Question about Canon PowerShot A590 IS Digital Camera
Same problem..lots of life left but camera says CHANGE
The batteries still have plenty of life, but the camera says they need changing and turns off. VERY frustrating.
  • brucepotter Sep 13, 2009
    Gee...you don't think that was the first thing tried? 4 different types of batteries...all new...all different NIMH..same 1.2 vlts...all the same result. Now using 2600 NIMH. Let's make it clear..these cameras have a defective indicator from the factory and the problem is widespread. What we need is a FIX or a workaround. It would be nice if we could dsconnect the sensor. Incidentally, mine will run for hours on the "slideshow" mode after it will not even turn on to take a picture.
    Problem Solver:
  • 16 Answers
How many volts do the batteries have on each of them? Many devices will not work if even one battery is less than the rated value of the battery like 1.5 volts. One battery low or bad draws down the others in series with it. It will be seen as a resistance and not a power source.
Try a new set or if you can use a fresh set of Alkaline.
Posted on Sep 13, 2009
My batteries dont last long. I put in new batteries and after only maybe one hour of use i get the change battery prompt.
Battery life really depends on a lot of things the amount of use you are giving the LCD screen, the temperature you are using the camera in meaning the colder it is the shorter the battery life, not all batteries are created equal and most "no name" brands are lacking in staying power. Your camera is able to work with rechargeable batteries Ni-MH AA's will last at least three times the length of the Alkaline types. You can buy a set of four rechargeable batteries with their charger fairly inexpensively and will pay for themselves very quickly because you can keep charging them.
Dec 27, 2010 | Canon PowerShot A1100 IS Digital Camera
The camera(Fujifilm Finepix AX 250) says that the life of brand new, never used LR6 AA Alkaline batteries is gone in 10 min-1hour, when the batteries have plenty of life left. The camera takes 2 AA LR6...
A search of the Fujifilm website provided no answers. Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol. Also, I would switch to 3 or 4 sets of rechargeable batteries. That way, you always have a fresh set ready and you'll save money in the long run.
Dec 15, 2010 | FUJIFILM AX250 Digital Camera
Camera is saying batteries are no good. They show plenty of life
Please update to the latest firmware from the Kodak site and try if the problem gets resolved
May 01, 2010 | Kodak EasyShare Z650 Digital Camera
I insert a new battery and go to a party. I switched on the camera and after some time the camera asks to change the battery and turned off. Change the battery and the same thing happens. The camera worked...
If you've recharged this battery many times over the past two years, it may be at the end of its useful life. Always run the battery down before recharging to extend its life. Also, don't ever let it completely discharge by leaving it for a long time...it will die.
Nov 09, 2009 | Canon PowerShot S3 IS Digital Camera
CAMERA WON,T TURN ON BATTERY HAS PLENTY OF LIFE LEFT
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Oct 24, 2009 | Kodak Easyshare M753 Digital Camera
Camera immediately turns off after being turned on
I have owned three Kodak cameras, the last and recent one being the M1063. They all three developed the same problem within two months of ownership....."zoom lens will move in or out depending on original position(gets stuck in out position), and camera beeps, then turns off."
It was always sand/dirt/dust in the zoom section.
Hold the camera in your right hand, as if you are going to take a picture and gently tap the left side of camera against the hard, lower part of your palm.
You might have to do it a couple of times and you might have to be a little more than gentle. Just don't bang it hard directly on the LCD screen, just the left edge.
It always works for me. Good luck.
Aug 03, 2008 | Cameras
OBSCENELY short battery life in PowerShot A40 :-(
You need to use Nimh battery specifically designed for digital
camera use with high ampacity usage.
Jan 05, 2008 | Canon PowerShot A40 Digital Camera
Not turning on
Hi -
We have two of these cameras. If it has been dropped, it can affect the way the camera "reads" the case sliding. Please turn the camera over and check on the bottom, and see where the cover is sliding to. If it is off track, it will not read it properly.
Also, rechargable batteries don't really work in this model worth a hoot. It is a power user. We've found only ONE kind of batteries that really make this camera work smoothly - the energizer "e" batteries in the silver and BLUE packaging. I take a LOT of pictures, and have had these last up to a month. (I am always curious about battery life and date them with a sharpie when I put them in.) Even after they no longer power the camera, they have plenty of oomph left for powering other regular items. (Our hair trimmers have been running for two months on AA taken out of the camera.)
Also, please close the slider a couple times and reopen it, making sure it is going all the way over. It doesn't always lock into place, and the camera mis-reads it as still being closed. It is a pain in the rump, and something I hope subsequent models get a modification on!
Also, simple, but double-check your batteries, and be sure they are not inserted backwards. Oftentimes, this is the reason ours won't turn on - in haste, we've put one or both in the wrong direction! Ha!
Hope that is the only problem for you.
Dec 23, 2007 | HP Photosmart M22 Digital Camera
Use of batteries in digital camera
you can change from nickel metal hylide to lithium ion batteries but you need a lithium charger. DO NOT SUBSTITUTE chargers! I've had my sony mavica for 7 years I have not needed to change the flashtube. the flashtube is a xenon based flashtube.
Nov 29, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Epson 3100Z battery life/power consumption
I have only had my 3100Z for about 3 months but I have found the battery life outstanding. I have the NI-MH batteries and haven't actually counted the number of pictures I take between chargings but it seems as if it is 200 or more. I also have many menu changes, view the photos in the camera and leave it on between shots. I also have sleep set for 30 seconds. I have actually never run the batteries down but recharged them twice in anticipation of needing plenty of power when I planned to take a lot of pictures. I'm guessing that you might have some faulty batteries.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Canon PowerShot A590 IS Digital Camera Logo
150 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
