Microsoft Xbox 360 Console Logo
Posted on Sep 12, 2009
Two red lights on left side of power button, vibrating controller
The game loads all the way up the point where I begin to play, then the screen goes blank, two red rings on the left side of the power button on the console and the controller begins to vibrate.
What's up?
Anonymous
Level 1:
  • Contributor 28 Answers
  • Posted on Sep 13, 2009
Anonymous
Contributor
Level 1:
Answers
28
Questions
0
Helped
6919
Points
69
Hmm maybe your Cables are not perfect plugged in or keep your xbox off for 24 hours if it doesnt work let microsoft fix it if you dont got a waranty anymore buy a new one.
Wen i want to play a game on line that i have is ascking to do the update, the update starts then stops freezing what should i do
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
Regards.
Sometimes the console will not load to the screen where the big (xbox360) icon, the lights around the on/off button flash profusely and it seems as though the screen has frozen. if the loading gets past...
Those are common error on the XBox 360, after some extended use. You can try to send it to be repaired, and if it happens again, consider the purchase of a newer model.
The two left sides of my Xbox 360 keeps lighting up and i barely
when did you buy the cooler?
the 2 red lights only appear on the left side of the turn on for your xbox when you have played for a big amount of hours on your xbox i recommend not playing the system for a day so it allows it too cool down if you have this problem if it persist contact a support manager at Microsoft
PS3 HDMI connection issues
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
2answers
I just put a new case on my 360 and it has a clear pece that goes over the dvd drive so you can see the disc when i play for at leat 30 minuites the video cuts out the controoller continues vibrateing and...
left side, means thats your 2 red lights is your AV/HDMI cable not connected properly. 3 red lights is the ring of death. 4 red lights is the disk drive/laser has gone.
1helpful
I need written instructions for EA Sports MVP Baseball for Gamecu
hope these are the right ones
MVP Baseball 2005
BATTING
Z Button Z + A Button = Square to Bunt (release to pull back)
A Button Swing
BASERUNNING
Control Pad Steal / Choose base destination (press toward base you are trying to steal)
Slide Refer to EA SPORTS Big Play Control in Gameplay below.
C Stick Left/Right = Increase/decrease leadoff.
X Button Control runner at 1st
B Button Control runner at 3rd
Y Button Control runner at 2nd
L Button Advance/stop all runners
Z Button Advance/stop all runners
R Button Retreat runner
PITCHING
Control Stick Choose pitch location.
A Button Throw a pitch
X Button Throw a pitch
B Button Throw a pitch
Y Button Throw a pitch
White Button (press and hold) + Directional Pad Up/Down (Left/Right to toggle between bullpens and dugouts) = View Bullpen/Dugout menu
R Button Throw a pitch
L Button + X, B or Y = Pickoff attempt. L + A = Pitchout. L + Control Pad Down = Intentionally hit the batter. L + Control Pad Up = Intentionally walk a batter.
Z Button (Hold) + Control Pad Up/Down = Choose infield/outfield alignment (before pitch). Left/Right to choose a category. Z Button (hold) + C Stick Left/Right = View pitch history, to toggle at bats. Z Button + Control Pad Up/Down = View Bullpen/Dugout menu (Left/Right to toggle between bullpens and dugouts).
FIELDING
Control Stick Move fielder
C Stick EA SPORTS Big Play Control
A Button Throw to home (press and hold to power up, release to throw)
X Button Throw to 1st (press and hold to power up, release to throw)
B Button Throw to 3rd (press and hold to power up, release to throw)
Y Button Throw to 2nd (press and hold to power up, release to throw)
R Button Throw to the cut-off man
GamePlay:
EA SPORTS PURE SWING SYSTEM:
The Strike zone is divided into nine colored squares. Red squares mark the batter's hot zones. Blue squares are the batter's cold zones. Clear squares are neutral for the batter.
Take unprecedented control at the plate by moving the Control Stick during your swing.
