Question about Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
Cancorder not wrking-e007 error message
E007 error message on sharp camcorder. Only happened 2 days ago. Cannot find solution
  • 4 Answers
Moisture in the cassette holder. Take out the cassette, leave the holder door open for a couple of hours in a dry, warm location, and it should work again.
Posted on Sep 12, 2009
After I charged the battery and started it was normal but once I restarted it showed error-007 and when I opened the tape casing it is not remaining closed with tape in but it closes o.k. without tape.
Posted on Feb 11, 2013
I have a sharp vl-z300 camcorder which is displaying an e007 error can you help
The 007 error is associated with dew sense and is a fairly routine repair.
PC board traces open at System Control IC, and will need to be hard-wired. I would suspect that any reputable electronics service facility should be able to perform this repair.
To find a Sharp authorized center in your area, contact Sharp support at sharpusa.com/CustomerSupport.
Hope this helps (remember to rate this free answer and leave a testimonial).
Sep 27, 2011 | Sharp VL-Z300U Mini DV Digital Camcorder
Canon ir2016 error e007
the e007 error means Fixing film rotation error
the fixing film in the fuser unit is not rotating or is defective.
Solution is to change fixing unit , part number: 3FFM2-3352-00000 (STK FIXXING ASSY)
Hope it helps.
adi
Nov 05, 2010 | Sharp AR-M350N Copier
I have System error E007 problem in my Canon iR-2016 copier machine?
Hi
Thanks for using FixYa. Error E007 means there is a jam in the Fixing/Fuser Assy. Error E007 is related to a non-detection of the Fixing Film/Upper Roller, the fixing film sensor didn’t detected the rotation of the film for 6 sec or more while the fixing motor is driven. Please check the condition of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error. If everything is fine then try clearing the error by entering the service mode, you can do it by pressing *(star), then press 2 and 8 keys at the same time & then press *(star) again.
Now press COPIER>FUNCTION>CLEAR>ERR, to clear the error code.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 28, 2009 | Sharp AR-M350N Copier
System error e007 for canon copier ir2016j copier needs solution
May 23, 2008 | Sharp AR-M350N Copier
E007 and DEW indicator
Few restarts fixed this for me but I know this is going to come back again soon.
Mar 30, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp VL-Z1 Mini DV
posted on Aug 20, 2007 Hello and please any body shed some light as to why would the cassete holder door will not close. It was ok, and suddenly I got the ?ject tape"warning. I took the cassete out but I saw there was some loose tape. After that it does not close. Thanks everyone.c
Jan 18, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Camcorder Error
for a quick fix I usually override it by slightly opening the tape when its being loaded, i think its a sensor issue. my cams been rendered useless because of this stupid error, I cant even sell it now because it only works 10% of the time and that's usually when im just checking out the cam, only when I need it the most does it screw up on me
Jun 06, 2006 | Sharp Viewcam VL-A10U Camcorder
Sharp Viewcam VL-Z1 Mini DV Digital Camcorder Logo
658 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
