Question about Singer Sewing Machines
I have a singer 514. I recently got a new foot pedal. When I press the pedal The machine motor runs hard, but nothing happens without moving hand crank -- and it will stop "whenever"
  • annosborn
    annosborn Dec 20, 2012
    will someone PLEASE HELP me thread this singer stylist 514... I havent sewed in a very long time..annosborn@live.com or fb in johnson city,ny
  • 980 Answers
Sounds like you need to open the foot control and adjust the carbon bar, you will soon see it, just undo the screw and move it away from the contact or adjust the screw in the end.
Posted on Sep 13, 2009
On my singer serger-i think i cranked the hand wheel the wrong way, now it won't move needle, when i turn machine on and press foot pedal motor runs but needle doesn't move, how can i fix it?
Force it in it's correct direction of travel using the hand wheel. My dry cleaner with 4 machines had me force one of hers. She said you can't break them.
If there is a lock in the centre of the hand wheel, make sure that is tight and you aren't in bobbin winding mode.
Jun 12, 2018 | Singer Sewing Machines
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
Is the motor in my kenmore sewing machine bad?
will the motor run if you turn it by hand when the power is on
Apr 02, 2014 | Sewing Machines
Singer confience stylist beeps four time and won't let me sew
The beeps usually indicates that your machine is not ready to sew which probably means a function has been left in the activated mode, ie bobbin winder, buttonhole function, etc. . Here are some ideas:
Why does the electronic beeper beep and the sewing machine won sew Sewing...
20 Most Recent Singer 7467S Confidence Stylist Electric Sewing Machine...
Mar 05, 2018 | Singer 7467S Confidence Stylist Electric...
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
I have a brand new Singer Pro Finish Serger and it won't sew. When I press on the pedal it makes noise, but the needled do not move. Nothing else happens.
are the cords for the power & foot pedal plugged in correctly?
the only thing I can suggest is taking the machine to a sewing machine shop
to be checked
or check on youtube or ehow that can help you
Apr 12, 2012 | Sewing Machines
The foot pedal on my Singer Inspiration is stuck on fast speed.
Hi lawoffice474...
Unplug your foot pad from the machine and the electrical receptical.
Try moving the foot pedal with your hands, back and forth as if you were pressing your foot on it.
Did it loosen up?
If yes then you still need some maintenance...
If no then you still need some maintenance.
Disassemble the foot pedal and take as many pictures as you need to be able to reassemble it.
Once you have disassembled then you will look to oil (one drop max) the pivot points of the foot pedal, like the hinge assembly, reostat linkage,etc.
Once you have it oiled then try moving the foot pedal again my hand before reassembly.
If everything moves ok then your good to go...
Reassemble the foot control.
If not then its time to replace it with another foot pedal such as one of these at this webpage below:
Please take time to rate me thumbs up.
http://www.sewingmachinesplus.com/singer-foot-controls.php
Sep 10, 2011 | Singer Inspiration 4206
Singer 2259 - The machine has stopped moving, the foot pedal is making some noise and the hand wheel will turn OK but nothing moves when I push the foot pedal.
Check to see if you have your bobbin winder on. That's usually the problem. Just push it to the left and you should be ok.
Sep 09, 2010 | Singer 2259 Sewing Machine
Sewing Machines Logo
167 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
