Question about Refrigerators
I have a GE side by side refridgerator that is about 6 years old. The icemaker stopped making ice. There is a blinking indicator that has 2 blinking lights and then a 1 second pause. We changed the filter in case that was it but no luck. Any ideas before I call a tech?
  • beairdfam Sep 12, 2009
    So, it doesn't sound like this is something I can do myself? I tried to get the icemaker unit out but I couldn't budge it and don't want to break it getting it out. I have no electrical expertise. But the troubleshooting sheet says that I should "Jump T and H to bypass the bimetal and start a harvest"... Is this something I can do?
  • Refrigerators Master
  • 3,051 Answers
Hello there:
hesr are several possible solutions i was able to get ideas for you ok
best regards michael
check and see if the fill tube is frozing. mayying times that freeze. I have a GE side - delicious.giffurl.gif quote.gif AIMANNY View Public Profile Find all posts by AIMANNY I have a GE side - post_old.gif post_old.gif
I have a GE side - icon1.gif icon1.gif Quote: ..if this does not work check the optic board sunds like the problem is a bad PC optic boards because power to the ice maker comes through theses boards.
- The PC board kit Part number: AP3137510
Posted on Sep 12, 2009
  • 15,935 Answers
The main reasons this icemaker goes into fault mode are:
  • stuck ejector–maybe a cube didn’t clear during harvest or the ejector has a mechanical problem;
  • no heat in the ice mold–could be an open heater, fried control board, or burnt out motor;
  • motor not turning–this is gonna be either a burnt out motor or a fried control board;
  • motor home position not operating–caused by a fried control board or loose magnet (the result will be continuous ejector operation);
  • thermistor either open or shorted
ELECTRONIC CONTROL BOARD AND INTERNAL COMPONENTS — The Electronic Control Board is secured by three Phillips screws within the control housing. All wiring uses plug-on terminals. The electronic control board contains two hall effect sensors (similar to electronic reed switches) which are activated by one magnet attached to the end of the ejector arm to determine if the motor has reached the “home” position and one magnet attached to the sensing arm to determine if the “feeler” or sensing arm has reached the fully extended position. (Ice has not prevented it from moving outward to the fully extended position).
THE SENSING ARM OR “PADDLE” moves laterally or horizontally (not up and down)
THE THERMISTOR is mounted in the mold body directly behind the control housing. It has two functions: 1) to measure ice temperature during freezing, 2) to determine water level during the fill cycles. (This icemaker can have up to 3 fill cycles: 1st fill is 5.1 seconds, 2nd fill, if needed, is 2.5 seconds and 3rd fill, if needed, is 2.4 seconds) The thermistor is looking for a temperature in excess of 39.6°F (4°C) to terminate the fill cycles. Once this temperature is reached, or is exceeded, the icemaker will start the freeze cycle. If after the third fill, and the temperature has not reached 39.6°F, the control will override this requirement and the icemaker will automatically enter the freeze cycle.
THE FREEZE CYCLE is the period of time where the icemaker is waiting for the cubes to freeze solid. This is based on an algorithm programmed into the electronic control board. The electronic control board makes these calculations once per second and monitors the thermistors’ current or present resistance value as well as the rate of resistance change. This will take into account the various environmental conditions that vary the freeze times, such as control settings, door openings, room temperature, etc., but the average cycle is said to be 75 minutes to drop the 7 cubes in the icemaker mold.
THE HARVEST CYCLE begins when the freeze algorithm (programmed into the electronic control board) has been satisfied and the sensor arm is out or fully extended. If the arm is in the “in” position when harvest is to begin, a delay of 3 minutes will be added once the arm is moved to the extended position to allow for drawer type ice buckets to be removed for this amount of time without starting a harvest cycle. This 3 minute delay will begin again if the arm goes back to the “in” position anytime during the delay period. This arm is spring loaded to go to the “out” position unless it is being held in the “in” position by an obstacle such as an ice cube.
At the beginning of the Harvest Cycle, the mold heater will activate. One second later the motor will start. The heater will remain on until the mold temperature reaches 35.6°F (2°C) and a minimum of 20 seconds have elapsed. If necessary, the heater will cycle within a range of 32°F “cut in” to 35.6°F “cut out”.
