Question about Microwave Ovens
My whirlpool SSN - xck3214685 microwave oven
My whirlpool #xck3214685 microwave oven doesn't heat anymore. It is only 8 years old. What could be the problem?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 72 Answers
It's probably the Magnetron. They usually go out.
Most older ovens have a fuse that goes out with it and shuts the unit down. A repair shop should be able to replace the Magnetron at a reasonable cost.
Posted on Sep 12, 2009
SOURCE:
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
My microwave want heat up anymore everything else works
The problem is caused by the magnetron, "heart of the system" or the inverter board, "if 7 years old or less"
Apr 27, 2012 | Whirlpool Microwave Ovens
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
Whirlpool microwave does not heat. The power is
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 15, 2010 | Whirlpool MH7140XF Microwave Oven
It doesn't heat anymore. About 5 years old only.
Check the door safety switch. When they go bad, they oven doesn't know if the door is closed or not. Find them inside on the side opposite the hinge. They go bad because we (read "you and me" open the door with the oven running and that cooks the contacts on these little switches.
Need more info? Post a comment to this question
thanks for your interest in fixYa.com
Dec 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Mar 04, 2009 | Whirlpool MH1150XMQ Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
