Question about Dryers
White westinghouse dryer not drying
  • catmaster Apr 16, 2008
    AEG T57800 Electric Dryer wit not dry have you a sevice manuel
Dear Expert,
When it starts, the heat element heats up and gas fire turns on for a while then turns off by itself. After that, the heat element turns on and heats up but the gas burner doesn't turn on!
What's wrong? The gas solenoid or heat senser?
Help me out, please.
Chai
Posted on Mar 19, 2009
I have the same AEG T57800 dryer.  Problem, no heat. Couldn't find a service manual anywhere on the net. Checked for fuses and saw none. Thermostats on heater appeared fine, showing current flow. Replaced heating element 112 54 84 41/8, via local dealer - Respond Services from Electrolux UK in Durham DL5 6ED (£68), still no heat.  Called service tech who replaced the PCB - 973916012018008 (£135 + £85 callout charge). Very, Very annoyed at this as the dryer is only 3.5 yrs old.
Posted on Jul 28, 2008
  • rick_hughes Jun 17, 2011
    did you find a manual in the end ... have same model with same problem
2 Suggested Answers
SOURCE: Dryer heats but doesn't dry
Sounds like it is only heating on "low". The problem is most likely a thermal limit switch/thermostat which is bad.
Posted on Apr 21, 2009
Stove pilot is on but oven wont light?
How do you know the pilot is on? Most likely if actually burning gas pilot, you have a bad oven thermostat. or perhaps valve. If your question is about the light switch itself, that is a different issue and somewhat confusing.
Feb 27, 2015 | White-Westinghouse White Westinghouse...
Why machine tumbles without drying and indicating E68?
not sure bout the code however need to check heating element with a multi meter and check thermostats also, also are u getting a full 240 at the terminal?
May 15, 2014 | Frigidaire 131758600 Washer Washing...
Westinghouse de600a0dw2
You'll have to trouble shoot it... the belt either jumped off the motor pully or it may have broke. Either way you'll have to disconnect it and inspect it. Remember to always unplug the unit when servicing it. If the belt broke it is not hard to replace. The drums are held by gravity on rollers. Simply lift enough to get new belt pass the roller. If there are upper rollers in the way... simply remove them. Don't remove lower rollers. Lift the drum enough to install the belt and replace the upper rollers, relocate the new belt and close it up. Done.
Dec 25, 2013 | White-Westinghouse White Westinghouse...
Wire a westinghouse mini pendant
if you have 120 volts on the white and red in the ceiling,try hoohking the blue to red if this is a light kit for a ceiling fan.hope this helps.
Jan 27, 2018 | Dryers
My Westinghouse LD505e suddenly stopped working during a drying cycle and it won't start. Would anyone be kind enough to guess what could be the problem and advise a solution. It's 4years old
Probably a blown fuse due to a heater element problem or maybe a bearing problem. I recently worked on one and did a movie which shows the fuse location and all:
More here
Oct 21, 2012 | White-Westinghouse Dryers
I have a white-westinghouse electric dryer and it stoped heating up. It still tumbles just with no heat.
In the back of the dryer you will find a high limit mounted to the element housing sometimes they can be reset and sometimes they just have to be replaced.They can be tested with a meter.or you can jump them out with a wire to test them .this would happen if you had a plugged vent.
Nov 24, 2010 | Westinghouse Industrial Plus White-...
Gas Dryer lights but not drying. I have a White Westinghouse gas dryer on natural gas. It has a new vent hose and the filter screen is very clean and the vent area in the door is very clean. I even...
Sounds like the dryer coils are failing. The dryer may heat up in the beginning but once it runs for a few minutes the coils fail to open and let gas in. Check to see if you can hear the flame ignite after it has been running for a little while.
for a free video on this got to www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Dryers
When I push the START button the dryer will come ON but then STOP on its own after only running a few seconds... This is a model # DE800KDD-1
that sounds like the timer is bad that is the knob you set the cycle or drying time a new one for that dryer is about $60.00 not hard to put in yourself check out this site for parts Appliance Parts from RepairClinic.com - HomePage alot of good info and how to do good luck hope this helps
Nov 11, 2009 | Westinghouse Industrial Plus White-...
Apr 21, 2009 | Electrolux Dryers
Dryers Logo
311 people viewed this question
Top Dryers Experts
