Question about Hoover UH50000 Bagged Upright Vacuum
New out of box UH50000 will not start have checked red on off switch.
  • 34 Answers
It is probobly faulty.
Posted on Sep 12, 2009
My Sebo X4 does not switch on, when powered up two red lights flash momentarily. There was a buzzing from the black box underneath but that has now stopped. I changed the bag yesterday as it said it w
Your red lights flashing momentarily is normal start-up. The fact that your servo motor is operating tells you that you are getting power. If the vacuum motor does not turn on, you likely have a problem with the motor itself or the power supply board that feeds power to the motor. These items should be covered under warranty. However, if your vacuum is outside the manufacturers warranty, you can replace either of these parts fairly easily with only a phillips head screwdriver.I have included a link to the parts list for this machine. We do stock both parts. http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Sep 24, 2014 | Sebo X4 Extra Bagged Upright Vacuum
Won't start, i push the red start button but it wont start
Start by checking the power cord and switch. If not solved you will need to follow power down to motor looking for circuit break. If none check motor,
Feb 17, 2014 | Dyson DC25 Vacuum
I LOST MY REMOTE CONTROL, INSIDE THE LIGHT THERE IS A PLASTIC HOUSING WITH CIRCUIT BOARD AND DIP SWITCHS THERE ARE SOME NUMBERS ON THE OUTSIDE, FCC NO CHQ8BT7051R MODEL NO UC7051R SERIAL NO...
i got a new remote switch box to put inside the fan, wiring in the lights was a snap but i have a red pink grey and yellow wire that control the fan and i should have tested the wires before i unplugged and re wired the light because the fan was running on low speed when we flipped the switch on thewall sending power to the fixture itself now i suppose there are only 16 different combonations to send power to the fan unless you factor in that maybe the red and pink are high and low respectivly and grey is "close" to black and yellow is white then you gotta have a switch to go high or low, God save us all and bless the person who can tell me what the other 4 wires go to
Apr 18, 2011 | Vacuums
My new Hoover Wind Tunnel Upright UH50000 will not turn off unless I unplug it.
First I would be sure the handle was properly installed. Remove the two screws holding the upper handle in place and tap it bacwards to remove it. Set the switch inside to the OFF position. Next set both buttons on the handle to the OFF position and re-install the upper handle. If the switch still does not turn the vacuum on and off, the switch will need replacement.
Apr 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | GE Vacuums
I have a broken chain switch that will not allow me to use all four light sockets. presently only using two sockets. Question: can I by pass the switch by combining all the black wires from the leading...
The blue should be for the lights and you can ty this into the black. The red should be the incoming for the motor to the fans. Some models are different and I strongly believe you have got to be talking about a ceiling fan and not a vacuum. Is this a test question? Because it is a darn good one if you do not mind me saying so however you might have not noticed to check or uncheck a box for the fans. Good luck.
Nov 02, 2010 | Vacuums
Brush roller on Hoover upright stops turning
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Dec 13, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
No power to the motor
http://geeksquad.fixya.com/ThreadView.aspx?prdid=49977&thid=601650
Posted by jdw121 on May 16, 2008
When I turn the machine on (both red and black switches) the red heat light goes on but the motor does not. If I leave the unit unplugged for a half hour or more, the unit will turn on. If I turn it off and then try a few seconds or minutes, the motor will not turn on.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a thermal switch problem – when the machine gets too hot it will shut off to protect the machine until it cools off and then it will re-start or if it gets hot or plugged. The one light could be for the heater and the other could be for the motor, but it is a good idea to check with the customer service dept @ Bissell to see if they have a better solution and also check in the trouble shooting part of the owner’s manual. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 16, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Hoover UH50000 Bagged Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
