Question about Dell Inspiron 6400 Notebook
My cd draw is stuck in the cd drive. How do i get it open
    Problem Solver:
  • 11 Answers
You should find a paperclip and straighten it out, on the front of the CD drive there will be a small hole just big enough for the straightened paperclip to fit in. Push it in until you feel tension and it should start to manually open.
Posted on Sep 12, 2009
  • 3 Answers
You should find a little hole on the CD drive itself.
If you straigthen out a paperclip and push the paperclip in gently to the little hole on the CD drive you should be able to open your CD-ROM drawer.
Do not force it, if you cant do this and the drawer doesn't open easily then you need to take your laptop in to your nearest computer repair centre and ask them to take a look.
If you are located in the Greater Manchester or Cheshire region and require further assistance then visit www.geek2door.com and can arrange a qualified engineer to visit you at home or work if necessary.
Posted on Sep 13, 2009
    Problem Solver:
  • 7 Answers
Quick tip to open a stuck CD/DVD drive on a computer on the drive there should be a very small hole unbend a paperclip until it is straight and push it into the hole on the CD/DVD drive until it opens up if that fails come back here.
  • 65 Answers
The front panel of your cd rom has a pin hole, push a pin or paper clip into it and the door will open
  • hcsr
    hcsr Sep 12, 2009
    the front panel of your cd rom has a pin hole, push a pin or paper clip into it and the door will open
  • 57 Answers
There should be a small hole on the drawer into which you can insert a paperclip. Push easy and the drawer should open.
My CD Player Draw Will Not Open
If there is a co in it then it probably fell out and is stuck... especially if it was shaken.... unplug the unit.... remove the screws holding the case together and open it up
Oct 16, 2014 | Electro Brand Nostalgic Stereo CD Music...
The tray is blocked. When I try to open it, I hear an ugly humming sound. The cd stuck inside can still be played. how can I open the blocked tray? I read that there is a emergency button under it, but I...
There is no easy quick release to the Drive Door. You have to take the cover off of the Player and in the front of t he drive tray there is a small motor that has a small belt on it. If that belt breaks of falls off of the pulleys, you will hear the motor spinning and then it gives up. You can remove a plastic plate over the motor and pulley and manually spin the drive gear to open the Draw and remove the Disc. The belt shuold be available online.
Jul 06, 2014 | NAD C541 CD Player
Cd drive xhnge
On the front of the CD rom there is a small pin-size hole, carefully put a drawing pin into the hole and it will open the CD drive manually, if it doesn't read disks anymore consider replacing your CD drive
Apr 17, 2014 | MSI Computers & Internet
Unstick dvd drive window
The draw has been knocked off it's normal line, When you have powered on your computer with a small thin piece of steel like a knife or thin bladed screw driver push the button on your CD/DVD and gently try to pries open the draw if successful it should zip out under it's own power after it reaches a certain limit. If you have to manually open it all the way then it is time to think about a new drive as this tells me that the ejection mechanism has failed and it is cheaper to buy a new drive than to have that drive fixed. If you are unable to get it open at all then the mechanism has ceased in place and you will have to break the face open if you have a disk in the drive but be careful not to damage the disk as it lays only 35mm in from where the draw face is. I hope this helps.
Sep 04, 2012 | HP m7367c PC Desktop
Cd will not eject from cd drive either manually or via the device icon
Desktop? Get a small screwdriver or butter knife. Hit the eject button and pry it out easy. Then you can see what the hold up is.
Jan 04, 2011 | Acer Computers & Internet
HP Pavillion - DVD & CD drive will not open!
More or less in the centre of the draw front of both drives you should see a small hole.
Get hold of a paper clip and straighten it out, or use something similar, and press it into said hole. It should release the drive draw.
May 02, 2010 | Computers & Internet
MY DVD IS STUCK IN MY BROKEN MACHINE, HOW DO I GET IT OUT?
if your dvd drive is stuck in your ole computer!!! you need to give more info on what type of computer you have? is it a dell compaq "what"?... if you are trying to get a DVD out of your dvd drive then thats easy, in the front you will see a very small pin hole. push a pin into it and you will open the drives draw.
Aug 17, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
I have a disk that I put in my old computer, just got a new computer and can't get it in---why?
hi adpelle
is the disc stuck in a cd /dvd drive draw ?
(if so there a small pin hole on the cd / dvd unit you can push a paper clip into it to open the draw .
it's on the left under the draw this will eject the disc in side )
if not disc in draw can you post back more details of this disc and what the problem is .
reagrds
riz.
Apr 16, 2008 | Computers & Internet
Problem with cd-r/dvd rom
does the light come on on the drive ? have you tried straightening a paper clip an putting it in to the little hole to push the draw open this may make it work if its stuck or try right clicking the drive in explorer and choosing eject from there
good luck
Jan 23, 2008 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
CD-ROM Not responding
you can get the disc out by inserting a pin in the small hole on the cd draw, but when this happens it means the laser is failing to read the disc and the cdrom is failing, unfortunately the cdrom cannot be changed in the acer notebooks.
Nov 06, 2007 | Acer Aspire 3000 Notebook
Dell Inspiron 6400 Notebook Logo
229 people viewed this question
Alun Cox