To assure that the motor makes a complete revolution, the control checks to see if the motor is not “home” for at least 10 seconds and the sensor arm is “in” for at least 10 seconds. When the ejector then reaches the “home” position, this completes the harvest cycle and the motor will turn off. If the harvest cycle, which consists of one complete revolution, is not completed within 7 minutes, the control will assume that a cube is blocking the completion of the cycle and will initiate a “Harvest Fix Mode”. If the Harvest Cycle is not complete within 30 minutes, the electronic control board will assume some other problem occurred and will enter the “Fault Mode” which will cause the LED to start blinking in an 1/2 second “on” 1/2 second “off” pattern.
THE HARVEST FIX MODE occurs when the harvest cycle is not completed within 7 minutes, as mentioned earlier. This is achieved by raising the mold temperature to 68°F “cut off” temperature, with a 59°F “cut in” temperature. During this mode the motor will cycle off 10 seconds per minute of cycle time. If the motor reaches home position, a second revolution of the ejector will occur to verify that there is no more blockage. At this point, the control board will initiate another freeze cycle without a water fill to avoid a double shot of water from entering the mold. As mentioned earlier, the control will enter a Fault Mode if a harvest cycle (including a harvest fix mode) is not complete within 30 minutes.
POTENTIAL CAUSES FOR A HARVEST CYCLE TO TAKE LONGER THAN 30 MINUTES AND THUS ENTER A FAULT MODE (LED BLINKS):
  • blueextc3221
    blueextc3221 Sep 12, 2009
    Stuck ejector — caused by a cube that was not cleared or a mechanical problem.
    Bad heater — caused by open circuit, control board triac or thermal cut out.
    Bad motor — caused by open motor, or control board triac.
    Motor home position not operating — caused by control board or loose magnet (the result will be continuous ejector operation).
    Thermistor — open or shorted.
    THE WATER FILL CYCLE occurs when the harvest cycle is completed and
    the icemaker is “pre-chilled” to 35.6°F. This pre-chilling of the mold
    allows the thermistor to better detect the level of the water. Water
    entering the icemaker mold will cause the mold temperature to change,
    effecting the resistance of the thermistor. The thermistor has a
    negative temperature coefficient. This means that an increase in
    temperature will cause a decrease in resistance.
    The first fill cycle activates the water valve for 5.1 seconds.
    After this fill, there is a 15 second delay to allow time for the
    thermistor to “read” the water temperature and thus determine if the mold is sufficiently full. If the temperature exceeds
    39.2°F (4°C) after this delay, the icemaker will end the water fill cycle and initiate the freeze cycle.
    The second fill cycle is initiated if the temperature is still below 39.2°F after the 15 second delay. This second fill will be
    only for 2.5 seconds, and again, another delay for 15 seconds will be made to allow time for the thermistor to determine if
    the temperature has reached 39.2°F (4°C). If so, the icemaker will end the water fill cycle and initiate the freeze cycle.
    The third and final fill cycle occurs after the 15 second delay if the thermistor detects that the water temperature still has
    not reached 39.2°F (4°C) . The third fill cycle lasts 2.4 seconds. After this, the icemaker control board is programmed to
    override this temperature requirement and will end the water fill cycle and proceed to the freeze cycle.
    The point of all these fill cycles is to help compensate for low
    water pressure and hopefully avoid the “ice cubes stuck in the ejector”
    problems that is so common with low water pressure.
    POWER ON DIAGNOSITICS TEST MODE
    When the icemaker is first connected to power and the thermistor
    temperature is 50°F or more, the control will initiate a “Power On”
    test before entering the freeze cycle. The test will consist of the
    following sequence:
    1)Turn on the motor until it reaches home position
    2)Turn on the water valve for 1/2 second
    3)Turn on the heater for 1/2 second
    4)Verify that the feeler arm was in the “in” and then the “out” position.
    5)Verify that the motor was not in the home position and then in the home position.
    6)Verify that the motor does not remain on after being turned off.
    7)Proceed to the freeze cycle.
