And the icon wont go away.And when someone else texts me, it says i have 2 text messages.I NEED HELP!
Hey that same thing happened to me. i think why it happened is if u delete a message before you look at it, so dont do that, and i went to setting and phone settings and deleted all the phone memory which got rid of it but it deleted some of my contacts that were saved to the phone memory. so like all the contacts you added after you got the phone. but yeah it gets rid of it
I tried that but it's a hand me down phone and it says I need a security code but idk what it is?
I had this problem today and i fixed it without resetting anything on the phone. If you have your texts in conversation view, switch it to 'standard view'. go back into your text message folder, then scroll all the way to the bottom. Mine had a text that was from 'unknown' and said nothing. it wont let you delete it from there. you then have to go to delete and 'select all' and delete it that way. The icon will go away once the that unknown text is opened.
Hope this solves your problem!
if your messages are in conversation view switch them to standard view. scroll down to the bottom and read the blank text from unknown. the icon should then go away. to ensure it doesn't happen again. click delete all.
hope this solves your problem. It worked for me today without having to reset anything.
Pls try this Delete all messeges on the phone make sure the mem card is not in .
Its like there so much messeges that your phone memory bank gets corrupted .
good luck
My LG enlighten is doing the same thing. I've deleted every text i had. I've turned my phone on and off like 20 times. I've went to settings and cleared the data on the messenger app and widget and it goes away for 2 seconds then comes back. I've opened in and it comes up as a blank text. I've tried filling it out and sending it. Still there, WHAT DO I DO WITHOUT RESETTING MY PHONE!!!! ;'(
