Question about Mitsubishi WS-65807 65" Rear Projection Television
Shut down When I turn the power on the tv it turns on and then off again
  • DeniseW Dec 11, 2007
    It did give me a code. The code says its the vertical protect. Do you know how I can fix this? Thanks
    Thanks for your help will try the outputs. Denise
    Genius:
  • 1,153 Answers
Goto www.ctechnicians.com and it has the diagnosis test steps
Posted on Dec 11, 2007
  • Lashawn Robinson Dec 11, 2007
    Sounds like vertical output bad. Check or Change Q5a37 and IC4B01 vertical output
While I was watching my Emerson TV I heard a loud click and the screen went black and audio went off. When I press tv button on cable remote the tv button glows red, and nothing happens on the tv.
Hi the power supply might have shut down through overheating turn the power of at the wall socket & wait for a short time before trying again the TV might reset itself if this doesn't work its probably shut down from a faulty component. good luck
Oct 23, 2016 | Emerson Televison & Video
Tv shut down about 2 seconds after it turn on
Short circuit protection. The power supply regulator section to your TV is working properly, but after the power supply starts on, it detects a short circuit, by any of the main board section circuit. Your TV need a thorough checkup. Contact any service technician. This is not a user repairable fault. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 06, 2013 | Sharp 19R-M100 19" TV
Tv will turn on, for about 30 seconds, then it will shut down
Hello
There are two main reaons for this fault. The first is with its power regulator board itself. If it has any loose soldering points developed, this type of intermittent fault can occur. The second is with its light engine. If you want to do this work by yourself, you must have thorough knoledge in electroncis, and must have all tools and ability to follow its schematic diagram. The most you need is patience. If you have these all, and want to do the repairwork by yoursef, inform me. I've the schematics of your tV, and all repair adjustments and proceedings. The power supply board and lamp ballast boards for Samsung (HL-T) series are shown here for your referecne. The lamp ballast board also may need to be checked.
Nov 16, 2011 | Samsung HL-T5676S Television
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
TXM3297HF Samsung TV shuts Down
Hi!! Kindly check the power supply section if their is a defective resistor or semiconductor device..thank you.
Jan 29, 2008 | Samsung TXM3297HF 32" TV
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
