Kyocera wild card Cellular Phone Logo
Posted on Sep 12, 2009
My Kyocera Wildcard tends to beep at certain intervals, even though i have no text or voice message and i dont know how to syop it. is this common?
How do I retrieve my incoming messages I am just trying to set up this new phone.I
What phone do you have?
Voice messages or text messages?
press and hold the number 1 for voice messages and go to your text message app to to view text messages
good luck
Feb 18, 2019 • Cell Phones
Is there a built in message machine on this model because i dont know how to use it I lost the book it has a recorded voice but i dont know how to get my messages on model FT365Bl southwestern bell ...
Innovated devices has several feature functions, voice mails, recorder message functions, text messaging, voice through video functionalities. past devices however either have one or the remaining mentioned. For example payphones have voice communications, mobile phones have voice or depending on the modernity would allow picturegrapics or videograpics or internet conferecing. famililiarise with the device to ascertain what has been integrated by the manufacturer. goodluck
4helpful
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 • Cell Phones
My Kyocera wildcard beeps once every few minutes. It started after I opened a voice mail. What's up?
Mine suddenly started doing that and nothing worked until I actually removed the battery for a few minutes, then put it back. No more beeps.
Keep hearing "command not recognized"
well. the problem is that you're probably hitting the command button where you sumbit voice commands like: call "mom".
its a stupid thing to put on a phone, and I've never seen anyone use it. but whatever, verizon's stupid.
again, the voice command key on the enV is the clear button. so if you hold it down, you'll hear the "command not recongnized, after you hear "please say a command".
your hearing it over and over again because you accidently hit it, and since you dont say anything after the beep it gives, it goes "command not recongnized". i dont think it says "please say a command" when its on vibrate, but i couldnt be sure.
hope i helped :)
1helpful
People can't hear me when I talk on my kyocera wildcard phone.
check the microphone of your phone... im sure of that cause i work as a service engineer of repair shop. good luck
MY PHONE WONT STOP BEEPING HELP!!!!!!!!!!!!
mine usually does that too! But, I have noticed that if you turn it completely off for about five mins. the problem stops for a long time, maybe like a month or so.
Wildcard sim card problem
There is no sim card in the phone. Only certain phones and phone networks use sim cards. a GSM network, like AT&T uses sim cards.
5helpful
3answers
I forgot my unlock code....
i gorgot my code to my phone and i dont even remember my numbr
Alarm beeping
Not sure, but the 1x active may have to do with some time of alert that you may have accidentally set in your calendar or alarm clock. Check your calendar and alarm for active alerts.
Top Kyocera Cell Phones Experts
Jim LeVerso - IT...
Jim LeVerso - IT...
john h
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
