Question about Singer Quantum XL-6000 Computerized Sewing Machine
I have a big problem...when I use my auto. threading my arm #7 stays does while it is threading and then makes a noise but does not lift back up...then the message box pops up and states that it is not threaded correctly..when I hit the arrow to return my arm goes back up and the gold arm inside returns as well...but when I start sewing it goes a few inches and stops and states the same thing.. I also notice my thread from my spool does not move ...does anyone know why...even when I manually thread it states and does the same thing....HELP!
  • snoopy5 Dec 11, 2007
    I meant to say my #7 arm stays down :-)
  • 110 Answers
Dear snoopy5,
First of all, the XL 6000 is a fantastic machine and offer excellent value for money, but you need to take care of your machine. My first suggestion would be to check the feeding mechanism for any tangled up thread. Look carefully under a bright light. I suppose you know how to get to the mechanism by opening the light cover and swing it open on its hinges.
If it makes any noises do not try to operate the machine, as you can cause more damge.
Posted on Dec 12, 2007
Auto threader wont come all the way down...makes a poping noise
Personally, I wouldn't bother to fix it. Take a sharp pair of scissors and trim the end of the top thread at an angle and poke it through the eye of the needle. Autothreaders are usually the first thing to break.
Jan 25, 2014 | Brother Sewing Machines
Sews very slowly/thread breaks
Welcome to the world of old dried out machines. Stop trying to sew until you have serviced the machine. Start by unplugging it.
Look in the bobbin area for lint and bits of thread wrapped around things. Clean it well.
You don't say what make or model of machine but get some sewing machine oil and find the oil ports and oil, and work it free. Oil where the arms connect, oil the needle bar... if it has an external motor, remove the belt and open the motor.... pull armeture and take some steel wool to the 'copper part" grease the ends and put it back together (make sure the little shims go back in the correct spots.)
Clear and oil the oil ports at each end of the motor.
Lift the maching to it's back and oil where all the arms connect.
Work slowly and methodically. Clean old, apply new... also look for misshapen parts, bent parts, etc.
Oct 10, 2012 | Sewing Machines
I am sewing scout badges on a uniform and when I sew there is a bunch of needle thread bunched up on the bottom (the top looks fine). And the needle thread gets all caught up around the bobbin.
Clean out the bobbin area if there are any thread tangles there.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
When you forget to lift the presser foot before threading the machine, the tension control does not open to capture the thread. Then when you begin to sew, the top thread has no tension, and the bobbin thread, which does have tension, pulls the top thread to the bottom in messy loops.
Jun 25, 2011 | Kenmore Sewing Machines
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
Bobbin thread won't engage.
The bobbin case is not in the shuttle.
Raise the needle to it's highest position.
Lift the lever on the back of the bobbin case and hold it open as you insert the case into the shuttle; arm on the case pointing up. You may have to turn a bit to the left or right - it will click when in place.
Mar 20, 2010 | Brother CS-8072 Computerized Sewing...
Modle 8072 bobbin thread won't engage machine makes cick-clack noise when I press on presser foot
Have no idea what brand of machine you are using.
If this is a rotary hook bobbin (side or front insert; metal bobbin case),
there should be a lever on the back of the bobbin case.
Raise the needle to it's highest point and then lift and hold the lever of the bobbin case open as you insert it into the shuttle.
If there is an arm on the bobbin case, it should be pointing up toward the machine.
When the bobbin case clicks into place, it should work as designed.
Mar 20, 2010 | Brother Sewing Machines
Bobbin holder won't stay put
If the bobbin case/holder is trying to lift up and the thread is staying partly around it, your bobbin case may have turned part way.
Remove the needle plate and the bobbin case. The outer edges of the bobbin case should be very smooth. I suspect you may see a needle hole in the flat area that was under the foot. If so, you will probably wish to take it to your dealer and show them. They may smooth it or recommend replacing it. When the bobbin case is placed back into the hook cup that it sets in, the retainer at the 11 o'clock position on it should only allow the case to lift up about 0.8 to 1mm at the most. If it will lift up more than this, press down firmly on the retainer and move it closer to the bobbin case. You must have enough room for the thread to pass between the retainer and the bobbin case, but too much clearance will allow the bobbin case to turn in the machine and it will be damaged by the needle.
Apr 09, 2009 | Husqvarna Viking 1
Bottom threads are big loops
Your problem is the top thread. Make sure you lift the presser lever BEFORE you thread the machine. After threading the machine, just before you thread the needle, lower the presser foot, and test the top tension by pulling down on the thead. If there is little or no tension, adjust the top tension to a higher number, say from 3 to 5, or from 5 to 7, and test the tension again. If you fail to increase the tension by above procedure, look for cotton that might be stuck in the tension blades and remove it. Hope this will help you
Nov 02, 2008 | Singer Featherweight 132Q Mechanical...
My singer simple
tension issue,,,,,upper tension assembly needs to be adjusted, either the machine is not being threaded correctly or tension assembly is bad,,,
Jan 01, 2008 | Singer 3116 Simple
Singer Quantum XL-6000 Computerized Sewing Machine Logo
194 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
