Question about Logitech MX Revolution Wireless Laser Mouse
Need to replace the battery in a Logitech MX Revolution Mouse
  • scottjacks3 Sep 13, 2009
    What was not mentioned in the above, is that you have to remove the teflon pads on the bottom to get at four screws that hold the body to the base. Once removed, turnt he mouse right-side up and lift the top of the body away; there is a ribbon cable connected to the top center button that does not have to be disconnected. The battery type is a 600ma, 3.7Vdc Li-Ion battery in a flat pack. Type is L-LL11, SS/N: F12440066 with L/N: 200605.
    Now that would have been a complete answer.
  • 59 Answers
Hello. Yes, it is quite simple to remove the battery of a Logitech MX Revolution mouse yet for some reason when going through the Logitech product support website it states that it is not possible. Just remove the 4 teflon pads located on the bottom of the mouse and then remove the four screws located under the pads. Once this is done turn the mouse back upright and remove the top off of the mouse. I would suggest temporarily removing the flex cable that holds the top and bottom of the mouse together. There is a small metal clip that holds the battery in place that must now be removed.
NOW FOR THE VERY IMPORTANT PART. There are two different generations of the Logitech MX Revolution mouse which have different batteries. The first Generation uses the L-LY11 battery and the newer generation of the MX Revolution uses the L-LL11 battery. There is no way to tell which battery your mouse uses without first opening up the mouse. Once opened you can easily tell which battery your mouse uses. Here is a link to a site that shows you an example of the L-LY11 battery: MX Revolution L-LY11 Battery
Here is a link to a site that shows you an example of the L-LL11 battery: L-LL11 Battery for Logitech MX Revolution Mouse
As you can see the L-LY11 battery has wires and a plastic connector and the L-LL11 battery has contacts. You should definitely determine which battery your mouse uses ahead of time to eliminate any frustration caused by ordering the wrong battery ahead of time.
Posted on Jul 22, 2013
  • 51 Answers
You can open the cover and change the battery so simple
Posted on Sep 12, 2009
3 Suggested Answers
leethedeuce
  • 4472 Answers
SOURCE: Necessary effective link for a Logitech MX 5500
What are you looking for the drivers? or the transmitter/receiver? Once I have more detailed information on your problem I can assist you further.
Thank you,
Lee
Posted on Oct 25, 2010
  • 10 Answers
SOURCE: MY LOGITECH MX REVOLUTION MOUSE
There are a number of reasons why your mouse isn't reponding:
  1. Check that the batteries are full
  2. Check that the mouse is synchronised with the adapter
  3. Check you have the correct drivers installed.
If none of these things help you, then if your mouse is still under warranty, I'd ask for another one.
Good luck! John
Posted on Mar 13, 2011
MY LOGITECH MX REVOLUTION MOUSE NOT RESPOND
Good luck! John
Mar 13, 2011 | Logitech VX Revolution 931690-0403 Mouse
Mouse will not charge when put in the base
I have a very bad solution about this, but it works on my mouse that also doesn't work. Try to put a tiny bit of water ( or spit Oo ) on the little, usually copper, receivers on the mouse. That makes for a better contact. Just get your finger wet and touch those receivers.
May 15, 2010 | Computers & Internet
Logitech MX Revolution Left Click Button Broken
I have a Logitech Revolution MX 5500 Bluetooth mouse (part of the Logitech MX 550 desktop set.)
In my case, uninstalling SetPoint and re-installing solved this exact problem.
Mar 23, 2009 | Logitech Cordless Desktop MX 5500...
New mouse wont connect....
This is a common problem, go to the Logitech website (www.logitech.com) and download the Reconnect utility. Follow the steps given to you in the software and it should work fine! If not, is the mouse fully charged?
Nov 10, 2008 | Logitech MX Revolution 931689 Mouse
Battery
Not sure how your mouse is configured but will give you two possibilities to use.
Turn your mouse over and see if there is a small door on the bottom where the batteries are located.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Aug 21, 2008 | Logitech MX Revolution Mouse
Laser Mouse MX 1000 By logitech
try replacing with new rechargable batterys
Nov 03, 2007 | Logitech Cordless Mouse
Logitech MX Revolution Wireless Laser Mouse Logo
1,031 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