    SERVICE DIAGNOSTICS TEST MODE
    During the first 15 seconds that power is first applied to the
    icemaker, the Service Diagnostics Test mode may be entered. The Service
    Mode is entered by pushing the feeler arm in and out three times within
    15 seconds. (only three times). There will be only one fill cycle (5.1
    second) in the service diagnostics mode without the waiting period for
    the mold to “pre-chill”. If the icemaker has already started a harvest
    cycle and the arm is moving, it may be impossible to start the service
    mode. (since the NORMAL cycle is already started).
    While in the “Power On Diagnostics” test mode, the “Service
    Diagnostic” test mode can be initiated and will override the “Power On
    Diagnostics” test mode.
    This icemaker has no replacement parts available and is not intented to be repaired.
    The thermistor is one busy dude in this icemaker. It’s contantly
    sensing the temperature of the ice mold and controls just about
    everything, from the mold heater to the ice harvest. It will fail
    either electrically open or shorted. Either way, you’re screwed…unless
    you know how to check it. Would you like to know? Ok, I’ll tell you.
    First, locate the thermistor on the icemaker and pull that ****** right out of the printed circuit board. Now, clip your ohm meter leads to the thermistor terminals and check the resistance If your thermistor tests bad, get a new one.
    If the thermistor is good but the icemaker still doesn’t work right, then you have toreplace the entire unit. Sorry, , but that’s GE for ya.
    If you feel you wish to tackle this troubleshooting and repair, we can help you - but if you have never attempted this - its best to let a professional repairman sort out the bad part(s) so you dont end up throwing $$ at the fridge, and have it end up costing more than just calling him right away.
    Thanks for using FixYa!!
Icemaker on side by side not working
Change out your ice maker. If your icemaker has worked for 6 years, you got lucky! They normally have to be changed out every couple of years. We have an unlimited inventory of appliance parts for Whirlpool, so please call us to send your parts out and we'll get them out right away!
Sep 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Water Dripping and freezing from icemaker fill spout.
I appears that no one offers solutions to the hundreds of requests on your website. I don't have enough time to wait for an answer from you folks.
Aug 03, 2009 | GE Refrigerators
GE Side by Side Stainless steel Ice Maker water will not shut off
The fill valve may hae a chunk of debris such as rust in it. If you disconnect power and water, you might disassemble the valve if it's the type that was screwed together. If it's riveted, you'll have no choice but to replace. In either case, make sure you have a filter in the line so this does not happen again.
May 18, 2009 | GE Refrigerators
GE Profile icemaker will make ice but won't dump into the tray
GE uses an electronic icemaker that is not field serviceable. if the Icemaker is getting water then something in the icemaker has failed and the complete icemaker must be replaced. the part number is wr60x10093 I believe and can be purchased online and many different places or thru local appliance parts supply house. thanks peyton
Feb 18, 2009 | GE GSS25LGM Side by Side Refrigerator
My ge profile ice machine on off light is blinking and not making
Blinking light indicates a fault with the icemaker. Look for a blockage preventing the ejector from making a complete revolution, such as a cube that was not cleared, or some other mechanical blockage. All other faults are icemaker component, which are not available as separate repair parts, which would require replacement of the entire icemaker assembly. Please don't rate this if you need a new icemaker, as anything less than a Fix-Ya lowers my score. Thanks.
Jan 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not working
you need to check the inlet screen on the solenoid down below for blockage, also make sure that the freexer is cold enough
Dec 26, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
We have a ge frig one year old. the model # is GSH25JFTE BB. I have noticed that there is blinking green light in the back of the ice maker. I have read the owner's manual cannot find a reference for...
A 1/2 second on, 1/2 second off blinking indicates a fault condition with the icemaker. It could be an open or shorted thermistor, or a harvest cycle taking longer than 30 minutes. Check for a stuck ejector - caused by a cube that was not cleared or a mechanical problem. Other causes can be bad icemaker heater, control board, thermal cut out, or bad motor. Essentially, if you don't have a physical blockage, you will have to replace the icemaker.
Sep 09, 2008 | Refrigerators
Ice maker not working properly
could be the air damper. try adjusting air control for more air at icemaker.
May 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Not making Ice
Best thing to do is make sure the paddle is free to move and not covered in frost. and if that doesn't work. Replace the Icemaker and you will be good to go.
Thanks,
Bill
Apr 22, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