-The results of your swing depend on your timing, the location of the pitch, and the direction you move the Control Stick.
-For the best results, move the Control Stick towards the location of the pitch.
-To hit the ball in the air, move the Control Stick Diagonal Up-Left / Up / Diagonal Up-Right while swinging. This increases the chances of hitting a fly ball, but also increases your chances of missing the ball if the pitch isn't up in the zone.
-To hit the ball on the ground, move the Control Stick Diagonal Left-Down / Down / Diagonal Right-Down while swinging. Keep in mind that high pitches are very difficult to hit on the ground.
-To hit the ball to the left, move the Control Stick Diagonal Left- Down / Left / Diagonal Up-Left while swinging. For the best results, use this when the pitch is coming in on the left side of the plate.
-To hit the ball to the right, move the Control Stick Diagonal Right-Down / Right / Diagonal Up-Right while swinging. For the best results, use this when the pitch is coming in on the right side of the plate.
TO THROW A PITCH:
1. Press and hold the button that corresponds to the pitch you want to throw. The bar inside the pitch meter begins moving.
2. Release the pitch button when the bar reaches the end of the pitch meter. The closer your release point is to the end of the meter, the more effective the pitch is.
3. Press the pitch button again when the bar is within the green accuracy zone near the beginning of the pitch cycle to determine the pitch's accuracy.
-The effect of a bad pitch depends on the type of pitch. For example, ineffective fastballs are slower than normal, and less effective breaking pitches are flatter.
-If a pitcher misses the green accuracy zone by a considerable amount, an indicator (red for hot zone, blue for cold zone, yellow for ball, white for neutral) appears to tip off the batter to the location of the pitch.
PITCH SELECTION
Your pitcher's pitch selection appears on-screen. Not all pitchers have the same arsenal of pitches. A pitcher's four-seam fastball is always assigned to A Button. The remaining pitches are assigned to X, B, Y and R Button (though not all pitchers have five pitches).
FIELDING
-If you power up the throw into the red zone, you throw harder, but less accurately, which could result in an error.
-If you select to throw to either a base or the cut-off man before the ball arrives, the fielder begins his throw immediately upon receiving the ball.
NOTE: The CPU automatically adjusts your defensive alignment based on the situation. However, you can override this by choosing the infield and outfield alignments yourself.
EA SPORTS BIG PLAY CONTROL:
Using the all-new EA SPORTS Big Play Control, you can climb the fence to rob home runs, make spectacular diving catches, slide around tags, and more.
FIELDING:
- To dive or stretch for a ball just out of your reach, move the C Stick Left/Right toward the ball.
-To climb the wall to snag a would-be home run or jump for a ball over your head, move the C Stick Up.
-To make a sliding catch, move the C Stick Down as the ball approaches.
BASERUNNING
Timing is the key to a perfect slide. Use EA SPORTS Big Play Control to create havoc on the base paths.
C Stick:
Up = Head-first slide
Diagonal Up-Left/Up-Right = Head-first slide to the left/right side of the bag
Down = Pop-up slide
Diagonal Down-Right/Down-Left = Hook slide to the right/left side of the bag
Up = Dislodge ball from catcher.
Playstation 3 shuts down as game loads
Generally there are a couple of things that can cause this. Bad installs of games, and more commonly thermal damage. The bad news is it will probably have to be repaired and Sony generally charges about $150 for that. Hopefully its under warranty? =)
There is some talk that the new firmware download may have altered physical parts that control the temperature inside the unit. Although that's just heresay i've been hearing more and more people thinking this is the case.
Screen turns off when i go to play a game
Go to
Start
Control Panel
Power Options
On left side of screen Choose When To Turn Off Monitor
Click...NEVER
2 red lights on the ring of light
Dont do those fake youtube videos this is how I fixed mine after trying endless Internet hoaxes http://xbox360repaircenter.info guarantees you be playing in 2 hours for cheap
PS3 wont take any GAMES nor DVDs
I have been playing today and just gone back on and not one game will load
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
