, size T-5 or T-6.)
    Remove the two securing screws, remove the two leads (one gray, one blue) and slide the adapter
    AWAY from the handle. This is the wiring for one of the cards so I would guess that the other two leads go
    to the second card. Process of elimination. Hook the wires up and test the connection. If you don't get a good signal, try to reverse the leads and see if that straightens things out. That's all I can dig up as of right now.
How do I replace my keyboard on a CF-52
For the Panasonic ToughBook CF-52 series of Notebook PC's, it's a little tougher to remove the Keyboard, than per se other models.
1) With all repair on laptops first remove ALL power.
Remove the AC adapter (Charger), and Battery.
2) Next you should follow Anti-Static Precautions. A little more on this as to why as you read, but you'll also see you will be very near the Processor.
A Processor is the most susceptible hardware component in a computer, to Static shock.
(It's close to the Keyboard Lid Plate under the Keyboard)
Anti-Static Precautions:
Your body carries Static electricity.
Static can fry out (Short Circuit) the delicate hardware components inside a computer.
The best method is to buy, and wear an ESD wrist strap, and connect it's alligator clip to a good ground source. (Electro Static Discharge. About $5)
The next best method (Debatable) is to place a large metal object on the table, and touch it before disassembling the laptop, and occasionally during.
(Metal serving dish, metal knickknack, etc.)
3) Components to be removed in order; [Straight from the Service Manual]
A) Power, as mentioned
B) The HarDDrive and it's mounting kit.
C) The DVD optical drive
D) The Tilt Panel Assembly
Simply the top outer cover along with the LCD screen that is mounted to it.
The part you tilt up and look at.
E) Keyboard Lid Cover
F) Keyboard
4) Use a multi-compartment container for the various screws you will remove. Mark each container for the area the screw/s come out of.
DO NOT mix them up!
[Some screws look very similar to other screws, plus they are S-M-A-L-L.
Put a screw in the wrong hole, and it may seize halfway in.
Cannot remove it without damaging the laptop, and cannot screw it all the way in.
You can substitute using a multi-compartment container, and use a clean egg carton instead.
Label each egg holder]
Make drawings, and notes if you wish. A guide to return to in case you are interrupted.
5) This is a link to the Service Manual for the Panasonic ToughBook CF-52 series of Notebook PC's.
It is for a CF-52EKMxDxM, but will work for all CF-52 series models, (Manual is free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-panasonic
Page 24 for the Disassembly Flowchart
Page 25 for removing the HarDDrive, and it's mounting kit, plus the DVD optical drive.
Page 26 for the Tilt Panel Assembly
Page 29 for removing the Keyboard Lid Plate, and Keyboard.
I'm here for additional questions please post in a Comment.
Regards,
joecoolvette
Jun 21, 2011 | Panasonic ToughBook 52 Notebook
How do i remove and replace the keyboard on a panasonic cf-52 laptop?
There is a plastic piece above the keyboard, pry that off gently, take your time, then remove the screws underneath it that holds the keyboard....make note of the keyboard wiring how its plugged in before you remove the cable, plug in new keyboard and replace everything you took out...should take 15 minutes.
Jul 04, 2010 | Computers & Internet
Can you buy replacement keys for the panasonic cf 52
Go to ebay and type in your laptops model + keys or keyboard in search box to get plenty results. Good Luck
Apr 26, 2010 | Panasonic ToughBook 52 Notebook
Panasonic toughbook cf 18
You will, at the very least, need to have the screen and screen cover replaced. If the hinges also damaged the bottom case to which they are attached, then it too will need replacing.
If you can't get it repaired locally, let me know.
Jan 09, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Need to disassemble
to remove the keyboard on the cf-18 keyboard you must remove the 4 screwsby the ESC, F4, F10, and PAUSE key. once removed lift the 2 covers and holding the keyboard from Function key sides lift up slowly. There are 4 sticky tapes holding the keyboard, once some of the tapes are off you can slide the keyboard up towards the LCD to remove. The connector to the keyboard can be removed by removing 3 screws from the aluminum center cover found under the keyboard
Jul 17, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Keyboard lights on CF-52
To Control Keyboard lights on CF-52
FN - Up Arrow
or
FN - Down Arrow
May 31, 2009 | Panasonic Toughbook 52 Notebook...
Want start unless you slam lid or push start knob in and out
HI, Check and see if the door hinge screws are tight. Sometimes the hinge loosens and the lid switch will not activet properly. It the lid is tight, you might have a lid switch going bad. The lid switch is located under the control panel. There is a screw in each corner of the control panel in the back side. Loosen these screws and lift the control panel up and it will rest on the hinges.
Ths lid switch is to the left and should have three wire to it. Parts# 8318084
I hope this helps you. If I can assist you further or you need a place to order the lid swtich, please give my web site a chance at www.whirlpoolpartssurplus.com
Thanks
Vic
May 22, 2009 | Washing Machines
Instructions to replace the LCD screen on a Panasonic CF-52 Toug
Trying this link to see if you can get this information.
Its Panasonic's website, toughbook section
Also try this link.
Mar 19, 2009 | Panasonic Toughbook 52 Notebook...
Gateway left hinge broke
Definately an easy fix.
I suggest looking on eBay for a donor chassis.
Sometimes they can be had relatively cheap CLICK HERE (this one has both hinges broken however) - and sometimes just the parts you are looking for are available CLICK HERE (this is for the RHS one though).
An entire donor PC is adviseable, because usually the repair is not just the hinge that broke - as the rest of the lid is plastic!
Once the trim above the keyboard is pried off, you will see the monitor cable, and hinge screws.
The trim around the monitor must be dis-assembled and pried into 2 parts.
Then the hinge & Support are either screwed into the side of the screen, or the back of the lid.
Most look like this...
Replace reverse of removal.
HERE is a link that will describe it better and give you a visual reference.
You are interested in step #s 7, 8, 11, 12
Once the screen is free of the chassis - its time to remove the little rubber scerw covers in the lid, and disassemble.
Good Luck!! Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 02, 2009 | Gateway MX6448 Notebook
Keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
Jan 04, 2009 | Panasonic ToughBook 52 Notebook
Panasonic ToughBook 52 Notebook Logo
162 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
